Need help to ID a part (e350 Morphing Terrarium)
Steam Shield
Post by Steam Shield » Fri Jan 06, 2017 5:40 pm
So I was rearranging my case and by accident broke a part off of my e350 due to a cable that was stretched too tight directly into it. Totally my bad.
Now I am trying to figure out which part this is and where to find it.
The part is from L6.
If anybody can ID this, you RULE!
lasesentaysiete
Post by lasesentaysiete » Fri Jan 06, 2017 5:57 pm
The manufacturer could identify which part it is. :despair:
L is inductor, btw. Unfortunately, I don't own the module.
Altitude909
Post by Altitude909 » Fri Jan 06, 2017 6:08 pm
Just contact paul, he's here
Steam Shield
Post by Steam Shield » Fri Jan 06, 2017 7:24 pm
Just sent a message to Paul, hopefully he can save the day here. Thx.
paults
mice nuts
Post by paults » Fri Jan 06, 2017 9:11 pm
Day saved. It's a ferrite-shielded inductor used in the power supply.
Good thing all SynthTech modules have a lifetime warranty :bananaguitar:
Steam Shield
Post by Steam Shield » Sat Jan 07, 2017 9:23 am
Oaky the part has been IDed!.. thanks to everyone who posted.
The comment from The 67 was especially helpful to start the part search and later Paul confirmed the correct part which is from the H series from Panasonic.
Next comes the solder work... thankfully this component uses some larger pads that should be relatively easy to work on and should be oaky for my novice solder skills. Basically I can't wait to use the e350 again.
:party:
thevegasnerve
Post by thevegasnerve » Sat Jan 07, 2017 9:55 am
paults wrote:Day saved. It's a ferrite-shielded inductor used in the power supply.
That's really awesome to help out so quickly, especially as I have my eye on a few Synthtech modules. That Deflector Shield is so cool!!
dhergott1
Re: Need help to ID a part (e350 Morphing Terrarium)
Post by dhergott1 » Wed Jun 24, 2020 10:17 pm
I have the exact same problem -- any insight into where you located the part and tips for soldering it in place would be appreciated!
Altitude909
Post by Altitude909 » Thu Jun 25, 2020 6:32 am
just like an SMD polarized cap
dhergott1
Post by dhergott1 » Sun Jun 28, 2020 9:41 am
Paul was very helpful and prompt with his response. :yay:
And it was very easy to solder. :tu:
