Random* Source BOM's for various Builds - both 4U and Euro
lcf
Post by lcf » Mon May 09, 2016 10:05 am
Does somebody have a BOM for NCOM please?
lcf
Post by lcf » Mon May 09, 2016 12:23 pm
Here is my Mouser cart for euro DSG: https://www.mouser.fr/ProjectManager/Pr ... 3a547e2afd
It does not include:
2x SIL header 4pol 855-M20-9770442
6x SIL header 5pol 855-M20-9990545
4x Switches SPDT Expo 108-0044-EVX
Jacks and 50k pots that i order from Thonk and Tayda.
listentoaheartbeat
Post by listentoaheartbeat » Thu May 19, 2016 6:28 am
Mouser project for the Euro NCOM:
http://www.mouser.com/ProjectManager/Pr ... 15573ed46e
I have not ordered yet, so there is no guarantee this is 100% OK. Let me know if you spot any issues.
Notes:
  • Includes expensive 0.1% tolerance resistors for R3, R10, R12, R21, R22, R23, R24 (249k) and R20 (499k). Replace with 1% if you are on a budget.
  • Includes WIMA caps for CX and bypass positions.
  • Does not include pots, jacks, headers/sockets!
listentoaheartbeat
Post by listentoaheartbeat » Thu May 19, 2016 6:58 am
Dogma wrote:https://au.mouser.com/ProjectManager/Pr ... dca4c4a741
Complete MOuser BOM for Res EQ
This project has both 7x C0G and 7x WIMA .01uF as bypass caps in it.
Zealot Vague
Post by Zealot Vague » Thu May 19, 2016 9:04 am
I'm piling up an R*S basket at TME and I can't find anything named precisely CD4520BE; the closest is CD74HC4520E. The pinout, functional diagram and truth table look like they match the CD4520BE datasheet up on Mouser but it's mostly above my head. How many letters around the number do I need to get right? gaaah :help:
richard wrote:Don't listen to anything. Don't drink beer, don't smoke weed, don't sleep. Have no ideas whatsoever. Make some tea. Start with a sine wave.
the bad producer
Post by the bad producer » Thu May 19, 2016 10:19 am
If you look at the datasheet you'll note that the 74HC runs on a supply voltage of 2V to 6V, CD runs at 3V to 18V. ie 74HC runs at low voltage, Ken Stone has useful info here:
http://www.cgs.synth.net/help.html
Looks like TME don't have anything suitable. :sadbanana:
Zealot Vague
Post by Zealot Vague » Thu May 19, 2016 12:30 pm
the bad producer wrote:Ken Stone has useful info here:
Headshot. Also thanks.
ZZ Ardoz
Post by ZZ Ardoz » Mon May 23, 2016 12:39 pm
listentoaheartbeat wrote:Mouser project for the Euro NCOM:
Notes:
Thanks so much for this
Would these cheaper 0.1% resistors be an acceptable substitute?
http://www.mouser.com/ProductDetail/TE-Connectivity-Neohm/YR1B499KCC/?qs=sGAEpiMZZMsPqMdJzcrNwnowNwQBGLxcPzUrk%2frKjGw%3d
Waz
Wiggling with Scurvy
Post by Waz » Mon May 23, 2016 1:01 pm
What size standoffs should I use for the EuroSerge? 11mm?
listentoaheartbeat
Post by listentoaheartbeat » Mon May 23, 2016 3:33 pm
Notes:
Good find, but only for R20. The 249k version of that resistor is not in stock (for the other positions).
listentoaheartbeat
Post by listentoaheartbeat » Mon May 23, 2016 3:37 pm
Waz wrote:What size standoffs should I use for the EuroSerge? 11mm?
Which headers / pin strips are you using?
lcf
Post by lcf » Mon May 23, 2016 3:46 pm
Yes 11mm
Edit: I built my NCOM with these parts and it works perfectly. A few things are missing like pots, jacks, SIL pins, but the essential is there.
https://www.mouser.fr/ProjectManager/Pr ... 1838e20d32
Waz
Post by Waz » Tue May 24, 2016 6:49 pm
Having a hell of a time finding 5mm 2mA LEDs that are somewhat bright. I ordered these and they fucking suck;
http://www.mouser.com/Search/ProductDet ... -HLMP-4700
http://www.mouser.com/Search/ProductDet ... -HLMP-4719
They're weak as hell.
:help:
lcf
Post by lcf » Tue May 24, 2016 9:09 pm
Waz wrote:Having a hell of a time finding 5mm 2mA LEDs that are somewhat bright. I ordered these and they fucking suck;
:help:
You can attenuate the brightness with a higher value for RLED resistors and test it on a breadboard with a 5V source (from a jack for example).
Edit: I think that I did not understand correctly. :hihi:
This model is powerfull but yellow is not disponible at Mouser for the moment:
http://www.mouser.fr/Search/ProductDeta ... 113LSYCKJ3
http://www.mouser.fr/Search/ProductDeta ... 113LSECKJ3
thetwlo
Post by thetwlo » Tue May 24, 2016 10:14 pm
:help:
for which build?
lcf
Post by lcf » Tue May 24, 2016 10:34 pm
:help:
for which build?
SSG and DSG
Waz
Post by Waz » Tue May 24, 2016 11:05 pm
:help:
Those exact LEDs are in my SSG. I was just hoping someone had another source for brighter LEDs.
:deadbanana:
*edit - looking for a pair for my DSG.
Waz
Post by Waz » Thu May 26, 2016 8:35 am
Looked everywhere for the yellow. I guess I'll have to wait for the duration of the lead time. If anyone has a set (red and yellow Kingbright), I'll pay double the price and shipping.
listentoaheartbeat
Post by listentoaheartbeat » Thu May 26, 2016 9:15 am
Waz wrote:Looked everywhere for the yellow. I guess I'll have to wait for the duration of the lead time. If anyone has a set (red and yellow Kingbright), I'll pay double the price and shipping.
I'd look for amber, not yellow.
lcf
Post by lcf » Thu May 26, 2016 11:48 am
108-0042-EVX Moutain switches are available again!!
lcf
Post by lcf » Thu May 26, 2016 12:15 pm
I have missing notions about trimmers.
I found the brightness that I like for my leds but it's not exactly the same on each led, so trimmers would be handy to set it perfectly but...
I'm not sure, does a trimmer go from to 0 resistance to the resistance announced? :hmm:
I'm affraid to burn the leds setting the leds brightness with trimmers...
ZZ Ardoz
Post by ZZ Ardoz » Mon May 30, 2016 3:50 pm
Notes:
Thanks - ended up with these for a little less http://www.mouser.com/ProductDetail/Vis ... eetw%3d%3d
Waz
Post by Waz » Mon Jun 06, 2016 8:04 am
LEDs are back in stock!
nikvudu
Post by nikvudu » Thu Aug 25, 2016 12:04 am
Anyone got one for the VCM? thanx :mrgreen:
thelizard
in it for the money
Post by thelizard » Sun Sep 11, 2016 5:49 pm
Notes:
The Zeners on this cart are too thick for the PCB holes. Also, there's not enough room to squeeze the 220pF WIMA cap in between the resistor and socket without floating and angling it. This is difficult to do, as the legs are really short.
