Flounderguts wrote: ↑Wed Feb 17, 2021 1:37 pm
1st, check your board to board connections at TRNS2.
2nd, check the soldering on the #2 NXP 4093, and make sure it's not backwards or has any bridged connections.
3rd, near that NXP chip there is a 547 transistor, check the connections and the orientation of that transistor.
4th, as the voices are sounding together, with the hold pot off, check for a grounding issue last...an upside down chip would do that, but there may be a different issue. Check for continuity to gnd from the pch connections and also the TRNS2.
Thanks for taking the time to reply
1) board to board connection at TRNS2 seems OK, I have continuity between the control board, connector pins and the TRNS2 labeled on the main board (I have used dupont cables with one side soldered to the control board and the dupont side connected to pins on the main board)
2) the NXP 4093 are in the same exact orientation, with the slant towards the top of the main board
3) all transitors are in the right direction, already checked 1000th times
4) no grounindg apparently. I have tested all of the connection pin points and none is shorting to GND (except GND pins of course).Trns2 is not shorted. IC are all in the correct orientation...
Some more testing and troubleshooting:
I noticed that when PITCH fori voices 5-8 is turned on, voices 5 and 8 are very loud, while voices 6 and 7 are barely audible.
I have some
SUSPECTS (can you confirm if they are right or not?)
1) I salvaged the 4x DPDT ON-OFF-ON swicthes from (very) old audio gear. Maybe they are not the right ones or there's a broken/shorted one?
2) at some point I am pretty sure I connected the IO Board in the opposite way, possibly shorting VCC+ and VCC-. Maybe some IC got burnt? (I have plenty of TL074 and some spare 4093, doesn't cost anything to swap them)
Other ideas are welcome ;-)
