[ORDER] Euclidean Circles - LEDs with rhythm
Moderators: lisa, Kent, Joe.
stentoe
Populated PCB?
Post by stentoe » Sat Feb 17, 2018 3:42 am
Hi av500,
Can you supply a price for the populated pcb? Ive made a bit of a mess of mine.
av500
Re: Populated PCB?
Post by av500 » Sun Feb 18, 2018 2:27 am
stentoe wrote:Hi av500,
email me please
jimboburgess
Post by jimboburgess » Wed Feb 28, 2018 2:04 pm
Swyndger wrote:Today the last missing part of my Euclidean Circles arrived: The WS2811 for the encoder leds. I ordered 5 for 83 cent each ...
Oh no!
83 cent is for 10! I accidently ordered 50 chips. :doh: Now I have 47 left. Shall I build 15 Euclidean Circles more? If anyone of you needs a chip I would send it to you for the shipping costs, but I think it is more expensive send a letter with three chips through europe, then ordering fifty chips from china ... :hmm:
Hmm I'm in the same boat what to do with a bunch of extra chips and leds I wonder.
n82558
Post by n82558 » Mon Mar 05, 2018 4:46 pm
Does anyone know the value of C1 and SJ1 on the bottom board?
jimboburgess
Post by jimboburgess » Mon Mar 05, 2018 5:50 pm
Working with a rev 1.9a board there seems to be many missing components. I think i followed everything correctly but when I power it up nothing happens. Seems like there is a short on the 5v rail, where should i probe to find the short?
Found the problem I think I used a AP7361C LDO voltage regulator with ground on pin2. The one called for has ground on pin1. blerg.
https://www.mouser.com/ds/2/115/AP7361C-775034.pdf
vs.
http://www.advanced-monolithic.com/pdf/ds1117.pdf
n82558
Post by n82558 » Mon Mar 05, 2018 9:26 pm
Should my encoders be lighting up without a clock? I’ve only soldered a few of the leds so far but they seem to be working, but the encoders aren’t doing anything. Anywhere in particular I should check for issues? I’ve given the board a once over but everything looks fine.
jimboburgess
Post by jimboburgess » Mon Mar 05, 2018 10:46 pm
n82558 wrote:Should my encoders be lighting up without a clock? I’ve only soldered a few of the leds so far but they seem to be working, but the encoders aren’t doing anything. Anywhere in particular I should check for issues? I’ve given the board a once over but everything looks fine.
The 2811s ICs control the encoders, double check they are soldered up correctly
av500
Post by av500 » Tue Mar 06, 2018 4:24 am
n82558 wrote:Does anyone know the value of C1 and SJ1 on the bottom board?
ignore parts not explicitly mentioned in the BOM
av500
Post by av500 » Tue Mar 06, 2018 4:25 am
the encoders are at the end of the LED chain, so unless you have all the LEDs working they wont light up. for a quick test you can remove the panel and bridge the top two rows of the 8 pin header, this will send the signal straight to the WS2811 chips (dont bridge the bottom rows as that connected 5V to GND)
wrave
octopart
Post by wrave » Thu Mar 29, 2018 4:06 pm
The mouser cart is not a complete BOM and a whole bunch of SMD passive components have been out of stock lately.. so I brought the 1.9 list over to Octopart. av500, I would recommend that you copy it, check my work, and provide a link to your own.
https://octopart.com/bom-tool/xtklnXjy
av500
Re: octopart
Post by av500 » Thu Mar 29, 2018 4:14 pm
wrave wrote:The mouser cart is not a complete BOM and a whole bunch of SMD passive components have been out of stock lately.. so I brought the 1.9 list over to Octopart. av500, I would recommend that you copy it, check my work, and provide a link to your own.
sigh, yes, keeping a Mouser cart current is a full time job. will redo it next week.
your list looks good, but remove the last item, the 2x4 male SMT header comes with the PCB set.
av500
Post by av500 » Sat Apr 14, 2018 3:59 pm
Mouser cart updated, I'm sure they will find something to go out of stock tomorrow...
ebardie
Low output voltage
Post by ebardie » Tue Jun 12, 2018 2:50 pm
I'm only getting about 0.5v outputs. Should be ten times higher. :eek: Any ideas where to look? Output signal isn't terribly clean looking either.
av500
Re: Low output voltage
Post by av500 » Tue Jun 12, 2018 2:54 pm
ebardie wrote:I'm only getting about 0.5v outputs. Should be ten times higher. :eek: Any ideas where to look? Output signal isn't terribly clean looking either.
do you have 5V at the 5V test pad?
av500
post a good resolution picture of the main PCB
ebardie
Post by ebardie » Tue Jun 12, 2018 3:41 pm
Here they are: https://photos.app.goo.gl/yvN6Q2gRuXiTe7sf6
ebardie
Post by ebardie » Tue Jun 12, 2018 3:47 pm
4.745V
ebardie
Post by ebardie » Tue Jun 12, 2018 3:54 pm
IC6 was round the wrong way....
Idiot DIYer strikes again o_O
Apologies for wasting your time.
And thanks again for such a cool module :D
av500
Post by av500 » Fri Oct 05, 2018 2:37 pm
Added V2 build guide! sale starts soon, stay tuned!
av500
Post by av500 » Fri Oct 05, 2018 2:41 pm
video about V2 features:
av500
Post by av500 » Sat Oct 06, 2018 4:41 pm
If you bought a v2 PCB set at Dutch Modular Fest, please contact me!
antiehdas
Post by antiehdas » Tue Oct 23, 2018 8:07 pm
Hello !
just ordered ec v2 and expander , anybody has a mouser basket ?
RogueWarrior
Post by RogueWarrior » Wed Nov 07, 2018 9:34 am
v1 Mouser cart: https://www.mouser.de/ProjectManager/Pr ... 99414397ee
v2 Mouser cart: to be done
av500
Post by av500 » Thu Nov 08, 2018 2:26 am
RogueWarrior wrote:v1 Mouser cart: https://www.mouser.de/ProjectManager/Pr ... 99414397ee
v2 cart, please review:
https://www.mouser.de/ProjectManager/Pr ... 40aaf3e4fa
RogueWarrior
Post by RogueWarrior » Sun Nov 25, 2018 5:53 pm
Is there a part number for the switches in the Six Switches unit?
