Deckards Dream General Build Thread
- synthcube
- you will be assimilated
its related to the pad spacing, the diodes are slightly different sizes. Functionally the same.
Hot air is really for removal, not assembly, because it isn't easy to tightly control the temperature profile using hot air by hand. I had an issue using hot air to solder where the components were literally popping off the board, not blowing due to airflow (which was low, but high temperature). My hypothesis is that this was to do with humidity and moisture either in the paste or on the surface of the components turning to steam in an explosive fashion rather than gradually evaporating. I switched to the hotplate method, with a heavy tile between the hotplate and the circuit boards that provides a decent thermal mass so that fast changes in the hotplate temperature are absorbed and controlled. I've had great results with this for prototyping, so long as you only have SMT on one side if the board.needspeed wrote:As in blow them across the room???????sduck wrote:Just make sure you have a few extra caps handy as you're likely to blow away at least a few. At least I've heard that can happen - of course it never happens to me. Nope.
- oldcrow
This diode is part of the negative rail voltage protection used on each 2164. If the 2164s are powered on the V+ pin with the V- rail missing/disconnected/unpowered a condition exists where a significant current flows into V+ which can damage the part. V+ internally tries to pull the free-floating V- up and if it gets above ~0.7v large currents start to flow as the voltage starts bypassing ordinarily reversed-biased junctions. The external diode clamps the V- to ground at a known lower forward voltage (~0.25v) to avoid this issue.
A 1N5187 or BAT85 work equally well, Roman simply changed the part to a smaller package to match up with the pads on the boards.
Crow
Crow
needspeed wrote:
Did you guys catch this change???
Per ultravox - REV1.0.6 CHANGED 1N5817 TO BAT85S ON THE MOTHERBOARD
Thank you very much for your knowledge and wisdom........Steveoldcrow wrote:This diode is part of the negative rail voltage protection used on each 2164. If the 2164s are powered on the V+ pin with the V- rail missing/disconnected/unpowered a condition exists where a significant current flows into V+ which can damage the part. V+ internally tries to pull the free-floating V- up and if it gets above ~0.7v large currents start to flow as the voltage starts bypassing ordinarily reversed-biased junctions. The external diode clamps the V- to ground at a known lower forward voltage (~0.25v) to avoid this issue.
Crow
To a never ending journey of exploring all noise that may or may not be music to someone or anyone.
Very happy to hear that, but I figure unless you have the PCBs the panel and case are circumstantial at bestJruss993 wrote:Woohoo! Synthcube just sent out my full kit for DD. Now just waiting on the front panel and case. So excited to finally have this coming together!
- Chrutil
- Veteran Wiggler
My video about hand soldering 0805 SMD caps got some comments about how it could be done with solder paste and a hot air station instead.
This got me curious so I decided to try it out and make a comparison video:
Soldering 0805 Caps for Deckard's Dream part 2 - Iron or Hot Air
My PCBs have made it from Tokyo to Chicago
MY PCBs have made it to Chicago from Japan. That is only 4 or so hours from where I live!!!!!!!!!!! It's got to be this week so hopefully I will be the first to post PCB pics unless on of you beat me to it!!!!!!!!!!!
10/15/2017 22:44 Item returned from import Customs ISC CHICAGO IL (USPS) UNITED STATES OF AMERICA
- the bad producer
@roglok - I'm going to buy the Smallbear soft touch ones in white and dye them, like this chap:
viewtopic.php?t=83775
These: $0.12 each
http://www.smallbear-electronics.mybigc ... oft-touch/
These: $0.12 each
4U panels for sale/4U wiring diagrams/4U stuff here: http://www.loudestwarning.co.uk/
And here, http://loudestwarning.tumblr.com/
https://www.instagram.com/loudestwarning/
Thanks for the link - that sounds a bit more reasonable! Doing it the hard way, I don't suppose you'd be willing to produce a few extras...the bad producer wrote:@roglok - I'm going to buy the Smallbear soft touch ones in white and dye them, like this chap:
These: $0.12 each
- the bad producer
Yeah, why not - they may not be exactly the correct colour
I'll let you know how it goes!
Thanks for the video! I think without a reflow oven, it seems quicker and more practical to just use an iron. I find 0805's pretty comfortable to solder with the right prep and equipment. 0603 on the other hand, it ain't so easyChrutil wrote:My video about hand soldering 0805 SMD caps got some comments about how it could be done with solder paste and a hot air station instead.
Sounds like group buy stuff...roglok wrote:Has anyone found an alternative source for switch/slider caps yet. The pricing for the ones specified in the BOM is outrageous (3£ for 10pcs). After all those are just tiny coloured PVC nipples...
What is this?!?!?! A synthesizer for ants?!?! It needs to be at least.... ....three times this big!!
- J3RK / Zoolander
- J3RK / Zoolander
- ultravox
- Ultra Wiggler
The switch covers arrived today. I ordered the colors separately but they arrived as a kit.Sideshow wrote:Sounds like group buy stuff...roglok wrote:Has anyone found an alternative source for switch/slider caps yet. The pricing for the ones specified in the BOM is outrageous (3£ for 10pcs). After all those are just tiny coloured PVC nipples...
This means nothing to me... Oh, Vienna!
Sweet! Just sent them an mail asking for the kit.ultravox wrote:Exactly. When I placed the order I didn't see a Deckard's Dream kit option. Maybe they knew what I wanted by the colors I chose?Sideshow wrote: Cool!
So they came as a kit? And you didn't order it as a kit?
They really should make it an option in their webstore
- J3RK / Zoolander
- J3RK / Zoolander
- ultravox
- Ultra Wiggler
I paid £2.99 for quantities of 10 of each required color. There wasn't a kit advertised, it just arrived that way.roglok wrote:so how much was the kit?ultravox wrote:Exactly. When I placed the order I didn't see a Deckard's Dream kit option. Maybe they knew what I wanted by the colors I chose?Sideshow wrote: Cool!
- keninverse
That is very cool for those who are so inclined.....Good news....Stevekeninverse wrote:Spoke to Roman. He's amenable to the idea of releasing the smd gerber layer to the public so we can get some stencils. No reason for all of us to each buy one so maybe we can pass a few around?
Will have vinyl switch / slider covers in a few days in 6 colors:
black / white / blue / red / yellow / orange
The ones from that kit pictured above look like the ones from Mouser (The ones on microminiatures website do not). It these are the same - they will most likely crack on the sliders.
Might offer kits but no green color available.
Buchla format cases & parts - Buchla 200s series clone PCBs & panels - www.samodular.com
black / white / blue / red / yellow / orange vinyl caps available in a few days.
Might offer kits but no green and grey color available.
