Jürgen Haible Krautrock phaser BUILD THREAD
- diophantine
- Super Deluxe Wiggler
http://vandaal-electronics.com/product/ ... ng-x-case/AonFLuX wrote:Very nice! Planning on selling cases?
Sweet! Ordereddiophantine wrote:http://vandaal-electronics.com/product/ ... ng-x-case/AonFLuX wrote:Very nice! Planning on selling cases?
That looks fantastic! Where did you source the big red button and the sharp-looking knobs? Jameco sells some knobs that go all the way to 12!!vandaal wrote:Built and designed a case for the beast.
https://www.jameco.com/z/RN-12POS-Arndt ... 58143.html
Hello.grenert wrote:That looks fantastic! Where did you source the big red button and the sharp-looking knobs? Jameco sells some knobs that go all the way to 12!!vandaal wrote:Built and designed a case for the beast.![]()
That red switch is ONPOW LAS1 series ON-OFF pushbutton with red illumination. (16mm panel cut) You can put there what ever fits 16mm hole and is ON - OFF. I used 24V version. It gets 12V from the circuit.
More options to dial (12 or 11) is always nice to have
They have to be in a correct region and according to the spec sheet. But they dont need to be 100% the same on the whole curve. Buy 8 and try it out. Its analog machine. You want it to be off, thats the whole beauty. Worstcase the filter cutoff is not that deep, but it still works. Later if you have the machine ready you can start improving.
- keninverse
Best way is with a curve tracer, next would be a jig and o-scope last would be just measuring the on/off resistance with a DMM. Set up a LED on a breadboard, plug in some optos to hold them in the same position, measure the on and off resistance. If you have a multichannel scope you could set up a channel for each opto or you can also record the output if you have a newer one.nologin wrote:A guy told me that the photo resistors must be matched, there is no explanation about it anywhere, someone could give some explanation how to proceed?
- Bamboombaps
- Wiggling with Experience
https://www.jameco.com/z/ADU180100-AC-t ... 21216.htmlBamboombaps wrote:What psu are you using? Can you explain your wiring for the power?
for wiring see this page...
http://electro-music.com/forum/topic-20373-225.html
- LED-man
- Contact:
It’s better to use Full-wave rectifying,
I tested half wave (1x single AC) years ago, much more noisy.
Quote from Juergen.Haible:
Half wave rectifying is considered "not elegant", because it needs overly sized capacitors, and creates higher peak currents. But the more I think of it, the more attractive it is to simply use a single wall wart and just upsize the capacitors. We're talking of just a few cents more on caps here (and there's plenty space on the board) - at the benefit of a safe and easy way too hook it all up at the mains.
- Reese P. Dubin
- Reese P. Dubin
- wackelpeter
- Veteran Wiggler
Without digging too deep into the thread i found a Statement by Jürgen where he said that this should be a stand-alone box as it draws a lot of power... and your psu in your modular would have some hard time to handle that and will likely cause voltage Drops in your PSU-Output.hububalli wrote:Does anyone know the power consumption on 15v?
Want to stick it in my modular but I think this will be quite hungry!
http://electro-music.com/forum/viewtopi ... c&start=25
- LED-man
- Contact:
It’s no problem to use this phaser in a 5U System, because we use NO cheap meanwell switching psus (which only have 500mA at the -15v rail.)
There’s a reason why you can order MOTM Panels for the Krautrock.
The module ask 50-75mA per rail.
https://www.dsl-man.de/display/MAIN/Jue ... er+in+MOTM
Just finished building and testing two of these that use those tasty Van Daal cases. (Picture below of the one that turned out nicer.) No huge issues with the builds or wiring though I had to spend some time tracking down funny little issues with the LFO/modulation section (cold joint hidden under some wire on one, first incandescent just not screwed in enough on the second) and even the schematic makes it a little unclear that two pins of the Osc Period pot are to be shorted. I used the Adafruit LDR's mentioned earlier in this thread and they seem to work awesome, though of course I don't have an original to compare.
Now to run a drum machine through one of them!
Short little demo in 2-stage mode here:
email: jschnvr@gmail.com
IG: @jackssynthbazaar
Need to try and fault find on my phaser once more as every time this thread gets bumped, I remember I have a complete but non functional one in the cupboard.
if I cant do it in August, its off to the dolls hospital in Clapton for an expert opinion.
aka the Badproducers workshop.
My Synth Instagram here * My Synth videos here
External PSUs and DC jacks are the hallmarks of toys. - Graham Hinton.
I am one of the "tiny fraction of a percentage of oversensitive idiots" who feels the name of this site sends the wrong message.
This is primarily for melody and historical educational purposes - Analogue Music
Re: Jürgen Haible Krautrock phaser BUILD THREAD
Very late in on the build here, i know, I am currently sourcing all the parts I need for this, but my quest for the fabled ldr's has drawn a blank, i read that some of you have managed to source and use some adafruit ldr's. These seems to referenced from various sources, are these the same ldr's that people have had success from?
https://thepihut.com/products/adafruit- ... toresistor
https://www.digikey.co.uk/product-detai ... =315574036
https://www.mouser.co.uk/ProductDetail/ ... qKUw%3D%3D
If there are any other ldr's people have found to be a very close match, would very much like to hear, ideally UK
- the bad producer
These are the original ones:
https://www.distrelec.de/en/light-depen ... p/16028961
I need some too, so doing a bit of cross-referencing
4U panels for sale/4U wiring diagrams/4U stuff here: http://www.loudestwarning.co.uk/
And here, http://loudestwarning.tumblr.com/
https://www.instagram.com/loudestwarning/
