[ORDER] Euclidean Circles - LEDs with rhythm
Nutritional Zero
Re: [ORDER] Euclidean Circles - LEDs with rhythm
Post by Nutritional Zero » Tue Mar 09, 2021 1:55 pm
Hi all, I bought a "factory" EC and perhaps this is my misunderstanding but I am observing something that doesn't seem right:
1. Module boots up with rainbow LEDs.
2. All LEDs subsequently flash red, blue, green.
3. Twisting any encoder causes the LEDs to turn white.
4. Long pressing any encoder appears to do nothing. No change in the red, blue, green, blinking.
5. Pressing the F button causes the top circle to flash white, then the middle, then the bottom continuously until F is tapped again.
6. Long-pressing F appears to do nothing.
I've tried pressing holding the middle encoder on setting 16 to try to reset all setting, but there is no feedback from the module and circle 1 and 3 continue flashing red, blue green even while circle two is at sixteen and encoder two is held.
av500
Post by av500 » Wed Mar 10, 2021 1:54 am
Hi there,
sorry for that, the unit seems to have shipped in production test mode.
to exit that:
- turn the three encoders so all rings are white
- press the three encoders so that the buttons light white
- press the F-button
- wait 3s
Nutritional Zero
Post by Nutritional Zero » Wed Mar 10, 2021 9:43 am
Thanks so much!
av500
Post by av500 » Wed Mar 10, 2021 9:46 am
sorry again 🙂
orukusaki
Post by orukusaki » Wed Apr 07, 2021 4:07 am
Received the kit from SynthCube and assembled over the Easter weekend, great fun!
It worked almost perfectly on first power-up, just had to touch up one of the LED pads
Only slight complaint is the kit didn't include any nuts for the jacks, I've got a bunch spare though so it's not a problem.
I would encourage anyone who's unsure about the SMD soldering to give it a go, it's not as hard as it looks.
Also... I'm new here... hi :)
moegl
Post by moegl » Thu Apr 08, 2021 7:15 pm
Is there any sort of way to CV the pattern? Maybe just a trigger signal to change? This module seems amazing for a performance, but I'd like to have some CV control over this. This would replace my Zularic Repetitor if the Euclidean Circles can receive CV.
mosorensen
Post by mosorensen » Thu Apr 08, 2021 7:23 pm
No CV in at all. That's its main limitation.
I believe PNW and Disting provide CV control over Euclidean Rhythms.
pjbulls
Post by pjbulls » Fri Apr 09, 2021 1:50 am
Also DNIPro DOT. Made my own version of that, it's awesome.
av500
Post by av500 » Fri Apr 09, 2021 1:52 am
well, for the kit contents, that's under Synthcube control. I won't comment on the choice of knobs ;)
