Bozak DJ Mixer Clone - Opened up
Nejrup
Post by Nejrup » Wed Oct 30, 2019 5:42 am
Exhale wrote:A quick question.
A BOM of INPUT Card states 2.2nf STYRENE 160V capacitor.
Does it have to be exact 160V ? I suppose not.
The typical styrenes from Xicon are rated at 50V.
Or maybe to go Polypropylene here ?
What capacitor you used at C201L, C201R positions ?
Thanks...
The BOM suggests to go with film instead (https://www.digikey.com/products/en?key ... -4874-1-ND)
I've done it with great results, and I suspect you can hear absolutely no difference between that and a polystyrene cap. If you want to stay absolutely true to the original and go for styrene, ebay is the way to source.
FS/FT: Glensound Mixer
WTB: TINIJAX! Buchla 285e, 258e, 291e, Buchla Sequencer
https://soundcloud.com/nejrupmusic
Exhale
Post by Exhale » Wed Oct 30, 2019 6:53 am
Turned out absolutely not necessary.
Because you won't able to find styrenes at 160V that easily.
And 50V is more than enough on that position.
Cause it's located in a signal chain, providing treble shelf eq frequency as I understood.
So, no need for 160V.
But PP also shall do the job perfectly.
home_listening
Post by home_listening » Sun Nov 03, 2019 1:01 am
Anything mentioned will work, main rail is only 40V. I bought a huge lot of 160V polystyrenes and included them with the PCB and Panel sets I sold, hence the voltage in the BOM.
Image[/img]
Krachluigi
Asking for a friend...
Post by Krachluigi » Tue Nov 26, 2019 4:59 pm
Are there any PCB´s out there?
Or anyone up for another run? :)
muzo
Re:
Post by muzo » Wed Jan 29, 2020 5:07 pm
I used EPCOS / TDK Epcos MKP cap for C201 and works nicely.
Mi-homme, mi-jambon
50% human, 50% cheese
muzo
Re: Asking for a friend...
Post by muzo » Wed Jan 29, 2020 5:08 pm
Last set from my side if you need.
Check your PM.
Mi-homme, mi-jambon
Krachluigi
Re:
Post by Krachluigi » Thu Jan 30, 2020 5:51 pm
I/Ø wrote:
Thu Oct 26, 2017 5:42 am
Thanks for sharing!
I was recently talking with a friend about the Bozak Isolators, which seems pretty hard to find...and we found your website, great work!
Some years ago we just found the Pioneer SF850 crossover / discrete isolator schematic
We might finish building some of Mr Eliot´s design ideas:
http://sound.whsites.net/project153.htm
http://sound.whsites.net/articles/eq.htm#s6
So since my PCB set arrived, I was wondering if anyone integrated an Isolator into this build?
Did a little research and apart from this Eliot Sound PCB´s, there is this pretty interesting prebuilt Isolator kit:
https://bozure.com/iso-2-19%e2%80%b3-isolator-pcb/
Furthermore the creator of this PCB made a little passiv DI Box by using Lundahl transformers.
After a whole day of reading about Palmer, Jensen and Haufe transformers I began to question myself, if thats the only way to get a balanced signal...
As far as I get it, there is also a way of using XLR with no connection to the ground pin.
Exhale
Re: Bozak DJ Mixer Clone - Opened up
Post by Exhale » Thu Feb 20, 2020 9:24 am
If somebody is interested, one silver front panel is for sale.
viewtopic.php?f=74&t=227902&p=3204993&h ... k#p3204993
Private message me regarding details.
home_listening
Re: Re:
Post by home_listening » Fri Mar 06, 2020 2:18 am
Hey, if take a look at the original schematics the output wasn't balanced at all, hence I was comfortable just using the RCA connector and not adding XLR too.
In the original the output signal goes to pin 3 of the XLR, GND to Pin 1 and pin 2 is left floating. A better choice would be to tie pin 2 to ground via a 12 ohm resistor so at least the output would be impedance balanced (ish). If you do want to symmetrically balance with a transformer the output amplifier has no trouble driving it whatsoever - look for a 600R:600R unit as there is no need for any stepup.
Thanks for sharing!
selectorsroll
Post by selectorsroll » Thu Mar 26, 2020 7:30 am
hi, has anyone found an off the shelf PSU for this project?
cheers
