[IC] PRIZMA - 2 channel, 16 step sequencer with rainbow
windspirit
Post by windspirit » Mon Apr 24, 2017 6:28 pm
You can get them through adafruit as well but they are a bit more expensive.
sduck
experimental use of gravity
Post by sduck » Mon Apr 24, 2017 10:20 pm
Nothing wrong with the sparkfun ones. You might want to know that that 2.95$ price is for 5 of them, so it's only 12$ for 20 of them, enough for extras if any of them don't work.
rvlt
Post by rvlt » Mon May 01, 2017 10:32 pm
I’ve been using Prizma for a bit now and I’m liking it more and more.
There’s one (minor) thing that is still very irritating, even after using it for a while: the LEDs for steps that are switched off (no trigger) are white, that is by far the brightest ‚color‘ of all. For my eyes that is kind of a ‚reversed logic‘. Would be nice to have an option to use switched-off LEDs for unused steps.
itsritual
Post by itsritual » Sat May 13, 2017 9:17 pm
Built mine up, and everything works fine except the top encoder. Goes haywire if you go over a certain speed. Reflowed everything on its trace and still doesn't work.
Bad encoder? Really can't replace it right now as I don't have any extras on hand.
Edit: nvm both encoders do it. Going to re-check it.
modestnikov
Post by modestnikov » Tue May 16, 2017 7:16 am
Is there anybody sell soldered module? I'm ready to buy it! :hail:
dubtoms
Post by dubtoms » Tue May 16, 2017 9:06 am
Hey Ilya, I think a friend of mine has one for sale. I will let him know that you are interested. :wink:
modestnikov
Post by modestnikov » Tue May 16, 2017 9:28 am
dubtoms wrote:Hey Ilya, I think a friend of mine has one for sale. I will let him know that you are interested. :wink:
cool! my e-mail ilyakolesnikov DOG yandex DOT ru
IImyment
Post by IImyment » Tue May 16, 2017 9:47 am
Pm sent.
Thanks Thomas :)
toneburst
Post by toneburst » Tue May 16, 2017 3:58 pm
itsritual wrote:Built mine up, and everything works fine except the top encoder. Goes haywire if you go over a certain speed. Reflowed everything on its trace and still doesn't work.
Did you get this fixed? I had a similar issue, but just with the top encoder. I replaced the encoder, which didn't fix the problem. Turned out eventually one of the ceramic caps was missing. Once that was soldered, everything worked fine.
a|x
itsritual
Post by itsritual » Thu May 18, 2017 12:22 pm
a|x
Not yet. Planning just to reflow everything at some point. Already did the relevant caps, headers, and pins on the main IC. Thanks for the tip though.
ground_state
Post by ground_state » Thu May 25, 2017 1:12 pm
itsritual wrote:Is there still no Mouser/DigiKey/Amazon alternatives for the LEDs?
Presumably 474-COM-12986. These are listed as being the actual Sparkfun parts (same price, even), but obviously you'll save on shipping if you get everything else through Mouser.
av500
Post by av500 » Thu May 25, 2017 2:04 pm
$2.8 per LED...
gruebleengourd
Post by gruebleengourd » Thu May 25, 2017 2:18 pm
av500 wrote: $2.8 per LED...
No. That price is for a pack of 5.
The price is ok by me, considering I had to wait like 4 months for numerous falsely advertised packs of LED to ship from China.
av500
Post by av500 » Thu May 25, 2017 2:19 pm
ah, missed the 5-pack - that's fine
ground_state
Post by ground_state » Tue Jun 06, 2017 10:52 am
About to order a set from Mod Addict. Does anyone know if their chips have the latest FW? I can easily flash it myself, but I 'd like to know up front.
modestnikov
Post by modestnikov » Wed Jun 07, 2017 9:05 am
I've made a new panel for my Prizma. :banana:
ground_state
Post by ground_state » Wed Jun 07, 2017 10:01 am
JEEZ! That's gorgeous. Is it completely DIY, or did you have it fabbed somewhere?
henrybirdseye
Prizma calibration trouble
Post by henrybirdseye » Wed Jun 07, 2017 11:57 am
I enjoy my Prizma, but I'm having a hell of a time calibrating it. It was just a tad out of tune, so I plug, say, the red cv into my uScale quantizer so I can see what voltage is coming out, and dial in some notes on the Prizma, and the LED indicating which note I'm sending, doesn't match the info on the uScale.
So, I go into calibration mode, and trim "ZERO" until I get 0000 in my voltmeter, then turn the upper encoder to a higher octave to tune for proper CV scaling. Trimming "V/OCT" seems to do nothing.
What am I missing?
modestnikov
Post by modestnikov » Thu Jun 08, 2017 5:16 am
ground_state wrote:JEEZ! That's gorgeous. Is it completely DIY, or did you have it fabbed somewhere?
yes, thank you)
I made design in Illustrator. Panel was made by https://shildpanel.ru/
small manufacture in Russian town Vladimir. it was cost 40$
It has absolutely awesome quality. I'm going to do another panel for my Radio Music module
ground_state
Post by ground_state » Thu Jun 08, 2017 9:21 am
Very nice.
I did something similar for my Anushri; it was about US$60 for the whole case from Pololu, cut and engraved (I colored it by hand).
What an amazing time we live in, when something like this is even possible.
johnnyapolis
OUT OF STOCK RESISTORS
Post by johnnyapolis » Sun Jun 11, 2017 1:59 pm
So I put in my part order at Mouser but there are two film resistors that they say are out of stock until JANUARY of 2018! I checked Digikey as well and they're saying the same thing. Does anyone know where I might find the following parts:
667-ERJ-3EKF2200V Panasonic 220ohm film resistors
667-ERJ-3EKF1001V Panasonic 1kohm film resistors
Or does anyone have a few I could buy from you to complete my project? Thanks!
johnnyapolis
Post by johnnyapolis » Sun Jun 11, 2017 2:24 pm
daynehacks
Post by daynehacks » Sun Jun 11, 2017 5:34 pm
You should be able to use any brand resistor that is the same package, if this case 0603. Sometimes even 0805 parts fit if you have some on hand.
The first one you linked would work, but the second one is a different case size.
johnnyapolis
Post by johnnyapolis » Fri Jun 16, 2017 2:50 pm
Thank you! It appears I've got a bit to learn--I haven't soldered this type of resistor before. I ordered twice as many as I need for a little extra practice before attacking the actual project!
daynehacks wrote:You should be able to use any brand resistor that is the same package, if this case 0603. Sometimes even 0805 parts fit if you have some on hand.
Switchzik
Post by Switchzik » Fri Jul 07, 2017 11:25 am
Hello everyone!
Is it normal that the prizma change the CV even when trigger is off ?
He will still play the pitch set for the step via the CV editor function.
Is that a normal behaviour ?
What I would like is that it doesn't send any new CV if the trigger step is off.
