I'll check all of the steps you addressed, then will be back for a detailed report.
Grazie!
No. This is why I say go through the User Manual and learn the keyboard. It does not work the way you are assuming. In the case of Portamento ON, the CV values are not sampled-and-held the way you assume. I.e. they are not controlled by the internal trigger.Fernandozarone wrote: ↑Mon Jul 20, 2020 5:35 am1) IMHO it should happen in both Porta sw positions... shouldn't it?
The Service Manual provides tests for mostly static/steady-state conditions. You are trying to improve a dynamic condition. You will need to set up a suitable diagnostic for this. The manual does not supply this but it does have sufficient information for a tech to set one up. (I gave you some hints above.)Fernandozarone wrote: ↑Mon Jul 20, 2020 5:35 am2) I have tried to change the bending angulation of the J wires, but the problem still remains.
I am seriously thinking of giving up...
If any other suggestions , very welcome!
That's the Fatar plus converter board combination? That is lovely!janvanvolt wrote: ↑Sat Jul 18, 2020 1:13 pmMade some progress with mine, awaiting the punch tool to make the wires between both boards. The case however, is shining in its beauty:
Thank you - i forward the compliments to the guy. He's my studio tech and also doing 3rd party work. It is plywood, but laminated, laquered and clearcoat. He suprised me with the blue inner color which complements very much the black.
