[NEW] Serge Resonant EQ for Euro by R*S
moket808
Post by moket808 » Tue Jul 03, 2018 5:13 am
Hi,
when the 4U version will be available again please ?
cheers
XAXAU
Post by XAXAU » Thu Oct 04, 2018 7:04 am
My 411Hz band is still dead. Switched out caps, resistors and op-amps. Now what?
Sleipnir
Post by Sleipnir » Thu Oct 04, 2018 11:46 am
XAXAU wrote:My 411Hz band is still dead. Switched out caps, resistors and op-amps. Now what?
I would reflow everything. Use a magnifier both to inspect, and while soldering.
Something like this (amazon link)
Multi Grooves
Post by Multi Grooves » Fri Oct 19, 2018 1:29 pm
I'm thinking a doing this build (or just buy a couple of Happy Nerding 3 band para EQa) but I have a few questions:
It has x2 INs and x2 OUTS, can this be used as a pseudo stereo unit?
Have any of you built the break out box for getting the individual bands? IF so, how useful is it/how do you use them?
I would like to be able to use the module almost like a final EQ for tweaking bits here and there subtly as well as for fucking shit up, can it do these things?
TiA
...but Cynthia, my Daddy never had a heath kit..
Multi Grooves
Post by Multi Grooves » Mon Oct 22, 2018 10:33 am
Hello? Anyone home?
Leverkusen
Post by Leverkusen » Mon Oct 22, 2018 4:29 pm
The 2 x INs are mixed together, the 2 x OUTs are the even and uneven bands separeted - so you can get pseudo stereo out of it but not process a stereo signal through it.
I have not built a break out box for it, but read somewhere that those who have do not use it very much. I also did not keep the Make Noise Fixed Filter because I did not use the single outs. Processing them with, say, individual delays might be fun, but who has that many delays...
I would not use a resonating EQ as a final EQ on anything. It's not subtle and the bands are not acting independent from each other.
I hope this helped.
Sleipnir
Post by Sleipnir » Mon Oct 22, 2018 11:22 pm
Leverkusen wrote:I would not use a resonating EQ as a final EQ on anything. It's not subtle and the bands are not acting independent from each other.
You say that like it's a bad thing. :guinness:
Leverkusen
Post by Leverkusen » Tue Oct 23, 2018 1:51 am
Sure, it actually is a good thing, much of what the resonant EQ is about for me. But as a final EQ to 'subtly tweak bits', it would not be my first choice, if any.
Multi Grooves
Post by Multi Grooves » Tue Oct 23, 2018 3:13 am
Is this a universal view i.e. It is not great for rolling off a dB or two at a problematic freqency?
There are comb outs as well as outputs. How do they differ?
I'm wondering would I be better just grabbing a Happy Nerding parametric 8hp wonder, the Tritone instead if it, too only works in mono?
:hmm:
Nice one Bayer(?)!
Leverkusen
Post by Leverkusen » Tue Oct 23, 2018 5:41 am
I misunderstood your previous post. The two OUTs are just the same - the COMB outputs are representing the two columns of bands and can be used for a (simple) pseudo stereo.
The TriTone is great to just sculpt the sound in a more clean way as in final EQ. It is mono too and sounds much cleaner. Plus it does a nice overdrive if you push it harder.
I use the Serge to color the sound and the Happy Nerding as a clean EQ. Mind that both do not allow to adjust the bandwith while the TriTone allows to adujst the freqeuncy - the resonant EQ is fixed.
How about MI Shelves?
oootini
Post by oootini » Tue Nov 20, 2018 4:08 am
Hi gang,
Couple of questions about this build:
1. Is the feedback circuit completely built into the design? My feedback section seems to do nothing at all, and overall, I cannot get this this unit to howl. Perhaps I misunderstand the feedback section - is it fully internally patched? or does it expect an output to be patched to the input, with the pot controlling the feedback loop?
2. Related to the above: is there a circuit schematic available for this build?
Triglav
Post by Triglav » Tue Nov 20, 2018 4:14 am
oootini wrote:Hi gang,
1. The feedback doesn't need any patching. Make sure that the switch isn't set to inverted mode.
2. You can find the schematic here (without the feedback section unfortunately): http://web.archive.org/web/201802010410 ... reseq.html
oootini
Post by oootini » Tue Nov 20, 2018 5:41 am
Ok thank you! Will investigate.
oootini
Post by oootini » Thu Nov 22, 2018 7:45 pm
Ha. Missed a couple of 100k resistors like somebody else up-thread. I must have ordered a BOM that was missing 100k resistors.
Anyway. All good now. Spent the last hour just putting a single kick drum through this thing It positively sings. :omg:
pynchy
Post by pynchy » Tue Mar 12, 2019 8:23 am
How much of a difference do the 1% resistors make here compared with say 5%?
B0bcat
Post by B0bcat » Wed Mar 13, 2019 12:03 pm
approximately 4% :hihi:
pynchy
Post by pynchy » Thu Mar 14, 2019 7:55 am
B0bcat wrote:approximately 4% :hihi:
Hahha :yay:
ishi
Post by ishi » Thu Mar 14, 2019 9:45 am
and everybody knows, 4% equals more organic :lol:
Futuresound
Post by Futuresound » Mon Mar 18, 2019 2:08 am
Does anyone make something like a Res EQ with voltage control over each band?
Leverkusen
Post by Leverkusen » Mon Mar 18, 2019 3:05 am
Futuresound wrote:Does anyone make something like a Res EQ with voltage control over each band?
Do you think of something like the Verbos Bark Filter Processor?
Tumulishroomaroom
Post by Tumulishroomaroom » Mon Mar 18, 2019 4:33 am
The Bark isn't resonant though. Maybe the Addac 601 ?
I just got one of these (R*S Res EQ) and damn it's fantastic. a very nice complement to the Bark, very very fun to tweak and keep on the edge of self oscillation.
instagram
soundcloud
dc11 - electron out on Cosmic Wave Records.
Permette
Post by Permette » Mon Mar 18, 2019 7:30 am
Yes,
- + individual bands out.
- + 8 in mixer/processor.
Cheers !
Futuresound
Post by Futuresound » Mon Mar 18, 2019 10:25 am
Permette. Cool! How do I get one?
Permette
Post by Permette » Mon Mar 18, 2019 10:53 am
Futuresound wrote:Permette. Cool! How do I get one?
Well, i don't know.
I haven't finished mine yet.
But you could try as I do, building it with a CGS202 a CGS04 and ten Thomas Henry / Fonitronik crossfader PCBs (in place of the frequency pots).
aragorn23
Post by aragorn23 » Fri Aug 30, 2019 2:53 am
Hey all, possibly a silly question but are there any cheaper opamp options for this? Would using something like an 072 work at all?
