1J17B Tube VCF eurorack
Eric the Red
Post by Eric the Red » Mon Dec 10, 2018 12:17 pm
Funds sent! Looking forward to this arriving.
-Eri
Abandon all hope, ye who wiggle.
fg
1J24B +/-12volt schematic
Post by fg » Sat Dec 22, 2018 6:19 am
hello, i built this module with this schem and it's ok
i use 2x low cost vactrol VTL5C but 2x leds + photocells work too
daynehacks
Post by daynehacks » Sat Dec 22, 2018 10:37 pm
I've sent a PM, I'm in for one!
rvrv
Post by rvrv » Wed Dec 26, 2018 6:26 pm
Thanks to all for your support, we now have 10 boards in the wild !
Looking forward to hear how these built goes.
rvrv
Re: 1J24B +/-12volt schematic
Post by rvrv » Wed Dec 26, 2018 6:27 pm
fg wrote:hello, i builded this module with this schem and it's ok
Thanks fg, I have some 1J24B tubes that I will also test soon.
synthetek
Post by synthetek » Fri Dec 28, 2018 6:39 am
Almost done with mine, waiting on 2 parts :ripbanana:
tomba
Post by tomba » Mon Jan 14, 2019 3:54 pm
Hi, I'm very insterested in your pcb and panel. :sb: :sb: :sb:
Are they still avaiable? if so, can you send them in Italy?
oberkorn
Post by oberkorn » Fri Feb 15, 2019 3:47 pm
took a while to get all the parts I didn't have in my stash but it was well worth it!
awesome sounding filter with evil distortion. will try to get a demo up this weekend
shogeki
Post by shogeki » Fri Feb 15, 2019 10:02 pm
I have a bunch of tubes leftover from building the CGS65, I'm interested in a few of those depending on the price (if still available).
BARD
Post by BARD » Wed Feb 20, 2019 8:20 pm
Hey rvrv
Greets for this project! Can we hear some news?
oberkorn wrote:will try to get a demo up this weekend
I would love to hear this VCF in line recording. Sounds good on OP's demos, even picked up with mic 8-)
I had a look on schematics - C8 and C19 basically are connected in parallel, right?
What's the function of C11?
oberkorn
Post by oberkorn » Tue Feb 26, 2019 11:56 am
here is the video --> https://vimeo.com/319940567
hope you like it. thanks to rvrv!
rvrv
Post by rvrv » Mon Mar 04, 2019 3:59 pm
thanks oberkorn for the video !
BARD, I will post a line recording soon, good idea.
shogeki
I send you a pm, I have two pcb left + panels.
rvrv
Post by rvrv » Wed Mar 06, 2019 4:31 pm
hi,
a demo was recorded and quickly edited here https://soundcloud.com/kroubikou/kroubikou-la-cigale
cheers !
daynehacks
Post by daynehacks » Tue Oct 08, 2019 11:55 pm
Well I finally built mine up! I waited quite a while to order the proper switches and vactrol, oops.
I've used 0805 SMD resistors and capacitors for all the resistors and ceramic caps. They work perfect over upright resistors.
I used BC337/BC327 for the transistors, because that's What I had around. Seems to work
I used 4 parallel 830ohm resistors to make something close to 220ohm for the tube. I have ~1.3v on the heater, so I hope that will not kill it too fast.
I haven't tried adjusting the 1v/oct trimmer yet, and I've adjusted the others to what I "think" sounds right, but who knows. Anyone have info on the "proper" way to adjust the trimmers?
Otherwise, this tube VCF is awesome. I like it a lot! Sometimes it makes some crazy sounds never to be found again... until they decide to reappear with the right combo of settings and input! It's a welcome addition to my rack!
1WILDTHING
Re: 1J17B Tube VCF eurorack
Post by 1WILDTHING » Mon Jun 08, 2020 3:46 am
Hi there, is this project still active? I'm really interested in this PCB....
1WILDTHING
Post by 1WILDTHING » Thu Jun 11, 2020 6:10 am
may be someone has a spare PCB? :oops:
rvrv
Post by rvrv » Sat Jun 13, 2020 2:54 am
Hello, sorry for taking so much time to respond. Yes I do have spare pcbs and panel and tube and double vactrol if you like. I will answer to your pm !
Also, I may run out of stock but if needed I will run a new PCB batch.
BARD
Post by BARD » Tue Jul 07, 2020 10:19 am
PM sent
socom93
Post by socom93 » Sat Jul 25, 2020 9:01 am
Hey rvrv ! Bravo ! Excellent project, where did you find the kicad footprint for the tube ? Did you do it yourself ?
rvrv
Post by rvrv » Sat Jul 25, 2020 9:27 am
Thanks ! If I remember well the footprint came from an old befaco project with 1J24b tubes.
socom93
Post by socom93 » Sat Jul 25, 2020 11:51 am
Found the footprint thank you !
paperCUT
Post by paperCUT » Fri Jul 31, 2020 7:55 am
I finally finished my build and this filter is stunning! There's a massive range of sounds possible and the difference between high and low pass is so dramatic (feedback is inverted between the 2 modes but is on an attenuverter). I have to post some demos of drones that sound totally organic and lively, more than any other filter I have this responds to different content in unpredictable ways. With a simple saw it's got one sound but add a second osc and the beating distorts the filter in a lovely way. Add noise and it starts to act like a tunable distortion, all without touching the controls.
It CAN do clean but not as predicable as other filters, best as a balls-to-the-wall lead filter.
