[Project] Music Thing Radio Music 4hp sample player
dooj88
Re: [Project] Music Thing Radio Music 4hp sample player
Post by dooj88 » Wed Apr 01, 2020 9:34 am
thats a kind offer, thank you. ill report back after more troubleshooting
oootini
Post by oootini » Mon Jul 27, 2020 5:19 am
Wondering about the Radio Music 2017 firmware and stereo files. How are stereo files actually handled? Are they downmixed to mono at output time, or does one of the channels get removed before playback? I searched the thread, couldn't see an answer...
cliffemu
Post by cliffemu » Mon Jul 27, 2020 8:58 am
I recommend batch-converting your files to mono.
Datum
Post by Datum » Mon Jul 27, 2020 2:10 pm
Per the instruction on Tom Whitwell's github the samples need to be converted to mono. I've think I accidentally uploaded a stereo file in the past and the Radio Music played it sped up (a la Alvin and the Chipmunks).
batchas
Post by batchas » Tue Jul 28, 2020 5:38 am
The last 2 comments might be misleading, making think stereo files won't play or won't play properly which IMHO is not the case. Maybe they are refering to 96/24 stereo, which is not handled as it uses too much memory, but the rest below is ok, I have stereo files on my sd card, like for instance 44100Hz/32 bit and they play just fine.
I guess both channels get mixed as I can't imagine any channel being removed before playback. To get more infos I guess it's best to go to the Audio Library for Teensy forum, as in the code I don't see how stereo is transformed to mono.
FS: KESAKO Player & Reverb for Serge and Buchla
Jumbuktu
Post by Jumbuktu » Tue Jul 28, 2020 8:34 am
I seem to have just fried my second Radio Music. Was removing it from the rack while powered up so I could adjust the trimmer to reduce gain and distortion. When I put it back, I must have shorted some pins against the adjacent module's faceplate - it's dead now.
I removed the Teensy and TL074 and did the voltage tests. Zero voltage anywhere. Suggests I have blown something in the power supply. Any suggestions what to replace?
glennfin
Post by glennfin » Tue Jul 28, 2020 9:08 am
How do you do that?..... Audacity? I've been converting files for my Nutella Tusnami one by one in Audacity to convert to mono, sample rate, and remove the metadata.... batch processing would certainly save me a lot of time. :confused:
gelabs
Post by gelabs » Tue Jul 28, 2020 9:20 am
If you have access to a Linux distribution, command-line tools like sox and fmpeg are invaluable for this kind of task.
The planet was, I realized, one of the spots before my eyes.
sc - bc - yt - mg
BartBral
Post by BartBral » Tue Jul 28, 2020 9:27 am
Maybe try L1 and L2...
BartBral
Post by BartBral » Tue Jul 28, 2020 9:33 am
I'm on MacOS and I use the free XLD sample conversion utility.
https://tmkk.undo.jp/xld/index_e.html
[EDIT] Never mind, XLD doesn't convert wavefiles to mono[/EDIT]
Or as mentioned above SOX is very handy for sample conversion... But it doesn't come with a GUI. But you can write Bash-scripts to automate the process, but that take some trial and error... and a lot of Googling.
cliffemu
Post by cliffemu » Tue Jul 28, 2020 10:47 am
Audacity -> File -> Apply Chain -> Apply to Files ;)
col
Post by col » Tue Jul 28, 2020 5:52 pm
I doubt that the ferrite beads or resistors would have blown, especially seeing that there are two reset-able fuses. Try swapping out the teensy with the "other" Radio Music.
Jumbuktu
Post by Jumbuktu » Tue Jul 28, 2020 8:37 pm
Thanks. I am not game to try a working Teensy for fear that I fry another one (possibly). Anyway, zero voltages suggest that it probably won't work.
Do the fuses automatically reset? Is there a possibility they are 'stuck'?
col
Post by col » Tue Jul 28, 2020 11:28 pm
Do you have a multimeter? Check for continuity across the fuses.
Jumbuktu
Post by Jumbuktu » Tue Jul 28, 2020 11:29 pm
Yes - obvious now!
col
Post by col » Tue Jul 28, 2020 11:33 pm
When you say there is zero volts, where and how are you checking the power?
Jumbuktu
Post by Jumbuktu » Tue Jul 28, 2020 11:57 pm
I was using the build doc guide. Multimeter in Volts mode, ground near the power socket and looking for +/-12v in the middle pins of the TL074 sockket.
I'll check the continuity of the fuses later when I finish work.
Jumbuktu
Post by Jumbuktu » Tue Jul 28, 2020 11:58 pm
Yes - obvious now!
I meant 'Good idea! Why didn't I think of that?'.
col
Post by col » Wed Jul 29, 2020 12:27 am
If you are not getting power at the 10 pin power socket, then it must be either the ribbon cable, a connector or your Eurorack power supply.
Jumbuktu
Post by Jumbuktu » Wed Jul 29, 2020 1:14 am
I didn't check the voltage at the power socket itself, so I should do that as well. However, the other modules in that rack have not been affected.
Jumbuktu
Post by Jumbuktu » Wed Jul 29, 2020 2:45 am
Ok, went back and did the tests properly. I must have been tired when I did it last night. I used hooked probes to get the ground secure this time.
I now get the correct +12v / -12v on the middle pins of the TL074 socket, and +5v for the Vin pin on the Teensy socket. I guess I can now safely test with another back board. If it works, next step would be to swap out the TL074 and then eliminate it (so it's the Teensy) or not.
Thanks for making me think this through properly.
col
Post by col » Wed Jul 29, 2020 2:48 am
Are your Radio Music DIY ones? Sometimes on the factory ones the Teensy has been soldered in.
Jumbuktu
Post by Jumbuktu » Wed Jul 29, 2020 5:24 am
DIY.
Ok, so the front board works with the second back board.
Tried to reflash the Teensy. No sign of life. Looks like it's cooked :(
Jumbuktu
Post by Jumbuktu » Wed Jul 29, 2020 5:49 am
Follow up question: Does it have to be a teensy 3.1? Don't seem to be many around now. 3.2 or later.
smiler
Post by smiler » Wed Jul 29, 2020 8:05 am
I have a 3.2 in mine. I think the only difference between 3.1 and 3.2 is that the 3.2 have a beefed up on-board regulator so it can drive more hardware off its 3.3V regulator.
