Dsh/Dip files are Diptrace Schematic/Board filesthe_laconic wrote: ↑Mon Apr 05, 2021 8:36 pm..
I tried everything in Eagle... anyway, here's a link. I'm not going to build this one again, but I would like to know how to view such files, for future reference, if anyone knows.
https://github.com/jakplugg/twist/tree/master/gerb_rohm
DIY Mutable Unsuccessful Builds
- Altitude909
- Super Deluxe Wiggler
Re: DIY Mutable Unsuccessful Builds
Hi thanks for your help on this!cnicht wrote: ↑Mon Apr 05, 2021 2:39 pmAre you seeing the correct voltages at the outputs of the potentiometer multiplexers?Ms304671 wrote: ↑Mon Apr 05, 2021 1:16 pmHi all,
So I recently finished up building elements. Checked all the voltages across the board, all okay. Flashed the STM, no issues. Soldered in the outputs and gate jacks along with the switch. Powered on and nothing happened. No light in the switch or audio from the outs. Rechecked all the voltages and all is fine there.
Not sure what the issue is, perhaps the precompiled hex files I used? Or do I have to solder in all the pots, jacks and LEDs before it will work?
Any help greatly appreciate. Thanks in advance!
Also the correct bias voltages at the outputs of the 6004 and 6002 op amps?
Checked the multiplexers and they’re all 3.3v with 3.3v to the correct legs on the B10ks also.
Checked the 6002 and it’s reading 3.3v at pin 8. However pin 1 only reads 2.6v.
Checked the 6004s and they’re all reading 3.3v at the corresponding leg as per the eagle file.
Looked at the pin out on IC6 in more detail and noticed pin 1 (pressure) and pin 7 (blow) are only reading 1.6v.
Checked the LME49720 (IC14) and that’s reading 12v.
Are these correct?
Apologies I’m still new to this haha. Hopefully this makes sense and I’ve checked the right things!
What does the output of the multiplexers look like when you turn the pots?
What pins of the 6004s are you measuring?
- standudinski
- Learning to Wiggle
for search continuity, i traced (no pun intended) the issue to a dry solder pad on one of the MCU pins, this was my first solder job using paste and reflow technique and i guess i missed it.cnicht wrote: ↑Sat Mar 06, 2021 7:30 amCheck continuity between microcontroller and DACstandudinski wrote: ↑Fri Mar 05, 2021 11:26 pmThanks!
doesn't look like there is signal on both channels, some probe noise and that's it. what should i look for when checking clock and input on the DAC?
lesson of the day, check your work after soldering, use deduction to figure out what part of the system the problem my originate from, and fix the issue.
i won't be using paste to solder SMD any more, i find the drag technique to be a lot more efficient.
Thanks for all the help!
Stan
- Common Wiggler
Hi! I have a problem with my recently built RINGS.
The device is programmed (bootloader + program with ok), but no sound at the outputs or light on the leds.
I had reprogram it successfully one more time with the provided hex files but no good news.
For you to know I first installed de stm chip backwards, but after realize it (because it cant program) I desolder the same with a hot air gun and resolder it. Then I am able to prorgam it and the programer detects the chip.
Any advice?? (dont know why the photo is turned 90º)
Thanks in advance.
Thanks in advance.
Are all the microcontroller pins correctly soldered?
has anyone programmed a Peaks or any of the other F103CB MCU modules using a STM32 discovery board? I have been told its possible, but I'm having no luck getting the board connected to my Apex (peaks clone) board. I have no idea of what settings I need to change within the STM32cube software, or the programmer hardware. If could be any one of a million issues, dodgy soldering, fake MCU, incorrect config...
I managed to program my plaits board, which is different MCU (although the board has other issues) but this one doesn't seem to be documented online at all.
So, if anyone has done it and could point me in the right direction, that would be VERY appreciated.
FIXED - THERE WAS A SHORT ON THE DAC
Marbles / Cara build...
Hey folks I'm having issues calibrating my marbles.
I have done all the DAC stuff OK, I'm now calibrating the ADC... I'm getting flashing red lights after putting the 1v and 3v into rate and spread.
