[ORDER] ZeroScope, 6hp scope that's almost not even there
WarpHead
Re: [ORDER] ZeroScope, 6hp scope that's almost not even there
Post by WarpHead » Tue Nov 10, 2020 2:06 pm
It says v1.2 at startup. Does that mean anything on the hardware side as well?
Don't believe the hype.
WTB: Schippmann Omega-Phi Mk2.
av500
Post by av500 » Tue Nov 10, 2020 2:58 pm
the hardware is the same, but sadly, software v1.2 is an early one before I added a bootloader that allows for easy software updates.
WarpHead
Post by WarpHead » Tue Nov 10, 2020 4:49 pm
Hmmm, alright. So I guess even updating via wav is not a viable route?
Appreciate the quick and effective answers, by the way! Zeroscope has been an awesome companion the past years! :tu:
av500
Post by av500 » Wed Nov 11, 2020 3:37 am
it's the bootloader that enables updating via WAV
tdallas
Post by tdallas » Thu Nov 19, 2020 5:58 pm
av500 wrote:
Sat Apr 04, 2020 1:05 pm
I just uploaded latest v1.7 here: https://drive.google.com/drive/folders/ ... sp=sharing
Hi. Please forgive me if I may have missed this info, but what has changed in the latest v1.7 (mine is on v1.6)?
batank
Post by batank » Tue Feb 09, 2021 6:00 am
Bumping to ask about details on firmware binaries to update via STLINK for those like myself stuck on pre-bootloader versions.
Edit: failed properly search, however having trouble detecting the STM device on the zeroscope 1.1 board using two different stm clones. :despair:
av500 wrote:
Tue Apr 17, 2018 4:26 am
for updates via STLINK, see the guide here:
and use the file zs_combo_v1.6.bin
av500
Post by av500 » Wed Feb 10, 2021 2:56 am
make sure you check "connect under reset"
batank
Post by batank » Wed Feb 10, 2021 3:23 am
Thanks for the reply! Checked, and just successfully detected and flashed... my original euclidean circles to v1.9. Good signs, so just in case, I reflowed the ebug header on the zeroscope and verified continuity from the header to the stm but still no target found. I have also tried powering from both the USB STLINK and my eurorack supply. Maybe blame the STLINK clone for the inconsistency? :confused: Will report back if I have any breakthroughs.
Harko
Post by Harko » Mon Feb 15, 2021 7:49 am
Is there an approximate date on when the DIY kit will available again?
I've tried looking online shops for a kit, but it seems out of stock everywhere.
synthcube
you will be assimilated
Post by synthcube » Mon Feb 15, 2021 9:34 am
we've got some going in to stock this week
facebook: https://www.facebook.com/2SynthCube
synthcube webstore www.synthcube.com/cart
music from outer space: www.musicfromouterspace.com
blacet research: www.blacet.com
MOTM DIY Analog Synthesizers: www.motmsynthesizers.com
music from outer space euro smt: www.mfoseuro.com
Harko
Post by Harko » Tue Feb 16, 2021 8:27 am
Good to know!
duallain
Post by duallain » Sun Mar 21, 2021 10:29 pm
Bought the kit from synthcube. Built the kit today, and it looks so good. Was easy to get everything connected together, and the screen looks fantastic.
One problem, it seems like I'm in production test mode. Firmware v1.7. I tried to follow the instructions on synthcube's product page of plugging a clock signal into ext input, and clicking/turning the knobs but no dice. Is there anything I can check to see what the problem might be? (I'm guessing the encoders are soldered wrong, or not connected to the circuit well in some way, but any hints to get started are appreciated.)
EDIT: It seems like IC2 had a bridged solder connection. Cleaned that up and was able to get out of prod test mode.
mario308
Post by mario308 » Mon Apr 05, 2021 9:46 pm
I just bought my kit from Synthcube and my module is stuck in "Prod Test" on bootup. I followed the steps on Synthcube's page and it still will not exit that mode. I doublechecked all my solder joints and did continuity tests from both encoders click, Channel A, Channel B, EXT in pin 3 to their respective pins on IC7. I also doublechecked IC2 and its neighboring resistors and capacitors according to the schematic and it all looks well.
It seems like the encoder clicks are responding since holding encoder 1 while turning it on does change the encoder settings and holding encoder 2 while powering up does go into firmware update mode.
I also tried to re-flash the 1.7 firmware just in case. It does start to update when I send the .wav file to the T input and there is a progress bar that shows but when the wav file is finished, the 4th LED never lights up on the screen.
Any ideas on this? Is there a specific way the encoders need to be pressed and turned and is there a range of how fast the clock pulse should be?
av500
Post by av500 » Tue Apr 06, 2021 1:06 am
there is no feedback on when you turn and press encoders, so make sure you do each at least 5 times
also, sorry again for shipping in this state, this is the firmware that normally only goes on production units, not the DIY kit, but its just a one letter typo 😕
mario308
Post by mario308 » Sat Apr 10, 2021 2:50 pm
Quick Question. Looking at the schematic it looks like P$3 and P$2 are connected for inputs 1 and 2. Does this mean if nothing is connected to input 1 and 2 ground will show at the input?
pjbulls
Post by pjbulls » Sun Apr 11, 2021 5:09 am
Yes, the jacks are switched to ground so that if nothing is connected they will show a stable 0V. This isn't needed though since the inverting op-amp should pull the input into its virtual ground anyway, it's more something you'd do with a non-inverting buffer (when not using a pull-down).
rocknrolla
Post by rocknrolla » Tue Apr 13, 2021 4:36 am
Is it normal that Zeroscope makes sound which i can hear at like 1 meter distance? It only happens when data is passing though the module. It's not really loud but that's the only module in my whole rack which makes noise.
av500
Post by av500 » Tue Apr 13, 2021 5:04 am
Hi there,
I have never experienced that, nor have I heard it reported elsewhere... the only explanation I can think of is that some components on the OLED display react in some way to what is displayed since the current draw is related to how many pixels are ON / WHITE.
pld
Post by pld » Tue Apr 13, 2021 5:23 am
FWIW I have some o_C displays that emit noise depending on screen content. Some of them manage to project the sound quite effectively so it took me a while to localize it (but I've never dug deeper if it's the actual OLED, or some component).
av500
Post by av500 » Tue Apr 13, 2021 5:28 am
yeah, that's what I assume happens here too, these displays do have an internal DC/DC converter, so there is some switching action going on.
I never had it with the displays I buy or I'm too old to hear it ;)
