Nejrup
- Common Wiggler
Post
by Nejrup » Wed Oct 30, 2019 5:42 am
Exhale wrote:A quick question.
A BOM of INPUT Card states 2.2nf STYRENE 160V capacitor.
Does it have to be exact 160V ? I suppose not.
The typical styrenes from Xicon are rated at 50V.
Or maybe to go Polypropylene here ?
What capacitor you used at C201L, C201R positions ?
Thanks...
The BOM suggests to go with film instead (
https://www.digikey.com/products/en?key ... -4874-1-ND)
I've done it with great results, and I suspect you can hear absolutely no difference between that and a polystyrene cap. If you want to stay absolutely true to the original and go for styrene, ebay is the way to source.
Nejrup on Wed Oct 30, 2019 7:06 am, edited 1 time in total.
Exhale
- Wiggling with Experience
Post
by Exhale » Wed Oct 30, 2019 6:53 am
Turned out absolutely not necessary.
Because you won't able to find styrenes at 160V that easily.
And 50V is more than enough on that position.
Cause it's located in a signal chain, providing treble shelf eq frequency as I understood.
So, no need for 160V.
But PP also shall do the job perfectly.
home_listening
- Veteran Wiggler
Post
by home_listening » Sun Nov 03, 2019 1:01 am
Anything mentioned will work, main rail is only 40V. I bought a huge lot of 160V polystyrenes and included them with the PCB and Panel sets I sold, hence the voltage in the BOM.
Krachluigi
- Learning to Wiggle
Post
by Krachluigi » Tue Nov 26, 2019 4:59 pm
Are there any PCB´s out there?
Or anyone up for another run?
muzo
Post
by muzo » Wed Jan 29, 2020 5:07 pm
Exhale wrote: ↑Wed Oct 30, 2019 6:53 am
I used EPCOS / TDK Epcos MKP cap for C201 and works nicely.
Mi-homme, mi-jambon
50% human, 50% cheese
muzo
Post
by muzo » Wed Jan 29, 2020 5:08 pm
Krachluigi wrote: ↑Tue Nov 26, 2019 4:59 pm
Last set from my side if you need.
Check your PM.
Mi-homme, mi-jambon
Krachluigi
Post
by Krachluigi » Thu Jan 30, 2020 5:51 pm
So since my PCB set arrived, I was wondering if anyone integrated an Isolator into this build?
Did a little research and apart from this Eliot Sound PCB´s, there is this pretty interesting prebuilt Isolator kit:
https://bozure.com/iso-2-19%e2%80%b3-isolator-pcb/
Furthermore the creator of this PCB made a little passiv DI Box by using Lundahl transformers.
After a whole day of reading about Palmer, Jensen and Haufe transformers I began to question myself, if thats the only way to get a balanced signal...
As far as I get it, there is also a way of using XLR with no connection to the ground pin.
home_listening
- Veteran Wiggler
Post
by home_listening » Fri Mar 06, 2020 2:18 am
Hey, if take a look at the original schematics the output wasn't balanced at all, hence I was comfortable just using the RCA connector and not adding XLR too.
In the original the output signal goes to pin 3 of the XLR, GND to Pin 1 and pin 2 is left floating. A better choice would be to tie pin 2 to ground via a 12 ohm resistor so at least the output would be impedance balanced (ish). If you do want to symmetrically balance with a transformer the output amplifier has no trouble driving it whatsoever - look for a 600R:600R unit as there is no need for any stepup.
Krachluigi wrote: ↑Thu Jan 30, 2020 5:51 pm
selectorsroll
Post
by selectorsroll » Thu Mar 26, 2020 7:30 am
hi, has anyone found an off the shelf PSU for this project?
cheers
home_listening
- Veteran Wiggler
Post
by home_listening » Sun May 10, 2020 12:32 pm
Hi All;
I started a facebook group for builders as, for better or worse, facebook offers the widest reach. As mentioned on my website, I have never been able to offer much in the way of support for this project.
The group is called "Fabric Astronaut Engineering Pathos Builders Alliance." and I'd suggest asking questions there so the hivemind can help out. Answers will then be available to all rather than getting burried in a PM.
RePost from the group:
"Hi All. Thanks to everyone who has decided to undertake this project. I really appreciate it and view it as a great support of my work.
However, I have extremely limited time as I am busy with work in addition to audio projects. I was only ever able to offer limited support to people who purchased the PCBs directly from myself and had no plans to offer any support to others. Assisting with builds has been a great chance to meet interesting people from around the globe - but I have to be practical about my situation. I appreciate your understanding.
Its likely that some fantastic people other than myself will be able to answer faster than I can, so I have decided to start this group.
If no one can answer your question, just try it. This is DIY after all and bumping heads with failure and errors is part of the fun, it has to be. If you were after a mixer with no struggles at all, then I have to suggest you purchase a fully built unit.
Progress is not a straight line.
Ask a question with plenty of photos where possible. Please clean your circuitboards with isopropyl alcohol before taking photos of them so that we can clearly see what is going on."
Kind regards -HL
fragletrollet
- Veteran Wiggler
Post
by fragletrollet » Tue Aug 11, 2020 9:42 pm
Anywhere to get the pcb's and/or files?
Luka
- Super Deluxe Wiggler
Post
by Luka » Thu Aug 13, 2020 4:55 am
If you sign up to the facebook group some members are selling pcbs
soup
- Veteran Wiggler
Post
by soup » Thu Aug 13, 2020 11:29 am
There's someone selling pcb's/faceplate in BST. It looks like the files were taken down from fabric astronaut's site, maybe they could get posted here for those who don't fuck with facebook?
Tonescape
Post
by Tonescape » Thu Aug 13, 2020 12:34 pm
I'd be happy to host the files if someone can confirm that it would be ok. Not sure which license it is released under?
roger
Post
by roger » Mon Jan 11, 2021 5:33 pm
home_listening wrote: ↑Sun May 10, 2020 12:32 pm
Hi All;
Hi, can you or someone else link the group? I am unable to find it under any of the given names/words. Got some juicy beginner questions to ask
Suf-fuD
- Common Wiggler
Post
by Suf-fuD » Sat Jan 16, 2021 7:38 am
roger wrote: ↑Mon Jan 11, 2021 5:33 pm
Hi All;
https://www.facebook.com/groups/1080577452325250
roger
Post
by roger » Sat Jan 16, 2021 4:46 pm
Thank you!
