Hello wigglers!
I am very proud to present my first digital module: the JME b101 Quad Locked Funtion Generators.
Basically, this module consists in FOUR digital LFOs that can create a quite extensive range of modulation sources on its own AND can be expanded to add some more.
LFO features:
-Sync/reset input that, depending on its mode will reset the LFO or sync it a rate wich is a factor of the incomping pulse frequency and of course a button to switch the operating mode
-Potentiometers allow to set frequency/division and waveform
-Continuosly variable waveform from sine to 99% pulse
SINE -> TRI -> RAMP -> SAWTOOTH -> VARIABLE PULSE WIDTH
then it select form Sample and Hold, noise or quadrature waveform (Locked at LFO A Phase/Frequency)
There are three expanders for this module
JME b101-2 Control Voltage, which adds CV inputs for both frequency and waveform modulation
JME b101-3 Phasing Controls, which add phase position and modulation controls
JME b101-4 Digital Controls, which add a "freeze" function (it stops the LFO in its position) and another reset pulse.
Other useful infos:
- LFO frequency range is from .03 Hz to 205 Hz
- LFO Amplitude is +/-5V
- Gate output is high for the first half of the waveform, 0/5V
- CVs voltage range is +/-5V
- Digital inputs expect 5V for an active level. However, they can work with voltages from 3V3 to 15V
Dimensions:
b101: 14HP
b101-2:4 HP
b101-3:6 HP
b101-4:4 HP
Power consumption:
+12V: 140 mA
-12V: 20 mA
with all expanders
+12V: 150 mA
-12V: 30 mA
I will of course provide fully built modules or PCBs/Panels/Programmed micros or a combination of the three.
All modules are 99% SMD, but i used 1206 and soic so still very easy to solder.
the MCU is a dspic30F4013
Prototype in Action
PROJECT STATUS AT 09 Oct '15
3 units left
Prototypes of main module and cv expander are fully working.
However main module needs some improvements/corrections on both pcbs.
CV Expander is 100% working.
The other two expanders circuits are tested and working but pcbs weren't made
For the first batch panels with be: Black anodized aluminum with white finish.
Price List:
B101 QLFO
- Built: 250€ + shipping
- PCB set + Panel + Programmed PIC: 52€ + shipping
- PCB set (mainboard and panel controls): 30€ + shipping
- Panel: 15€ + shipping
- Programmed PIC: 9€ + shipping
B101-2 CV
- Built: 50€ + shipping
- PCB + Panel: 20€ + shipping
- PCB: 10€ + shipping
- Panel: 10€ + shipping
B101-3 Phase controls
- PCB + Panel: 22€ + shipping
- Panel: 12€ + shipping
B101-4 Digitals
First Batch Orders:
Zaibach: B101 FS, B101-2 FS, B101-3 FS, B101-4 FS
sammy123: B101 FS, B101-2 FS, B101-3 FS, B101-4 FS
adnauseam: B101 FS, B101-2 FS, B101-3 FS, B101-4 FS
falafelbiels: B101 PCBs + IC, B101-2 PCB
paulstone: B101 PCBs + IC, B101-2 PCB, B101-3 PCB, B101-4 PCB
Eloc: B101 FS x2, B101-2 FS x2, B101-3 FS, B101-4 FS
vtl5c3: B101 PCBs + IC, B101-2 PCB, B101-3 PCB, B101-4 PCB
synaptec: B101 FS, B101-2 FS, B101-3 FS, B101-4 FS
euromorcego: B101 FS
mecanikill: B101 built, B101-2 built, B101-3 built, B101-4 built
cane creek: B101 FS
FS = Full Set (PCB + Panel + Pic)