Ive also noticed that the left side isnt biasing properly when in branches (green) mode. only channels 2 & 3 are lighting up. (this LED works fine in the other modes) it then works OK after calibrating ADC, but then when I restart the module it loses the settings...
anyone have any ideas for what to try / look at? Ive checked all the obvious things...
thanks
Iain
thanks
Iain
- Staticcharge
- Common Wiggler
Hey all, How's it?
Has anyone had any success building Veils 2020 using AS2164 or SSI2164? Other folk have touched on this but having tried the recommended solution of changing the RC and CC values it makes no difference.
The issue I have is localized to channels 1 and 3....on several modules.
My current setup:
https://www.modulargrid.net/e/users/view/99889
Hi,
Checked the centre pins on the B10ks and they vary from 0v - approximately 3.3v
Tried to check pin 3 (ADC_POTS), assuming this is the corresponding output from the multiplexors, and I couldn't get my multimeter probe on it unfortunately. However, I did manage to check the voltage on the corresponding via hole (not sure of the correct terminology haha) which ties all the ADC_POTS traces together before entering the STM32 and the voltage ranged between 0v (pots to the left) and 2.95v (pots to the right).
RE: 6004s I checked pin 4 (3V3_A) and these read 3.3v. Ive also checked Pins 1,7,8 and 14 on all 6004s (with the exception of IC13 this only has outputs at 7,8 and 14). All outputs read approximately 1.65v.
The voltages seem correct
Check the pins of the microcontroller are soldered correctly
Also are you getting signals on the address pins of the multiplexers?
I'm doing an Elements build. I believe I successfully programmed it because when powering it on, the two leds and play button blink a few times in sync and then they turn off. Also, if I power it on while holding the play button down, it appears to go into firmware update mode because the play button continuously blinks (I did this just to test, im not updating it until fully working).
Currently i only have the top row of pots soldered in.
So the issue is, after the initial blinking of the leds at power up, I cannot get the play button (or other leds) to light up, nor can I get any audio out. I'm not really sure what output I should be getting at this point, but I feel like the play button should at least light up when I press it in. The fact that I can hold the play button in at power up to which the board goes into firmware update mode would imply that the play button is properly installed, so I am not sure what output I should be expecting at this point.
With the top row of pots installed, what output should I expect? Or do I need to install the rest of the pots?
The three blinks is an error code for when the MCU can't communicate with the codec. Check for errors on both those chips.
Thank you...that was it...works now
I have built a jakplugg nano rings and now while uploading the firmware have run into some issues. This is just my second MI diy build and the first one was an antumbra elements that instantly worked like a charm so I followed the same procedure in the mutable instruments dev environment and I get the following error
I am a total noob I just know how to use a soldering iron so have really no clue what that means and what is wrong my build. Any help or hints what could have gone wrong would be greatly appreciated. I have also attached a few photos of my build
Code: Select all
cat build/rings/cv_scaler.d build/rings/resources.d build/rings/rings.d build/rings/settings.d build/rings/ui.d build/rings/adc.d build/rings/codec.d build/rings/debug_port.d build/rings/leds.d build/rings/switches.d build/rings/system.d build/rings/trigger_input.d build/rings/fm_voice.d build/rings/part.d build/rings/resonator.d build/rings/string.d build/rings/string_synth_part.d build/rings/atan.d build/rings/units.d build/rings/random.d build/rings/bootloader_utils.d build/rings/system_clock.d build/rings/system_stm32f4xx.d build/rings/misc.d build/rings/stm32f4xx_adc.d build/rings/stm32f4xx_can.d build/rings/stm32f4xx_cec.d build/rings/stm32f4xx_crc.d build/rings/stm32f4xx_cryp_aes.d