Not OP, but that explains a lot, thanks. I was confused about max holes size too, but then I just sent the panel without thinking too much, seeing other people here having larger holes made by the same fab.
PCBs as Front Panels ?
- joeSeggiola
- Wiggling with Experience
- Contact:
Re: PCBs as Front Panels ?
- Tonescape
- Contact:
That looks quite nice Romain! Which kind of varnish did you use, and how did you apply it? Thanks
_________________________________________________
www.bragi-modular.com - www.instagram.com/momecmusic
Thanks !
For those panels with a "granular" finish, I used Edding e5200 Spray (amazon) for the first layers and I finish with Altona anti reflection varnish.
I think that a spray varnish is the best choice to have a nice homogeneous render.
Edding Spray is supposed to be mat but still Altona is better for that.
If using only Altona, you get a very smooth surface which is also very nice.
I m almost out of stock of Altona and made a new order. I realized that the graphics are different. Hope they didn't change anything.
- Tonescape
- Contact:
Nice. I really like the textured finish on the Erica synths examples.
- fitzgreyve
- Veteran Wiggler
Just received the following 3hp 1.6 mm aluminium panels from PCBway. Order to delivery (UK) was 10 days using Fed-Ex IP.
Panel layout created in FPD, SVG imported into MS Visio to add graphics, then SVG imported in Designspark PCB to create the gerbers (initially assigned to "front documentation" which was used to align holes (no plating) or reassigned to "front screenprint").
The fixing slots were imported into Designspark separately so that they could be assigned to the "board outline" layer. No issues at all from PCBway on these.
This has a full copper layer on the top surface under the black resist layer. I selected the "no manufacturing number" option, but was not charged for it.
Quality is acceptable for the price - no obvious marks on the panels (anything on the photo is dust).
Under developement:
- Reich
https://fitzgreyve2.blogspot.com/
- Reich
- joeSeggiola
- Contact:
Nice. I will probably built an "orthogonal" (how do you say that?) module next.fitzgreyve wrote: ↑Tue Jan 19, 2021 5:45 amJust received the following 3hp 1.6 mm aluminium panels from PCBway.
What are the plugs you used? They look different from the one I ordered:
- fitzgreyve
- Veteran Wiggler
PJ302M (from Thonk in the UK)joeSeggiola wrote: ↑Tue Jan 19, 2021 6:40 amWhat are the plugs you used? They look different from the one I ordered:
Under developement:
- Reich
- Reich
Orthogonal is correct and accurate, but many or most native speakers would say "perpendicular" instead.joeSeggiola wrote: ↑Tue Jan 19, 2021 6:40 amI will probably built an "orthogonal" (how do you say that?) module next.
But usually they would add.. perpendicular to what?
I will probably build a module with a perpendicular PCB next.
I will probably build a module with an orthogonal PCB next.
The top one of the two would be most common.
EDIT: I will probably build a perpendicular PCB module next. <-- This would be another choice.
Leaving out "with a" creates an amibiguity between whether the perpendicularity refers to construction or function. But many would still understand the meaning given any context at all.
- indigoid
- Super Deluxe Wiggler
beware that there are two very similar variants of this jack floating aroundfitzgreyve wrote: ↑Tue Jan 19, 2021 7:42 amPJ302M (from Thonk in the UK)joeSeggiola wrote: ↑Tue Jan 19, 2021 6:40 amWhat are the plugs you used? They look different from the one I ordered:
there's another type from Lumberg called 1503_12 which has the same footprint but has a shorter length of thread
fine with typical PCB/aluminium panels... but back then I was using lasercut 3mm acrylic and the thread was too short :-(
https://au.element14.com/lumberg/1503-1 ... dp/1340604
Zap him again! ZAP THE SONOFABITCH AGAIN!
- Altitude909
- joeSeggiola
- Contact:
I tried ordering black 2mm panels on JLCPCB again, but I find them pricier than expected. I have just 1 design per board instead of 5; last time was my first, so I made many variations to test manufacturing. I thought that would keep the price down, but it's still around 40 or 50 EUR for single layer PCBs. Am I doing something wrong? Or is it right? I checked a couple other manifaturers too (PCBway, for example), but they're pricier.
- Flounderguts
- Contact:
YES! you are doing something wrong. JLC keeps prices down by keeping things to certain processes, not by less material. Make a 2 LAYER pcb with soldermask and a few traces (or a ground pour) on the back.joeSeggiola wrote: ↑Sat Feb 13, 2021 9:28 amI tried ordering black 2mm panels on JLCPCB again, but I find them pricier than expected. I have just 1 design per board instead of 5; last time was my first, so I made many variations to test manufacturing. I thought that would keep the price down, but it's still around 40 or 50 EUR for single layer PCBs. Am I doing something wrong? Or is it right? I checked a couple other manifaturers too (PCBway, for example), but they're pricier.
Black is now same price as green, but single layer adds a $50 surcharge.
