[Build Thread] Jasper, an EDP Wasp Clone
- Learning to Wiggle
I had a bad filter rotary also. Was a bit of a pain to swap, but fixed it right away.
Just pulled the trigger on the noise and XOR mod boards. My question is, where are you guys drilling the hole for the noise switch? Ideally id like to go just above the noise pot, along the line that connects the osc and the external in pot. A few resistors under there, but not a big deal. Any thoughts?
Also, got my mod boards all built and wired and realized i didnt have a 4070. Subbed a 4093 instead. Not bad, fairly close to the demo vids. then i found this:
https://electronicsclub.info/cmos.htm
if you scroll down to the first picture, there are several different logic functions with the same pinout. Gonna have to try a few and see...
I've got a vacuum desoldering station and it still didn't want to come out - the pins are tight. Ended up dismantling the switch in situ and pulling the pins one by one.goodrevdoc wrote:I had a bad filter rotary also. Was a bit of a pain to swap, but fixed it right away.
One day I'll get an avatar!
Yeah i had to do something similar. I bought the alphas from mouser and replaced with the same. If i build another, im definitely going to try the other kind, Lorlin maybe?gslug wrote:I've got a vacuum desoldering station and it still didn't want to come out - the pins are tight. Ended up dismantling the switch in situ and pulling the pins one by one.goodrevdoc wrote:I had a bad filter rotary also. Was a bit of a pain to swap, but fixed it right away.
- relggiwffum
- Common Wiggler
Soldering TR1 and TR2 transistors
We have the same issue here:grizzle wrote:Hey all,
The build guide says to solder in TR1 and TR2 bent over flush against the PCB to avoid any shorts but I noticed both transistors have been moved on the latest PCB. Do they still need to be installed bent flush or can they be soldered in without bending the legs now?
Alex
Anyone knows how to do it?
TIA
Jasper 3-D printed case
Hi! I just want to share my 3D printed case. It's printed on a Prusa I3 MK3 in several parts and afterwards glued together.
- Sunshine Jones
- Common Wiggler
- Contact:
I'm late to this party, but I've just about finished my build and am really enjoying how the Jasper sounds.
I have a question about the HOLD switch:
I wanted to use Hold Switch 1 and wired up the switch from the 2.2 BOM (Miniature Toggle Switch SPST ) as follows:
It doesn't seem to do anything. It is connected as illustrated here between the switch and a MTA-100 connector which fits onto a header. The wires show connection, so I believe they're ok. I have also checked to be sure I've connected it to HOLD 1 (and not hold 2.)
I assumed that this mod would allow for whatever note is played on the keyboard to be held, and it would sustain... This isn't happening.
Have I bungled the wiring? Or completely misunderstood something? Perhaps both?
Anyone else had trouble with the hold switch?
[quote="Sunshine Jones"]I'm late to this party, but I've just about finished my build and am really enjoying how the Jasper sounds.
Without checking the manual or ripping mine apart"again" , Ive built 2 by the way.
I have used both hold variants . Ive just checked on the machine itself. One mode should hold on a key press , the other should hold repeated triggers but only if repeat /sustain is clicked into repeat mode.
Repeating VCA envelope
I am not getting the VCA envelope to repeat, all else works correctly. Hold switch is wired to both hold functions and works correct for each Hold function. The 0meg pot for the VCA repeat/ sustain does not appear to be working. I can hear the VCA get to the sustain stage and there is a volume change before it goes into the decay stage as if there is no value for the sustain stage. NO repeat function when the VCA pot is in that position and the hold switch is engaged to Hold one. I will be checking the pot solder points tonight for the VCA.
Can someone help me out here with this problem and where else I might look on the board to solve this issue?
Technosaurus small wonders complete owner. 39U 19 inch rack width worth of euro rack. Electribes, Z1, Pro2, Casio sk-1,5,8 bent, VZ-1, VZ-8m, voices processors and vocoders, dozens of DIY devices and circuit bent creations.