build/rings/stm32f4xx_cryp.d build/rings/stm32f4xx_cryp_des.d build/rings/stm32f4xx_cryp_tdes.d build/rings/stm32f4xx_dac.d build/rings/stm32f4xx_dbgmcu.d build/rings/stm32f4xx_dcmi.d build/rings/stm32f4xx_dma2d.d build/rings/stm32f4xx_dma.d build/rings/stm32f4xx_dsi.d build/rings/stm32f4xx_exti.d build/rings/stm32f4xx_flash.d build/rings/stm32f4xx_flash_ramfunc.d build/rings/stm32f4xx_fmc.d build/rings/stm32f4xx_fmpi2c.d build/rings/stm32f4xx_fsmc.d build/rings/stm32f4xx_gpio.d build/rings/stm32f4xx_hash.d build/rings/stm32f4xx_hash_md5.d build/rings/stm32f4xx_hash_sha1.d build/rings/stm32f4xx_i2c.d build/rings/stm32f4xx_iwdg.d build/rings/stm32f4xx_lptim.d build/rings/stm32f4xx_ltdc.d build/rings/stm32f4xx_pwr.d build/rings/stm32f4xx_qspi.d build/rings/stm32f4xx_rcc.d build/rings/stm32f4xx_rng.d build/rings/stm32f4xx_rtc.d build/rings/stm32f4xx_sai.d build/rings/stm32f4xx_sdio.d build/rings/stm32f4xx_spdifrx.d build/rings/stm32f4xx_spi.d build/rings/stm32f4xx_syscfg.d build/rings/stm32f4xx_tim.d build/rings/stm32f4xx_usart.d build/rings/stm32f4xx_wwdg.d build/rings/startup_stm32f4xx.d > build/rings/depends.mk
openocd -s /opt/local/share/openocd/scripts/ -f interface/stlink-v2.cfg -f target/stm32f4x.cfg -c "init" -c "halt" -c "sleep 200" \
-c "flash erase_address 0x08000000 32768" \
-c "reset halt" \
-c "flash write_image erase build/rings/rings_bootloader_combo.bin 0x08000000" \
-c "verify_image build/rings/rings_bootloader_combo.bin 0x08000000" \
-c "sleep 200" -c "reset run" -c "shutdown"
Open On-Chip Debugger 0.9.0 (2021-04-10-08:19)
Licensed under GNU GPL v2
For bug reports, read
http://openocd.org/doc/doxygen/bugs.html
Info : auto-selecting first available session transport "hla_swd". To override use 'transport select <transport>'.
Info : The selected transport took over low-level target control. The results might differ compared to plain JTAG/SWD
adapter speed: 2000 kHz
adapter_nsrst_delay: 100
none separate
Info : Unable to match requested speed 2000 kHz, using 1800 kHz
Info : clock speed 1800 kHz
Error: open failed
in procedure 'init'
in procedure 'ocd_bouncer'
make: *** [upload_combo_jtag_erase_first] Error 1
vagrant@vagrant-ubuntu-trusty-64:/vagrant/eurorack-modules$
Are all the supply rails correct?
Have you tried programming it with a compiled hex file from the STM Utility?Maximilianfred wrote: ↑Sat Apr 10, 2021 2:02 pmYes I think so I am measuring 11,84 V , -11,65 V and 3,27 V
- Stoneyards
- Common Wiggler
I'm noticing some odd behavior on blinds. Unpatched, rather than outputting +/- 5V, I get -5V to 3.75V.
Patched with a 5V sine wave, with the pot turned all the way up, the result is an output wave with the top clipped off:
I see more or less similar behavior for each channel (measured with normal from previous channel broken). Channels 1 and 2 output -6V to 3.3V.
Reference voltages are just fine at 10v, -10v. Nothing hot and nothing visibly weird. 12v rails look fine.
Strangely - I built two modules.. Both exhibit this behavior. The other module outputs -6.2 to about 2.8V across all channels. Maybe I installed a wrong value as I built them together?
I traced the problem to the channel of the 2164 VCA that applies the modulation gain to the signal. On the way in, the voltage is tidy, at -4.9V to 5.1V before conversion to current. On the way out it's -0.42V to 0.27V. Vc for this channel of the 2164 is -0.032V and it's coming from the linear control circuit that handles the signal input (which is unpatched, so should be at 5V). So maybe the issue is there?
Here are all the voltages for that circuit (in this case blinds ch 4.)
Reading the application notes from the 2164 datasheet, this is a control circuit that puts the VCA channel in the feedback loop of the 4171. The negative feedback is supposed to be proportional to the input, but I have no idea whether the -0.033V is proportional to the 5V? And is there some problem that's biasing the whole job down?
Please school me! :-)
I’m also eager to hear how this is playing out.Staticcharge wrote: ↑Wed Apr 07, 2021 11:29 amHey all, How's it?
Good to hear! The error code was explained by Emilie in an exchange with a DIYer on her forums, IIRC.