Flounderguts
Flounderguts
- joeSeggiola
- Contact:
Nice to hear that, but I'm pretty sure I tried the double layer also. In fact, my initial gerber had soldermask and ground pour on the back, and its price was even bigger. I made it single layer because of that. It's 2mm thick in black, with ENIG-RoHS finish. I still have to confirm the order, since they will start production on the 19th because of Chinese New Year holidays. I guess I should try switching options again...?Flounderguts wrote: ↑Sat Feb 13, 2021 11:15 amYES! you are doing something wrong. JLC keeps prices down by keeping things to certain processes, not by less material. Make a 2 LAYER pcb with soldermask and a few traces (or a ground pour) on the back. Black is now same price as green, but single layer adds a $50 surcharge.
- Flounderguts
- Contact:
2mm is also expensive.
2 layer 1.6 mm black ENIG is the standard for me...and is generally same price as green, up to about 10 cm2
Flounderguts
Flounderguts
- bgreeves
- Common Wiggler
- Contact:
2mm board + ENIG is a relatively uncommon combination for them so they'll charge you a bunch extra for it.
I've shopped around a bit, and JLC is probably still the best price you're gonna get for small batches.
If you're doing anything with some quantity to it, go look at PCBWay. The setup cost is higher but you can 2mm aluminum board (1 layer) for the same cost as getting 2mm FR4 board (2 layer) there. It's also a lot cheaper to combine your designs into one panel at PCBWay than it is at JLC.
If I assume your panels are 4HP eurorack and you have 5 different designs, here's the quote to get 5 of each panel (ENIG is selected, you just can't see it):
$166 USD or just under $7 per panel. So like 5 EUR ea. Did I hear you correctly that when you last quoted from JLC each separate panel would be 30 or 40 EUR for 5 of them? So it looks like this might be cheaper, and you get aluminum!
- joeSeggiola
- Contact:
Flounderguts wrote: ↑Sat Feb 13, 2021 2:35 pm2mm is also expensive. 2 layer 1.6 mm black ENIG is the standard for me...
Uh, yes, looks like the thickness is a bigger discriminating factor than I thought! 1.6mm ENIG is cheaper with 2 layer (less than 20€), while 2mm ENIG is cheaper with 1 layer (about 40€). I'm not considering HASL because, correct me if I'm wrong, it's not great for front panel aesthetics... I considered 2mm an imperative to improve stiffness, but I guess I should also try 1.6mm with ground pour on the back layer... Latest project had very few jack connectors panel-mounted only, while the next will have lot of them soldered on the PCB too; I guess this should make the panel stiffness less crucial.
I'm doing very small quantities (the minimum, really: 5) because they're just for myself. I think I'll keep ordering from JLCPCB.
40€ total, I always reported total price for the minimum quantity, which is 5.
- bgreeves
- Common Wiggler
- Contact:
You're not wrong at all. Looks abysmal from JLC for front panels, mostly because it scratches incredibly easily and is just not an even finish at all.joeSeggiola wrote: ↑Sat Feb 13, 2021 3:42 pmI'm not considering HASL because, correct me if I'm wrong, it's not great for front panel aesthetics...
Right, is that for each different panel, so 200€ total for your 5 designs?joeSeggiola wrote: ↑Sat Feb 13, 2021 3:42 pm40€ total, I always reported total price for the minimum quantity, which is 5.
- joeSeggiola
- Contact:
No, no, if I have different designs, I panelize them myself, and the total price grows about 10€-15€ higher total. I was always talking total, the total cart price (except shipping ofc).
Thanks for your reply about finish, one option less to consider.
Hi
How do you remove the order number,ive forget to select remove the number in a small pcb order,thanks
Fyi,at jlc ,you can remove the number ,in the detail section and for big panel ,you can choose paper between each pcb
Attached my 208X projet ,prototype pcb panel varnished
? Thanks
Fyi,at jlc ,you can remove the number ,it’s a details ,and for big panel ,you can choose paper between pcb
Attached my 208X projet pcb panel
options
? Thanks
options
208X 200X modules serie ,Buchla 200 upgraded viewtopic.php?f=17&t=243688&p=3444875#p3444875
FS :custom buchla 203 style càbinet ,skiff new design,boat ,hardware for diy cabinet ,easel case ,new 1u to 10u to 56u and more. / New 208 buchla card 12 price down atm/
HQ small case buchla psu PCB
viewtopic.php?p=3118393#3118393
viewtopic.php?t=211862&highlight=
Although I usually use metal, I do have a HASL front panel with 2oz copper in front of me I made as a trial and it's not that bad. For stiffness, and provided your connectors can accomodate it, two 1.6mm panels are cheaper than one 2mm panel, and a lot stiffer.joeSeggiola wrote: ↑Sat Feb 13, 2021 3:42 pmI'm not considering HASL because, correct me if I'm wrong, it's not great for front panel aesthetics... I considered 2mm an imperative to improve stiffness, but I guess I should also try 1.6mm with ground pour on the back layer..
- bgreeves
- Common Wiggler
- Contact:
Thonkiconns just barely fit through 2x1.6mm:
Also you can see what I'm talking about with the scratching on the HASL.
Why worry about HASL *or* ENIG, a panel doesn't require metallic highlights.
- bgreeves
- Common Wiggler
- Contact:
And a gift doesn't require a bow. And a sundae doesn't require a cherry.
I mean, why would people want anything besides a square of aluminum with sharpie on it? All you need is labels after all.
Yes I said it depends on your connectors.
I can't see much scratching on the HASL which will be hidden by the connectors anyway. But agree the solder resist layer isn't the best.
