Slomen wrote:I am building the Vncursal VCA now and I am a little confused about the leds. How do I know what resitor value I should use for my red leds? I´ve got red standard leds, the ones in the BOM. 10k?
EDIT: silly me, it is in the build guide: 20k for red leds
well its 20k for the red leds that come in my kits. not all red leds have the same mcd(brightness). if you have your own standard red led it might be around 1k or a little higher.
yep you need the song huei pots
if i didnt mention it already. i posted a bunch of new build docs recently. theres now vnicursal docs for the mother board, and docs for the attmix and dual vca.
also i posted a vid in euro subforum. but you guys over here would probably like to know theres a new clk dv coming out
the new clk dv mk ii and expander are coming out in a couple weeks. i also fixed whatever problems there were with the last version not triggering with certain slopes and now triangles and sines at audio rate can be divided "clearly."
the expander adds switching over non-inverted, off, and inverted clocks of the 5 divisions from the clk dv. it also provides 3 non inverted divisions of 64, 128, and 256.
old versions of the clk dv are not compatible with the new expander....
heres a little video with the smrf
im cool now, i have an instagram....
https://www.instagram.com/zlobmodular/
also its hard to see but it will be released in black and white pcb/aluminum panel.
o and finally vnicursal, push vca, and miniatt black and red aluminum panels should in by the end of this month or so. and other black and white aluminum pcb panels will be coming out soon for the dual vca, entropy, mineq, and clk dv expander
