[ORDER] Euclidean Circles - LEDs with rhythm
av500
Post by av500 » Mon Nov 26, 2018 12:36 am
RogueWarrior wrote:Is there a part number for the switches in the Six Switches unit?
they are subminiature ON-OFF switches with 5mm panel hole diameter.
e.g.
https://www.thonk.co.uk/shop/sub-mini-toggle-switches/
https://www.ebay.com/itm/131171342660
Bamboombaps
Post by Bamboombaps » Thu Dec 20, 2018 7:07 pm
I'm debugging a v1 , the encoders seem to think they are constantly being pressed.
The module switches from safe mode to non safe without pressing all the buttons as directed in the manual.
There are one or two steps active on the circles but I can't change them. The outputs correspond to those that are active so they seem to be working ok.
The middle encoder does Change colour and function (I assume) when it is turned but there's no change to the output
Vladimir advised to check the voltage divider but these resistors seem ok
av500
Post by av500 » Fri Dec 21, 2018 3:00 am
Bamboombaps wrote:I'm debugging a v1 , the encoders seem to think they are constantly being pressed.
so, the switches are pullep up to 5V and when you press them they connect to GND. can you check the voltage level at the junction of R14/R15, R16/R18 or R17/R19. can you please also check you did not mix up the 10k and the 5.6k?
RogueWarrior
Post by RogueWarrior » Fri Dec 21, 2018 8:29 am
Okay I was able to get switches from Digi-key,
However, on Ring 3 only half of LED's are lighting, but I am getting full voltage across ALL LED's. I have Checked, and Re-Checked, but nothing is working
I sad Panda :sad:
av500
Post by av500 » Fri Dec 21, 2018 8:34 am
RogueWarrior wrote:Okay I was able to get switches from Digi-key,
I sad Panda :sad:
the LED control signals are all connected in a chain, so check the last working and first non working LED for correct soldering.
RogueWarrior
Post by RogueWarrior » Fri Dec 21, 2018 9:50 am
HA success!!!
I replaced TWO (2) LED's, and we have full Ignition!
Sad Panda now HAPPY PANDA!! :sb:
Now on to Frames DIY
Bamboombaps
Post by Bamboombaps » Sun Dec 23, 2018 9:29 am
im pretty sure the 5k6 are correct but maybe im missing something. the pads that are to be left unpopulated are disconcerting, maybe ive made a mistake somewhere. FYI the links that dont look connected are on the other side .
av500
Post by av500 » Tue Dec 25, 2018 5:39 am
PCB looks OK to me, so I'm a bit puzzled as to why it does not work...
Radium
Six Switches
Post by Radium » Thu Dec 27, 2018 6:40 am
Edit: i`ve see the upper post, sorry...
Hey AV500 :)
What switches do i need for "Six Switches"? SPDT ON - OFF?
Thnx ;)
Bamboombaps
Post by Bamboombaps » Sun Dec 30, 2018 12:05 pm
av500 wrote: can you check the voltage level at the junction of R14/R15, R16/R18 or R17/R19. can you please also check you did not mix up the 10k and the 5.6k?
R14/R15 0v
R16/R18 0v
R17/R18 0v
also the 5v pad only reads 4.45ish
av500
Post by av500 » Sun Dec 30, 2018 12:51 pm
ok, and what is the level with a switch pressed?
Bamboombaps
Post by Bamboombaps » Sun Dec 30, 2018 12:59 pm
av500 wrote:ok, and what is the level with a switch pressed?
R14/R15 2.84v
R16/R18 2.84v
R17/R18 2.84v
av500
Post by av500 » Sun Dec 30, 2018 1:23 pm
hmm, your 5V should be 5V, can you remove the panel and check if you get 5V properly? and around 3.3V when the switches are pressed?
Bamboombaps
Post by Bamboombaps » Wed Jan 09, 2019 6:07 pm
I took the panel off and tried another case which seems to give me 4.8v on the 5v pad and 3.28v on the test pads but still the same behaviour.
Which pad /leg of the encoder should I be measuring ?
av500
Post by av500 » Mon Jan 14, 2019 4:38 am
Bamboombaps wrote:I took the panel off and tried another case which seems to give me 4.8v on the 5v pad and 3.28v on the test pads but still the same behaviour.
so without the panel you have 4.8V and 3.28V which is OK, but with the panel you only measure 2.84V which is too low. so I think you have a light short on the panel that pulls the 5V down. can you please measure the resistance between 5V and GND on the panel alone?
Bamboombaps
Post by Bamboombaps » Mon Jan 14, 2019 3:13 pm
Can you tell me which pins to measure between based on my pic?
12
34
56
78
av500
Post by av500 » Mon Jan 14, 2019 3:14 pm
56 ist 5V, 78 ist GND
synthpriest
Post by synthpriest » Mon Jan 14, 2019 4:14 pm
Is the DIY version sill available for ordering? :guinness:
av500
Post by av500 » Tue Jan 15, 2019 4:28 am
of course, vp (at) vpme (dot) de
corrupt_reverend
Post by corrupt_reverend » Wed Feb 13, 2019 10:28 pm
Still accepting orders for Euclidian Circles v2 and switches?
I sent an email almost a week ago, and haven’t heard back.
av500
Post by av500 » Thu Feb 14, 2019 3:43 am
sorry missed that mail :) just replied - and yes, PCB+panel sets are still available
frequenzteiler
AMS1117 vs LD1117
Post by frequenzteiler » Fri Mar 01, 2019 4:26 am
am i guessing right that its not crucial to exchange the 1A AMS1117 with the 0.8A LD1117 thats on the mouser bom ?
the module is not eating up all those 800mA even with all leds at full brightness ? is it ?
av500
Post by av500 » Fri Mar 01, 2019 4:41 am
no, it does not need all 800mA :)
Silver
Post by Silver » Fri Mar 08, 2019 4:26 pm
Anyone know where else we can find the encoders? looks like sparkfun no longer has them in stock.
Ernst Bitter
LED problem
Post by Ernst Bitter » Thu Mar 21, 2019 7:36 am
Hi,
Ive built a V2 and after changing several LEDs all LEDs are illuminated but some are not fully illuminated (see picture; the wire is a bridge because I killed one solder pad by soldering out on LED)
I already changed some of them to see if they are broken but it had no effect.
Maybe somebody has an idea what I could do about it?
Thank you[/img]
