It was super stormy yesterday in my home town, huge hail and lightning.
I disconnected my studio in fear of power spikes and entertained myself inside. While my girl was out getting her hair cut i made a pnp layout for the buchla 295 comb filter
i used a serge pcb layout and substituted the opamps for 5532s but i guess TL072s would work. There is also a quad opamp package for the input buffers and output mixer section, based from tl074.
I did this layout as functionally it resembles the serge resonant eq and i planned on making my own serge panel soon in which it would be included
each stage is a 6db filter with trimmable freq, Q and mix level pot. i think 20k trimmers boost the Q so you could bring that out to the panel (untested)
but on the buchla panel there was just a mix level pot and indivual out jacks
i heard it is meant to be a good filter bank with a metalic sound
if you look at the schematic you can see there is a 220ohm resistor before each stage ouput, this needs to be wired off board. the summing line (along with resistors also needs to be mounted off board and then brought back to the mix input)
schem found here
http://rubidium.dyndns.org/~magnus/synt ... 50_200.jpg
pcb is 2" x 6" and is designed viewing from above
