I am taking orders for these now, and will be mailing out the first production run in about 4 weeks. I have 25 units available.
I have added some new features, which I find useful. The "manual" and "tone write" buttons on the PG-800 Mini can be configured to behave like a stock PG-800, or you can enable a set of enhanced button features. New features are as follows:
Tapping the TONE WRITE button will produce a scratch program, which functions as a useful starting point when creating a new sound. (Think Jump by Van Halen)
Holding down the TONE WRITE button will produce a random program, where all 44 pots are assigned random values. This can be a fast way of discovering interesting sounds.
Tapping the MANUAL button will set all 44 parameters to the corresponding functions on the PG800 Mini, just like the MANUAL button does on any typical polysynth.
Holding down the MANUAL button will copy the current state of the controllers on the PG-800 Mini, but won't send the values to the JX. If you hold MANUAL down again, then the copied state will be transmitted to the instrument. This is a handy way to transfer a tone to another patch, or just hang on to an idea. I use it frequently now.
Holding down the MANUAL and TONE WRITE buttons will disable the PG800 Mini until you press the MANUAL button again.
With two buttons, you can add a lot of additional functionality to the PG800.
The pricing scheme is as follows:
Bare PCB, schematic, programmed processor chip, graphic overlay, BOM, and drill template - $99. (Requires SMD soldering)
Assembled & tested board with drill template and graphic overlay $250
Fully assembled and tested external unit with 5' DIN cable - $350
If you're interested in getting one, please PM me. Thanks!
A giant photo gallery with lots of angles of the product can be viewed here.
A couple videos can be viewed here:
