[BUILD] JasperIN - Midi and CV/Gate Input for Jasper/Wasp
afx
Post by afx » Fri Feb 16, 2018 6:58 pm
Purveyor2 wrote:
Purveyor2 wrote:
Put me down for a JasperIn w/teensy. Thanks.
order here: viewtopic.php?t=171543&highlight=
Did you get the order or did I mess it up? thx
Where are you located?
Purveyor2
Post by Purveyor2 » Fri Feb 16, 2018 10:05 pm
Portland, OR
mbroers
Post by mbroers » Fri Feb 16, 2018 10:38 pm
im having some difficulty getting the jasper in cv/gate to respond to the gates that are generated from an sh101 internal sequencer, im not sure why. i dont currently have a scope to see what the gate looks like from the 101 in each scenario.
im using the latest beta firmware.
when i have the 101 cv/gate out to the jasper cv/gate in and i just press keys on the 101, the cv/gate works as expected. when i use the 101 internal sequencer it doesnt respond to any gate changes and just looks like its getting one long gate (indicator light stays lit with little fluctuations when gates are sent). i tested this setup with a pro one instead of the jasper and it works fine, with the pro one envelopes triggering as expected when the source of cv/gate is the 101 internal sequencer...
is this a sensitivity thing that can be possibly adjusted in the firmware?
mbroers
Post by mbroers » Fri Feb 16, 2018 11:34 pm
also doesnt seem like midi is working with the latest 20 beta in my rig. i can switch back to .09a and get a sequence working from ableton. then i upload the latest beta and set midi channel and cv range (i keep it on channel 1 anyway..) and the same sequence from ableton that worked in .09a doesnt trigger the jasper on beta 20. i tried putting the notes in different octaves just to see if i would get any response but no dice.
afx
Post by afx » Sat Feb 17, 2018 1:00 am
mbroers wrote:im having some difficulty getting the jasper in cv/gate to respond to the gates that are generated from an sh101 internal sequencer, im not sure why. i dont currently have a scope to see what the gate looks like from the 101 in each scenario.
The GATE of the 101 is not off long enough to retrigger a new note on the jasper. The trigger on the jasper is a 50Hz signal, if I recall correctly it needs the trigger signal to be low/off for over 10ms to retrigger a new note.
I have access to a 101 so I will test what comes out of the gate while using the sequencer.
afx
Post by afx » Sat Feb 17, 2018 1:01 am
mbroers wrote:also doesnt seem like midi is working with the latest 20 beta in my rig. i can switch back to .09a and get a sequence working from ableton. then i upload the latest beta and set midi channel and cv range (i keep it on channel 1 anyway..) and the same sequence from ableton that worked in .09a doesnt trigger the jasper on beta 20. i tried putting the notes in different octaves just to see if i would get any response but no dice.
Did you unplug the CV/GATE cables while testing midi?
mbroers
Post by mbroers » Sat Feb 17, 2018 9:12 am
Makes sense, i was hoping something in software could assist but im guessing the cv/gate conversion isnt controlled there.
mbroers
Post by mbroers » Sat Feb 17, 2018 9:14 am
Yeah i was going between firmwares with no cv gate plugged in just trying to get midi working on the latest.
mbroers
Post by mbroers » Sat Feb 17, 2018 9:49 am
Double post
mbroers
Post by mbroers » Thu Feb 22, 2018 10:55 am
has anyone else updated to the new firmware and had midi work as expected?
afx
Post by afx » Thu Feb 22, 2018 3:10 pm
mbroers wrote:has anyone else updated to the new firmware and had midi work as expected?
Check if R12 and R14 are properly soldered.
mbroers
Post by mbroers » Thu Feb 22, 2018 5:17 pm
will do, thanks for the tip - for clarification midi works fine on the previous firmware and this was a prebuilt jasperin order.
afx
Post by afx » Thu Feb 22, 2018 5:27 pm
mbroers wrote:will do, thanks for the tip - for clarification midi works fine on the previous firmware and this was a prebuilt jasperin order.
I didn't had those 2 resistors properly soldered on the unit that I used to test the firmware, so the old firmware was not working as it was intended.
mbroers
Post by mbroers » Thu Feb 22, 2018 9:53 pm
R12 and R14 seem soldered fine on my prebuilt jasperin. old firmware is still working fine for midi, new latest firmware is not responding to midi.
afx
Post by afx » Fri Feb 23, 2018 12:09 am
What voltages do you have on the south side (label side) of those resistors with and without cables plugged?
mbroers
Post by mbroers » Sat Feb 24, 2018 12:16 am
Due to some time constraints I had to seal this up with the .09a firmware so I will be holding off to troubleshoot further until the sequencer stuff is available. I'll be cracking it back open at that time for sure.
col
Post by col » Wed Mar 28, 2018 7:21 pm
The links to the firmware are not working?
wget http://misw.us/jasperin/JasperIN.v0.09a.zip
--2018-03-29 11:17:08-- http://misw.us/jasperin/JasperIN.v0.09a.zip
Resolving misw.us (misw.us)... 74.208.236.44
Connecting to misw.us (misw.us)|74.208.236.44|:80... connected.
HTTP request sent, awaiting response... 404 Not Found
2018-03-29 11:17:24 ERROR 404: Not Found.
wget http://misw.us/jasperin/JasperINBeta20.zip
--2018-03-29 11:17:56-- http://misw.us/jasperin/JasperINBeta20.zip
2018-03-29 11:18:12 ERROR 404: Not Found.
Altitude909
Post by Altitude909 » Thu Mar 29, 2018 2:41 am
Fixed
col
Post by col » Thu Mar 29, 2018 9:12 am
Altitude909 wrote:Fixed
:tu:
JanneI
Post by JanneI » Sun Apr 01, 2018 9:30 am
Installed the 20 beta and now midi doesn't work at all. I put the old 0.9 back, it works..
Altitude909
Post by Altitude909 » Sun Apr 01, 2018 10:51 am
JanneI wrote:Installed the 20 beta and now midi doesn't work at all. I put the old 0.9 back, it works..
Somethings up , youre not the first to report this. What midi controller are you using?
JanneI
Post by JanneI » Sun Apr 01, 2018 11:14 am
Arturia keystep
Altitude909
Post by Altitude909 » Sun Apr 01, 2018 3:48 pm
Arturia keystep
Try hitting the learn when it's powered up and pressing a key.
BambooGuerilla
Jasper in Pin Headers
Post by BambooGuerilla » Mon May 14, 2018 12:43 pm
Hi,
For what are the pin headers ment for. (Vs,Ck,Mi,M8,M10,//Vs,Ss,Mo,M7,M9)
Also I read something in the new beta about sequences and arpeggios. How does this work.
Thanks in advanced.
Menno
afx
Re: Jasper in Pin Headers
Post by afx » Mon May 14, 2018 3:49 pm
BambooGuerilla wrote:Hi,
Thanks in advanced.
Menno
The header is for access to unused pins on the teensy, those can be used by another peripheral device like the sequencer addon.
