Jürgen Haible Krautrock phaser BUILD THREAD
Re: Jürgen Haible Krautrock phaser BUILD THREAD
Hey guys
So I have finally got to the krautrock phaser in my back log.
Seems like a lot to watch out for but with this thread and the LED man site I am ready
I intend to but it in a Hammond 1550G enclosure with a Yamaha PA20 as I don’t want to deal with mains power.
One question, does anyone have a part number for the rotary pot for the stages?
Cheers as always.
Cheers as always.
- Learning to Wiggle
I used a dpdt toggle wired like this for the stages if that's any help?
https://www.talkbass.com/attachments/sp3t-gif.1739206/
- FactoryDefault
Me too. Get a dpdt on-on-on toggle off you go this route.manymachines wrote: ↑Wed Nov 11, 2020 11:45 amI used a dpdt toggle wired like this for the stages if that's any help?
I used this one: 100DP6T1B1M1QEH
If you really wanted to go rotary, you only need 1 pole and 3 positions, so the switches in the jasper bom will work, since they have the ring that you can move to change the number of positions.
Cheers for the info guys.
I will go toggle switch. Takes up less space in my enclosure and easier to wire!
Thanks as always.
Thanks as always.
Hi All,
finally got this boxed today. Normally I hate boxing effects but I decided to go big (1550G) and it paid off, no hitches and plenty of room to work ;]
This is such a great sounding thing, respect to JH! RIP
- FactoryDefault
Manymachines, That looks awesome!manymachines wrote: ↑Thu Nov 12, 2020 12:08 pmHi All,
Agreed. This phaser sounds sooo good. Since I finished the basic build it’s been hard for me to finish putting it in its enclosure. Every time I sit down to work on it I end up noodling with it instead of crimping cables.
thanks!
i know what you mean, I noticed after I posted this that the status LED has stopped working, I guess I mangled it a bit while boxing but I'm having so much fun with this I can't be bothered to open it up and fix it right now ;]
Hey Many machines,
where did you get the bulb cover /Cap thing?
And those knobs.
Very nice.
I will also be putting mine in a 1550G.
Cheers as always.
And those knobs.
Very nice.
Cheers as always.
Hi just saw this message so sorry for late reply!
I got the lamp holder from ebay— https://www.ebay.co.uk/itm/MES-E10-Pane ... SwJe9eWkHq
I don't know if he's got any with the red cover left. The bulb JH specifies is just a tad too long for this holder so the panel nut inside the enclosure doesn't quite reach the thread. I think I botched it with some tape!
The knobs are from uk-electronic.de
look forward to seeing your finished project, so many variations of sound possible with this thing!
- Hermetech Mastering
- Ultra Wiggler
There's a lovely free plugin version here, I was surprised how good it sounds. Hard to find good flanger and phaser plugins that sound like the real thing.
https://ccrma.stanford.edu/~jatin/chowdsp/
Thanks manymachines. I was able to get the red bulb cover and it looks sweet.
Guys, are there any calibration guides
What do the 3 trim pots do?
Is it just trim to taste or what.
This is the longest it’s ever taken me to build a “pedal effect”!
Cheers as always
Cheers as always
Can anybody who's built this on internal power recommend a transformer, preferably from Mouser or Reichelt? Thanks
WTB: MacBeth X-Series Single VCO / Dual Oscillator / Elements
I used this one: TALEMA 55102-P1S2 for both the Krautrock and the Tau Pipe phaser. It fits the vandaal Krautrock phaser enclosure if you are building that. It's only avaible from TME AFAIK
Thank you. I have been advised that Newark/Farnell MCFM70/18 fits that enclosure also, so it appears there are some options.
Well, this is a long time coming. When I first posted to this thread it was June of 2015. This was one of the more difficult builds I'd done and I
kept running into problems. Then I'd put it on the shelf. Get it back off the shelf. Tinker a bit. Put it back on the shelf. But it wasn't until today that I almost pulled the trigger on buying an original Schulte Compact "A" for a LOT of money online that I decided to get it down ONE MORE TIME and: what do you know! I finally found the problem! So, I followed my own advice in not giving up. It sounds amazing and, I FINALLY got it to work perfectly.
Patience and well, some troubleshooting skills I learned along the way.
[attachment=0]Phaser.jpg[/attachment]
This has been a super-informative thread, and I wish I had found it earlier. I thought I'd share some of the issues I had getting mine going. It seemed to (mostly) work first try, though the bulbs were oscillating, I was getting no phasing. I found the relay sub I had used (255-1079 from Digi-Key) had reverse polarity on the coil pins, so I did a wire flip between the relay and the board. I couldn't readily find the proper relay (though now from another thread I see an Axicom/TE V23105A5403A201 is supposed to work). I had a hard time finding the proper fuse holders here in the US initially, but I did find also from Digi-key, F6245, perfect fit. I also had no oscillator period adjustment, until I placed the shunt I had forgotten. I used the Adafruit 485-161 photoresistors. I don't think they have the same dark-resistance as the originals, but I put them in sockets so I can try others. I went with the internal power supply, and used a 36 volt center-tapped 500 mA toroidal transformer. The case is an LMB MDC-973. With the board mounted to the top, it's a really tight fit at the front for one of the bulbs (which I had to take the base off of to shorten), and some of the heat sinks. If I had it to do over again, I'd mount the board on the bottom cover, and remote the pots.
One final thing, just throwing this out there.. if anyone knows where I can get a copy of J. Haible's Dark November, PM me!
This is my exact issue... I'll check out the Relay I am using,Luchswald wrote: ↑Sun Feb 21, 2021 2:39 pmThis has been a super-informative thread, and I wish I had found it earlier. I thought I'd share some of the issues I had getting mine going. It seemed to (mostly) work first try, though the bulbs were oscillating, I was getting no phasing. I found the relay sub I had used (255-1079 from Digi-Key) had reverse polarity on the coil pins, so I did a wire flip between the relay and the board. I couldn't readily find the proper relay (though now from another thread I see an Axicom/TE V23105A5403A201 is supposed to work).
not sure I understand this, but might look out for a recommended relay... anyone got a part number that they know works?I did a wire flip between the relay and the board
mine has been on the WIP bench for many a year, so woudl be great to get it working.
- FactoryDefault
The part number above works in mine. (TE V23105A5403A201)
Not sure where you are but it’s available from mouser in the US or U.K.
The trick is to use a non-polarized relay so whichever way you energize the coil, the relay switches in the right direction.
