DIY Mutable Unsuccessful Builds
Altitude909
Re: Stages Sanity check
Post by Altitude909 » Mon Jul 27, 2020 5:24 pm
funketek wrote:
Mon Jul 27, 2020 3:41 pm
Not technically an unsuccessful build yet, but I am confusing myself on the orientation of the RECOM DC converter. My understanding is that Pin 2 is the one by the spool and it should be in the lower right corner on the PCB. I have attached a picture of how I am planning to solder it. However, the top view/bottom view of the pin-out has me second-guessing myself. Could I please get a sanity check that this is the right orientation?
Theres a diagram in the silk screen showing the inductor (round thing) and the IC (squareish thing)
NeolithicElectrophones
Re: DIY Mutable Unsuccessful Builds
Post by NeolithicElectrophones » Tue Jul 28, 2020 4:00 pm
Edit: Bad pcb, all good now.
Last edited by NeolithicElectrophones on Thu Jul 30, 2020 6:55 pm, edited 1 time in total.
Post by NeolithicElectrophones » Wed Jul 29, 2020 5:58 pm
Edit:
After scoping, the issue turned out to be incorrect switch routing on the pcb. Did some trace fixing and all is working.
snowtires
Post by snowtires » Thu Jul 30, 2020 7:16 pm
Hello everyone, I just finished a Braids build and everything is working, except there is a constant note playing when the output is patched. I replaced the MMBT3904 and the two resistors on the gate jack and that didn't do anything, so I'm about out of ideas. This is the first oscillator in my rack, is this maybe supposed to be how it works? I kind of feel like probably not, but you never know.
Post by NeolithicElectrophones » Thu Jul 30, 2020 7:37 pm
Unless you're using the internal vca through the menu, it should output a constant tone. Oscillators without internal vca or patched into an external one will just drone. That's how we all do drone patches at least. But just to sort out any confusion, is it just one continuous note that doesn't change when moving the coarse and fine tune pots? That would be a build issue.
snowtires
Post by snowtires » Thu Jul 30, 2020 7:40 pm
Thanks for replying before I break something trying to fix it! No, the pitch changes along with the pots, I was just confused as to what I was doing wrong. For once it seems like the answer is nothing!
Post by NeolithicElectrophones » Thu Jul 30, 2020 7:47 pm
Great! Congrats on your first oscillator build! Be sure to try out the Renaissance firmware on it, it is KILLER. The manual for braids goes into the depth of the menu system and how to set up the internal vca to be triggered. I personally don't think the internal envelope is long enough for pads and such, but it makes for great shorter keyboard and percussive stuff.
snowtires
Post by snowtires » Thu Jul 30, 2020 10:17 pm
Thanks again, I uploaded the Renaissane firmware and lo and behold I can switch the direction of the encoder! Awesome!
Post by NeolithicElectrophones » Fri Jul 31, 2020 1:01 am
:sb: :party:
aragorn23
Post by aragorn23 » Sat Aug 08, 2020 12:58 am
Hey all, I've got a particularly weird problem, made even weirder by the fact that it's happening on TWO freshly built Rings modules at the same time (one fullsize, one nano). The modules are pretty much fully operational except for the following odd fact: dampness doesn't work (via pot or CV), but the structure attenuator pot modifies dampness. Brightness is similarly non-operational, but the position pot seems to affect brightness. Everything else is fine. I've calibrated both modules, checked for bridges, etc. and I'm totally stumped.
cnicht
Post by cnicht » Sat Aug 08, 2020 4:06 am
Check component values and voltages round IC5 and 7
You can calculate the 'static' voltages at the outputs of these and remember to disable the normalisation signal (by inserting an unconnected patch cable into J7)
sduck
experimental use of gravity
Post by sduck » Sat Aug 08, 2020 6:09 pm
This is a dumb question, that I think I've asked before, but can't remember. The ARM chip I've got has two embossed dots - a smaller and a larger one - which one do I line up with the dot on the PCB?
