SORRY, MY CAPS LOCK IS STUCK ON (A COMMON MACBOOK PROBLEM, EVIDENTLY)
BARE PCB: $40
STUFFED AND TESTED PCB: $200
NOTE: THERE ARE A LOT OF VERY SPECIFIC RESISTOR VALUES IN THIS BUILD (LIKE, 56 DIFFERENT SPECIFIC VALUES) THAT ARE A REAL PAIN TO ORDER. ALSO, I HAVE HAND-SORTED ALL OF THE CAPACITORS INTO 0.1% BINS FOR THE UTMOST ACCURACY FOR THE TWO DOME FILTERS. HENCE, THE EXTRA $160 FOR STUFFING AND TESTING THIS BOARD IS A REAL BARGAIN. NOTE THAT THIS IS BASED ON MY NORMAL HANDBUILT PRICING SCHEME OF CHARGING DOUBLE THE PRICE OF THE PARTS PLUS THE COST OF THE PCB. THIS BUILD TAKES SEVERAL HOURS, SO IT'S A BARGAIN.
JUST SO YOU KNOW, I WILL NOT BE SELLING KITS. IF YOU WANT THE RESISTORS, YOU HAVE TO ORDER THE STUFFED AND TESTED BOARD.
AS I SAID BEFORE, I'M GOING TO DEVELOP A VERSION OF THIS BOARD WHICH IS A STACK OF THREE BOARDS 2" WIDE, SO IF YOU WANT THAT INSTEAD, PLEASE SPECIFY. ALSO, IF YOU WANT ONE OF THESE, PLEASE SEND ME A PM. DON'T CLOG UP THIS THREAD WITH REQUESTS -- THANKS.
