DIY Mutable Unsuccessful Builds
cnicht
Re: DIY Mutable Unsuccessful Builds
Post by cnicht » Sat May 30, 2020 6:55 am
I'm not sure it will.
The dual diode (BAT54S) is there to prevent the Normalisation signal exceeding the supply value, the single diode only gives protection in one direction.
Worth a try though and I'll be happy as you to hear that it works.
Faye
Post by Faye » Sun May 31, 2020 4:46 am
This question is not exactly related to an unsuccessful build. But I didn't want to open a specific thread for such a small question. I hope that's ok.
I'm sourcing slider potentiometer for a MI module. On the datasheet I can see that there is a code for the resistance taper. B1 and B2 seem both to be linear:
https://www.mouser.ch/datasheet/2/54/PTL-777483.pdf
As I understand, B2 will reach maximum or minimum resistance a few mm before the end of the travel.
Unfortunately I don't know how they compare in practice.
Should I prefer one over the other for some reason?
Thanks for your opinion.
Flounderguts
Post by Flounderguts » Sun May 31, 2020 12:55 pm
B1 will be more controllable, but in practice they will probably be almost indistinguishable from one another on a module. Get whichever one is cheaper.
Flounderguts
Faye
Post by Faye » Sun May 31, 2020 2:03 pm
Cool, thanks :)
Dominox
Post by Dominox » Sun May 31, 2020 3:53 pm
Hey,
I have a Braids with successful boot, the display works and I have sound on the output!
But no input or Poti work!
I have check't the parts around ic7 and ic9 but I found nothing...
With the oszi I get no good wave only like noise...
Any ideas
Thanks Dominic
cnicht
Post by cnicht » Mon Jun 01, 2020 5:15 am
Check soldering round IC4.
Make sure it's connected to the microcontroller.
stevemensink
Post by stevemensink » Tue Jun 02, 2020 6:18 am
You were right. I just replaced the BAT54 to BAT54S, and it is not the fix I was hoping for :-(.
I have built a couple of hundred modules in my life so far, never had such a stubborn problem. If anything else comes to mind for debugging these, it will be really appreciated!
cnicht
Post by cnicht » Tue Jun 02, 2020 11:44 am
Measure the voltages at the output of the op amps which condition the signals from the input jacks. You may need to disable the normalisation signal to do this.
How does it compare to the calculated voltage?
crawave
Post by crawave » Tue Jun 02, 2020 3:22 pm
Hi everyone. I built a Plaits. all right, I loaded the firmware. the module works all, the only thing is that from dac pin 7 no sound comes out. I checked the voltages at the dac and stm, the digital signal between dac and stm is there. does anyone have a suggestion for me? thank you all.
cnicht
Post by cnicht » Wed Jun 03, 2020 2:16 am
Have you placed jack sockets J6 and J7?
qmulus
Post by qmulus » Thu Jun 04, 2020 7:57 pm
Has anyone who has built Swirls (micro Tides) had any power supply issues? I'm on my third attempt and once again, I'm getting low voltages (between 100-500mv) on all reference points.
I'm at a loss.
cnicht
Post by cnicht » Fri Jun 05, 2020 1:47 am
Is anything getting hot?
qmulus
Post by qmulus » Fri Jun 05, 2020 2:45 am
Nope. Everything is staying cool. Not even a little warm.
cnicht
Post by cnicht » Fri Jun 05, 2020 3:54 am
Interesting.
Did you check the voltages after you'd placed the regulators and reference components and before you placed the microcontroller?
Are D1 and D2 the correct way round?
qmulus
Post by qmulus » Fri Jun 05, 2020 5:56 am
Interesting.
I populated two boards (one for tides, one for sheep) in one go (stencil, solder paste and hotplate). I have both D1 and D2 oriented as shown in the Eagle (stripe on the white side).
The attached pic with the color codings are the pathways, the readings from my multimeter (from both boards) and what they are labelled in the Eagle file. Every point on each pathway came out with the same voltage.
cnicht
Post by cnicht » Fri Jun 05, 2020 6:25 am
Is your DMM set to AC or DC scale?
qmulus
Post by qmulus » Fri Jun 05, 2020 6:39 am
DC.
cnicht
Post by cnicht » Fri Jun 05, 2020 8:07 am
Very strange.
Post some high resolution photos of the board.
pld
Post by pld » Fri Jun 05, 2020 8:35 am
Looks like the silkscreen says -12V right where you're measuring +12V... that's probably important :)
qmulus
Post by qmulus » Fri Jun 05, 2020 2:40 pm
I've been considering that. The pads along the VCC path say "+VCC" while the VEE say "-VEE". Plus, the 3V3 and 3V3_A pads have a "+" in front of them. Those connect to the VCC.
However, in the Eagle file and on the boards themselves, it shows that the red (-12v) stripe goes the other way.
Could this be a design error, and should I try it the other way and see what happens?
I don't wanna blow anything up.
qmulus
Post by qmulus » Fri Jun 05, 2020 2:48 pm
Very strange.
cnicht
Post by cnicht » Fri Jun 05, 2020 3:06 pm
I can't see anything obvious.
I've looked at my Swirls and the +12V end of the power connector is definitely at the top of the board.
It still seems from the voltage measurements though, that the diodes D1 and D2 are reverse biased.
qmulus
Post by qmulus » Fri Jun 05, 2020 3:12 pm
Yup. That was the problem. I went ahead and flipped the ribbon cable around and everything works perfectly now.
Thanks for pointing that out!
:hail:
qmulus
Post by qmulus » Fri Jun 05, 2020 3:15 pm
I flipped the ribbon cable and everything seems to be working now. I just finished flashing the boards, so I guess that maybe the ribbon stripe on the board is marked on the wrong side...?
cnicht
Post by cnicht » Fri Jun 05, 2020 3:38 pm
Diodes D1 and D2 protect the circuitry against reversed power lead connection so if they are soldered with the correct orientation no harm should come to the module.
Glad it's working.
