ornaments+crimes extended / polymorphic 4x16bit CV generator
pld
Re: ornaments+crimes extended / polymorphic 4x16bit CV generator
Post by pld » Thu May 14, 2020 4:49 am
wuff_miggler wrote:
Thu May 14, 2020 3:22 am
just wondering if anyone experienced in the zen of o_C can let me know where the best thread/place would be to post about prospective collaborative concepts for user created firmware for this beast?
Hm, between this and "user" thread there hasn't really been a "best" place for firmware development discussions.
Part of that is perhaps because (IMO) the firmware is kind of a one-off and was never intended as a base for long-term or community development. At least not without some fairly extensive groundwork and cleanup (some of which I have started in private github branches), but the hardware platform will always be limited. And of course Hemispheres created its own abstractions.
wuff_miggler
Post by wuff_miggler » Thu May 14, 2020 5:01 am
all good! Thanks for letting me know pld! :)
i love the skews which currently exist :D i guess my main question was regarding adding buttons, small controls on front panels which i'm working on a sketch on now. will start a new thread in music DIY
Sideshow
Post by Sideshow » Tue May 26, 2020 12:59 am
Dais3 wrote:
Sat May 02, 2020 4:32 am
Hi all
I've just completed building a O&C module for MOTM format. All good, but what I'd love to do before I design a panel for it, is to switch to using a 2.4" display - essentially the SSD1309 (I'm old and my eyesight is terrible). It is very similar to the SSD1306, but different enough it doesn't work 'out of the box'. Looking back on the dev history I can see O&C firmware was using U8glib which supports the 1309, and that pld has switched to a custom driver based on potions of that lib to optimise for O&C only on the SSD1306/SH1106. I'm happy enough getting into some code and compiling (I was a developer many moons ago), but wondered if a) anyone has done something like this, and b) if pld or anyone else has some pointers on the complexity of doing this, and if feasible how difficult/easy it might be?
many thanks
Cool!
I've been thinking about porting O&c to MOTM-format myself complete with PCB's to go flush with panel and PCB-mounted jacks.
In my panel mockups (which is all I've really done) it's planned to be a dual O&c behind a 3 unit width panel.
However if you are already porting O&c over to MOTM, I might just jump on (if possible).
Also I do not really have time to jump into making O&c for a while anyhow..
Please keep us updated over at the 5U-forum, I guess there are other ponytailers who would be interested in this aswell.
-Peas out :rastanana:
What is this?!?!?! A synthesizer for ants?!?! It needs to be at least.... ....three times this big!!
- J3RK / Zoolander
vcowl
Post by vcowl » Sun Jun 28, 2020 2:02 pm
Hello, first time post but I've been leaning a lot from the search history as I build my system!
I'm working on a uO_C kit from synthcube, and running into a few problems. I'm wondering if anyone may be able to help.
First off, what's working:
- Encoders, buttons, screen OK
- No problem flashing teensy and navigating menus
- T1/3 respond to clock
- C1-3 respond to CV in debug and references are OK
What's not working:
- All outputs stay at ~11.2V constantly
- T2 and T4 don't respond to clock
- C4 doesn't respond to CV
What I checked:
- reflowed DAC pins
- all IC orientations appear to be correct
- I couldn't see any missing solder joints
Unfortunately the standard O_C guide doesn't help me much with test points since I'm not quite good enough at electronics to translate between the original and micro boards. This is also my first SMD project, so it's entirely possible I did some joints wrong.
Thanks in advance for any ideas!
TL072
Post by TL072 » Sun Jun 28, 2020 6:13 pm
I know this is going to be a really annoying and tedious answer but 95% of problems I have had with SMD builds are eventually from soldering problems with fine-pitched pins.
I swear to you check some of my forum posts if you do not believe me. You will think you have checked the pins 2-3 times - but some how after you post a help on an internet forum you will try again and realise that somehow you missed something. For Micro o_C I think it is the DACs that are the tiniest pins.
