JanneI
- Wiggling with Experience
Post
by JanneI » Tue Feb 26, 2019 5:20 am
5U version UPDATE: only 2 sets left, PM asap if you like to buy. I'm not ordering more of these pcb's near future. Thanks!
acinonyx
- Common Wiggler
Post
by acinonyx » Tue Feb 26, 2019 7:33 am
deleted
"Eureka, Archimedes of Syracuse"
JanneI
Post
by JanneI » Wed Feb 27, 2019 3:21 am
All 5U pcb kits gone.
Starspawn
- Ultra Wiggler
Post
by Starspawn » Fri Mar 01, 2019 5:10 pm
Got my 5U pcbs already
Whos going to be the lucky one to organize panel buys at schaefer?
I could possibly, but Im outside EU so would end up more expensive for all within.
JanneI
Post
by JanneI » Fri Mar 01, 2019 5:29 pm
Starspawn wrote:Got my 5U pcbs already
Good to hear! Heads up for the panel files, I deleted all the 5u format specified mounting holes, so you need to add those, if you like to install the module to your cabinets :-)
JanneI
Post
by JanneI » Fri Mar 01, 2019 5:30 pm
I'm also collecting a "wish list" for 5U module, if there's enough orders (10+) I can do a second run in the future. Add your name if you'd want one.
oozitron
- solder fume huffer
Post
by oozitron » Fri Mar 01, 2019 6:15 pm
Aw crap... I was going to send you PayPal $$ this weekend...
He who hesitates is lost. So true.
Yes, please put me on that list!
Drew
Never want to come down, never want to put my feet back down on the ground
OIP
- Common Wiggler
Post
by OIP » Fri Mar 01, 2019 9:59 pm
yeah i also snoozed on it - i feel like the ease of all-in-one outweighs any benefits of separate euro modules so i'm also interested in a future run of 5U, thanks.
djs
- Super Deluxe Wiggler
Post
by djs » Fri Mar 01, 2019 10:13 pm
Someone needs to get 8 of these and make a polyphonic 606
"Noise is what the Earth is made of" - David Bowie
placidhouse
- Common Wiggler
Post
by placidhouse » Fri Mar 01, 2019 10:53 pm
really nice job on the full panel! might be down for this. will keep watching.
kragg
- Veteran Wiggler
Post
by kragg » Wed Mar 06, 2019 1:21 pm
Hello
For those who want to build the kit, as there are plenty resistors, and it is not very easy to find their value, i scanned my "color sheets", if it can be helpful for someone ?
- 606 diy color help web2.pdf
- (1.56 MiB) Downloaded 59 times
JanneI
Post
by JanneI » Wed Mar 06, 2019 5:43 pm
kragg wrote:Hello
For my PDF file: Try fullscreen mode and switch between pages (RefDes & Values). That's how I build my last one!
kragg
- Veteran Wiggler
Post
by kragg » Thu Mar 07, 2019 11:49 am
How could i miss this
Ricochet
- Common Wiggler
Post
by Ricochet » Fri Mar 08, 2019 2:50 am
I'm on the way ...
sailing away with the first winds of the new day !
Ricochet
- Common Wiggler
Post
by Ricochet » Mon Mar 11, 2019 4:36 am
Are there any pics of the finished module ?
...in particular the mechanical connections
maybe separate pics (of each side) of the PCBs before mounting
JanneI
Post
by JanneI » Mon Mar 11, 2019 6:03 am
BTW, If you have strong opinions which way the pots should react for the mods, then it might be worthwhile to try the module out before designing your panel. Most of the pots work as a variable resistor (check the schematics), so for those pots it's easy to change the rotation just by cutting the trace and sorting the other pin to the wiper. I didn't put any 0-10 style scale to my panel graphics for this reason. Since this is SDIY, do what ever pleases you! ;-)
Bamboombaps
Post
by Bamboombaps » Mon Mar 11, 2019 11:40 am
hi there i have some sets of Jannels BD and HH boards and panels for EURO
2 panels and 5 pcbs £30 + shipping
pm me if interested!
Sanoj
- Learning to Wiggle
Post
by Sanoj » Mon Mar 11, 2019 5:56 pm
aargh. missed the good stuff again, put me on the wish list!
You've got so many machines, Richard
Dominox
Post
by Dominox » Tue Mar 12, 2019 3:48 am
Pcbs / frontpannel's available?
Bamboombaps
Post
by Bamboombaps » Tue Mar 12, 2019 4:52 am
Dominox wrote:Pcbs / frontpannel's available?
i have euro pcbs and panels
djs
Post
by djs » Tue Mar 12, 2019 3:16 pm
Got my 5U pcbs in the mail yesterday- they look great!
Now to work on building a full drum machine out of this
kragg
- Veteran Wiggler
Post
by kragg » Fri Mar 22, 2019 5:32 pm
Did anyone managed to finish it yet ?
I am building mine. I soldered every resistors, diodes, and most of the capacitors.
I would be curious to see more pictures of the finished & populated PCB, and to hear it in action
kragg
- Veteran Wiggler
Post
by kragg » Fri Mar 22, 2019 6:23 pm
A couple more questions : The BoM says "ceramic capacitors" for everything, but i guess it might be a typo ?
Is there anything special to know about the capacitors to use ?
For instance, for the 100nF, i have both Green Mylar, Box (Wima-style, but unbranded), and yellow multilayer monolithic ceramic caps : is there any better than others ?
For 2.2nF and 56nF, i only have green Mylar : will it be ok, or is it mandatory to use box type (from the picture it seems that you use only box type wherever possible) ?
For the 22pF, a yellow multilayer monolithic ceramic caps is fine, i guess ?
kragg
- Veteran Wiggler
Post
by kragg » Sun Mar 24, 2019 11:20 am
little bump ?
JanneI
Post
by JanneI » Sun Mar 24, 2019 1:50 pm
I used C0G/X7R/Wima, which ever I had, no audible difference in my opinion. 22pF / 220pF can be whatever you have. The correct value is more important. If you buy from mouser, I'd use c0g, but I don't think original has anything fancy.
