[pcb+panel] ssm2044 filter for eurorack
falafelbiels
still learning to wiggle
Post by falafelbiels » Fri Nov 06, 2015 6:13 am
Yeah so I built this one in about an hour or so, very straightforward build if you have the parts available.
The silly thing I did was initially build it from the Fonitronik BOM, there is a slight difference regarding r15b. I was like R15B?!?!?! Then when I found the Timo BOM it all became clear. I used 33k for r15 and r15b and I think the range is fine. I have built several Polivoks filters and they were generally worse in this regard.
It sounds quite sweet and tidy, my most well behaved filter so far. The whistling from the self resonance sounds very pure siney.
All in all, very doable and rewarding little project, I give it the thumbs up!
grizzle
Post by grizzle » Fri Nov 06, 2015 7:57 pm
I would like a PCB and panel please!
Tunes-----> apartmentfox.bandcamp.com
TimoRozendal
Post by TimoRozendal » Sat Nov 07, 2015 9:42 am
all orders of the second run have been shipped!
waiting list is now open for the third...
flab
Post by flab » Sat Nov 07, 2015 10:01 am
lots of ssm2044 out there - maybe you found a nice place that sells them on a good price ?
TimoRozendal
Post by TimoRozendal » Sat Nov 07, 2015 10:43 am
flab wrote:lots of ssm2044 out there - maybe you found a nice place that sells them on a good price ?
you can buy them tested from me for 25 each, I buy them for about 20-22 each
Synthiak
Post by Synthiak » Mon Nov 09, 2015 2:25 am
I would be interested in a PCB + Panel.
Catfish
Post by Catfish » Mon Nov 09, 2015 4:58 am
Hi,
I would like one PCB, with panel if possible, without chip.
Roel
acilator
Post by acilator » Tue Nov 10, 2015 6:26 am
One set for if it's still possible
PCB + Panel + Chip SSM2044
mbroers
Post by mbroers » Tue Nov 10, 2015 10:18 am
id be interested in a full set too, if there is another run :)
grenert
Post by grenert » Tue Nov 10, 2015 9:11 pm
I'd be interested in the PCB set if you do another run.
Cablebasher
Post by Cablebasher » Tue Nov 17, 2015 7:26 am
Hey guys,
Did people use MICA caps for 15pf and 820pf as per Foniks Bom?
They seem super expensive?
Cheers.
TimoRozendal
Post by TimoRozendal » Tue Nov 17, 2015 7:46 am
Cablebasher wrote: Did people use MICA caps for 15pf and 820pf as per Foniks Bom?
nah, he used them because he had them lying around, poly film should be fine.
esp the 15pF is not that important, this is just for preventing oscillation of the opamp, I think I even used a ceramic capacitor
for the 820pf I used a polypropylene (evoc pfr5)
plasnu
Post by plasnu » Sun Dec 06, 2015 4:13 pm
grenert wrote:I'd be interested in the PCB set if you do another run.
Meetoo
TimoRozendal
Post by TimoRozendal » Wed Dec 09, 2015 11:23 am
ok, third run is ready to go, pm's sent
a possible fourth run will feature the last couple of wooden panels that I have (5), after that I will transition to pcb material if there is still interest
TimoRozendal
Post by TimoRozendal » Tue Dec 15, 2015 3:51 am
and... all orders that have been paid for are out the door!
happy building!
mistahad
Post by mistahad » Fri Dec 25, 2015 12:50 pm
interested in pcb and chip :)
humax5600
Post by humax5600 » Sat Dec 26, 2015 7:27 am
I´m interested in 1x PCB Set + 1x PCB Front-Panel + 1x SSM Chip
HipDestroyer
Post by HipDestroyer » Mon Dec 28, 2015 4:46 am
I'd likethe full package as well. When/if it becomes available :-)
Conjure
Post by Conjure » Mon Dec 28, 2015 9:25 am
Interested in the full set if/when it becomes available again. Thanks!
jackmattson
Post by jackmattson » Mon Dec 28, 2015 10:42 am
PCB + WOOD Panel + Chip SSM2044
antf4rm
Post by antf4rm » Mon Dec 28, 2015 11:26 pm
Count me in for a full set please!
TimoRozendal
Post by TimoRozendal » Tue Dec 29, 2015 3:50 pm
Please note: Bom and build doc pdf attached to first post is updated!
thorncore
Post by thorncore » Tue Dec 29, 2015 7:47 pm
1 full set of pcb + panel + chip in the next run please :tu:
volpone
Post by volpone » Sun Jan 03, 2016 3:56 pm
Count me in for PCB set + chip
with the next run
Thanks V
quanty37
Post by quanty37 » Tue Jan 05, 2016 4:26 am
I would be in for a PCB + Chip as well, especially if it could be combined with the steiner parker filter shipment.