  1. check all the fine-pitched pins for bridges.
  2. Use a multi-meter and if you can check for continuity between the pad and the pin (e.g. not enough solder)
Most of the problems I have had with SMD come down to either a solder bridge between pins or a pin that is not actually soldered down. For (1) If you do not have one already buy a cheap loupe to inspect them (I recall <10 USD/EUR). I wind a piece of wire around the ends of a multimeter probes if they are two big and go along the fine-pitched stuff to make sure they are not bridged (occasionally two pins are actually to ground so check against the schematic if you find continuity between two neighbouring pins).
For (2) above, you can often touch the top of the pin and the trace independently and if there is no beep you know exactly where one of the problems is. The issue becomes particularly clear if a little bit of pressure (very light!) on the pin leads to continuity. The way to solder those down is often to get a bit of solder on the iron and if simply flowing the solder on is not enough give again - very very light - pressure on the pin. Sometimes this has been enough to get the pin soldered.
pld
Post by pld » Mon Jun 29, 2020 12:27 am
Yeah, "recheck and/or reflow and/or clean yer board" as default answers are annoying, but often successful :)
There is a dedicated thread for the uo_C that might have reference points.
~11V anywhere but the rails is likely a short, but can get there with incorrect components around the DAC.
Altitude909
Post by Altitude909 » Mon Jun 29, 2020 6:18 am
open connections on the 2172s can give you those numbers also
vcowl
Post by vcowl » Mon Jun 29, 2020 2:21 pm
Thanks for the ideas! I found that pins 14, 15, & 16 on the DAC were testing positive for continuity between each other. I've tried desoldering them but am having a tough time getting it with braid, so I've used this dilemma as a justification to buy a cheap hot air station :) I'm going to try completely removing the DAC, cleaning up the pads, and attach it again.
I tried reflowed a suspicious leg on one of the 2172s as well.
Thanks again for the quick replies - I'll check in with how it goes.
emmaker
Post by emmaker » Mon Jun 29, 2020 2:30 pm
You need to look at the schematics.
TL072
Post by TL072 » Mon Jun 29, 2020 5:53 pm
I think this basically happened to me at some point as well.
For de-bridging, there is really goey flux that is almost like honey which i found to be really good and kind of separating the bridged legs almost like dish soap in oil and then the oil wicks onto the iron. This stuff. I think it was the first solution that worked for me and then at some point I needed the hot-air gun (this one works for me still but I am sure based on this recommendation many actual electronics people are waking up in a cold sweat and not knowing why)
vcowl
Post by vcowl » Wed Jul 01, 2020 9:11 am
Checking out the schematics and re-checking continuity between all the DAC pins, I'm no longer convinced there's any bridges or open connections on the DAC, but I may try reattaching it eventually if other things don't work. I reflowed all four of the transistors for the trigger inputs, which seems to have fixed one of them, but one is still not working. I reflowed all the connections on the 2172s as well, and still there's the problem of all four of the outputs staying constantly high at ~11.2V. Looking at the schematic, I don't really understand what components are shared between all four outputs that would cause them to behave that way, especially since there are two separate opamps on the outputs. Any suggestions on the most likely suspects?
Thanks for all the ideas so far! This is my first time doing any real troubleshooting on a board, since my other projects have been much simpler through-hole builds and just happened to work the first time :) Learning a lot.
ploubus
Post by ploubus » Wed Jul 01, 2020 2:28 pm
The o_C was also my first smd build and I too experienced the constant voltage on all outputs. If I remember correctly this was due to several bad solder joints along the op amps and some resistors as well. What helped me tremendously was that I loaded up the schematic and looked at just one output on the board and tried to figure out which components are involved in this circuit, tracing lines on the pcb and rechecking with the schematic. I then just reflowed all joints along the way and it worked out in the end.
Funnily I also ended up soldering a capacitor face down in place of a resistor at one point due to accidentally tossing around some stuff on the desk and ended up reflowing half the build before spotting it. That was fun.
