[Project] Music Thing Radio Music 4hp sample player
col
Re: [Project] Music Thing Radio Music 4hp sample player
Post by col » Wed Jul 29, 2020 8:05 am
Teensy 3.2 is fine. Last ones I bought were from Mouser.
BartBral
Post by BartBral » Wed Jul 29, 2020 11:05 am
col wrote:
Tue Jul 28, 2020 5:52 pm
BartBral wrote:
Tue Jul 28, 2020 9:27 am
Jumbuktu wrote:
Tue Jul 28, 2020 8:34 am
I seem to have just fried my second Radio Music. Was removing it from the rack while powered up so I could adjust the trimmer to reduce gain and distortion. When I put it back, I must have shorted some pins against the adjacent module's faceplate - it's dead now.
I removed the Teensy and TL074 and did the voltage tests. Zero voltage anywhere. Suggests I have blown something in the power supply. Any suggestions what to replace?
Maybe try L1 and L2...
I doubt that the ferrite beads or resistors would have blown, especially seeing that there are two reset-able fuses. Try swapping out the teensy with the "other" Radio Music.
I meant the fuses as well... But in the schematics it is very unclear what the fuses are called (they are not named at all). So I mistakenly thought they where called Lx...
:doh: Sorry for that!
Jumbuktu
Post by Jumbuktu » Wed Jul 29, 2020 6:12 pm
Jumbuktu wrote:
Wed Jul 29, 2020 5:49 am
Follow up question: Does it have to be a teensy 3.1? Don't seem to be many around now. 3.2 or later.
I have a 3.2 in mine. I think the only difference between 3.1 and 3.2 is that the 3.2 have a beefed up on-board regulator so it can drive more hardware off its 3.3V regulator.
apfEID
electro-vivisection
Post by apfEID » Tue Aug 04, 2020 7:39 pm
Is anyone working on a higher fidelity version of Radio Music?
It does so much of what I want that other sample players literally can't, but the noise floor really restricts what kind of sounds I can use it with.
Te Occidere Possunt Sed Te Edere Non Possunt Nefas Est
http://anthonysaunders.bandcamp.com/