On the tube channel same as username here.
Re: Repeating VCA envelope
Have you checked page nine component configuration notes R 172 and diode ?
Attached some photos of my slightly changed design of the Jasper enclosure that it slides into a desktop stand. More information and STL files on https://www.spillerphoto.com
- LED-man
- Super Deluxe Wiggler
- Contact:
After we have seen Behringers EDP wasp clone:
The EDP deluxe don’t have the VCO ENHANCED Mode.... but the Jasper has this function.
Jason still have a lot of Jasper pcbs for sale.
Behringers Clone costs 300€, the same amount like the Jasper pcb plus parts.
But you can modify the Jasper to your choice - trigger mod, envelope timing mod, midi (from Jason) LFO speed mod and more.
And if you don’t want the keybed, use a saw and cut the pcb.
You can control it by midi.
- diophantine
Actually Behringer has included the additional VCO mode, as well as every other mod on the Jasper, plus the panel layout.LED-man wrote:After we have seen Behringers EDP wasp clone:
So build a Jasper and support Jason & SDIY!
This honestly has me tempted to build another. Thorofon and Geneviève Pasquier used mine during their first US shows in Los Angeles last month, and it sounded awesome through the big PA!
- diophantine
I agree with people saying it's a clone of the Jasper. Behringer's Wasp: It has oscillator level and external signal pots between the oscillator controls, plus notch on the filter switch, plus the hold switch under the VCA envelope controls. Enhanced waveform (Gnat has this.) The waveform switches have an off position (original Wasp does). The Wasp Deluxe doesn't have these features. Jasper does.
You could argue that they just took all the best features and mods from all three Wasp variants like on the Jasper but when you look at it, the Behringer Wasp does seem to be a clone of Jason Lane's work, they copied the features of it, saved themselves some expensive development time.
Re: [Build Thread] Jasper, an EDP Wasp Clone
Hello Friends
First post here but have been stalking for years.
Just built a Japer kit, powered up and worked right away so im happy about that.
I have one question tho: it appears that the tuning for OSC2 zeros at roughly one a clock. Is this normal?
Havent seen anything in the documentations about this.
- FactoryDefault
- Common Wiggler
Mine's not centered either. If you want it to be spot-on, look at page 41 of the build guide for clues.HyprDrivr wrote: ↑Fri Dec 27, 2019 11:52 amHello Friends
Just built a Japer kit, powered up and worked right away so im happy about that.![]()
R9 affects osc2 frequency so either try another value that works or replace with a trimmer.
I think this is also in the BOM - it says 3k9 is the suggested value but you could also try 4k7.
edit: wanted to add that having the tune knob non-centered triggers my ocd too and it's on my to-do list! please report back on your results
- Very Little Fun
I have a hopeless feeling about this but I thought I would post this here first before abandoning the project all together...
A year ago I bought Jasper V.2.2 and the parts from Mouser as suggested ( I am in the USA ). At the time, the pedal guy at the music shop I work at was going to build this for me as long as I bought the parts. Well here we are a year later, he got half way done and just decided he doesn't want to do it since he quit the shop
. My question is, is there anyone on this board who would be willing to finish this Jasper build for me if I mailed it to you and paid you for your time?
I guess if not, there is the Behringer thing out later this month :(
Thanks in advance and Happy New Year everyone.
Keep on selling cocaine to angels.
HTH: There is actually a Hire-A-Builder ThreadVery Little Fun wrote: ↑Fri Jan 03, 2020 12:31 pmMy question is, is there anyone on this board who would be willing to finish this Jasper build for me if I mailed it to you and paid you for your time?
The Jasper build is well documented, and there's no SMT to solder, so don't despair
... why buy it for $100 when you can build it yourself for $150?
And even if you have never even seen a soldering iron before, it's always always better to diy than even consider getting all stinky with Behringer shit
