Something New from Doc Sketchy
Dcramer
Re: Something New from Doc Sketchy
Post by Dcramer » Sat Feb 20, 2021 5:17 pm
Dr. Sketch-n-Etch wrote:
Fri Feb 19, 2021 2:21 pm
Sure, but give me a week or so to sort out all of my other orders (plus I ran out of some parts so I'm waiting on a Digikey order before I can finish a couple of orders).
The 3-PCB stack is nice, and only a couple of inches deep, but it's also a couple of inches thick. The single PCB is much deeper but is only one board so not very thick. The only thing is that I can only connect wires to the single PCB with vertical pin headers, whereas I can use sideways (90-degree angle) pin headers on the board stack, so the connections do not add to the thickness of the stack. The vertical connections render the single PCB almost as thick as the stack. Plus, it's just a lot nicer for me to work with the smaller boards.
The Euro panel for this module only needs to be 4HP to accommodate all the stuff, but it should probably be 8 or even 10HP to accommodate the width of the board stack. I'll work up a couple of designs and you can tell me what you think. There is probably no virtue in making it too small, because it's harder to wiggle.
:party: Sounds awesome Doc, 3 stacked boards would be great and there’s no issue with panel width for me, 8-12 hp is fine! :tu:
Dr. Sketch-n-Etch
Post by Dr. Sketch-n-Etch » Sat Feb 20, 2021 8:07 pm
McIntosh wrote:
Sat Feb 20, 2021 7:03 am
I have 75mm to the back of my diy 3U case, how deep is the triple stack in total? 10Hp or even 14 Hp is cool with me, i like to have room to wiggle, defiantly an effect you want to wiggle! your prices are very reasonable considering the price of what other Frequency shifters go for, never thought i ever get my hands on one.
Concerning my prices, I do this for fun. I could never sell things at this price if this were my livelihood. The parts aren't that expensive, but this is all pretty time-consuming. I probably earn well less than minimum wage from all this stuff. I do this for gratification rather than profit. If I can make enough to cover my (ever increasing) Digikey and Small Bear costs, then I'm happy. Even so, though, most frequency shifters are a ripoff. The Encore one is a decent price, but many others are just ridiculous.
If you mount the stack perpendicular to the panel, then the boards themselves are 2.1" wide (about 53 mm). Only the top board has any panel connections. Depending on how you do the connections, you could almost mount the boards flush with the panel. However, you'd probably need at least 0.5 to 0.75 inches (10 to 20 mm) of clearance to bend wires. It can be done, but it's a bit of an engineering problem. The panel PCB can be fitted with 90-degree-angle pins. You could even put the pins on the component side of the panel PCB and bring the wires around the sides.
The board stack is probably a little bit less than 2" thick, but it has to be mounted to something. If the panel were 12 HP wide, then the boards could be mounted parallel to the panel. Also, the panel PCB could be organized with mounting holes that would line up with the corners of the Freak Shift PCBs That would probably be the way to go. The wiring may make the back of the unit a little wider than 12HP, but it would be deep enough that it probably wouldn't interfere with the modules on the sides. It might not like being mounted at the end of the rack, though, because the wires might impinge on the wall of the case.
If you want to do it this way, I'll work up a design. I think our friend J Daniel Cramer would also be interested in this design, since he wants a eurorack version (and he says that HP is not an issue).
A dewdrop can exalt us like the music of the sun.
McIntosh
Post by McIntosh » Sun Feb 21, 2021 8:43 am
It shows that your in it for the love and enjoyment it brings to people, not enough of this attitude, your a rare breed.
"If the panel were 12 HP wide, then the boards could be mounted parallel to the panel. Also, the panel PCB could be organized with mounting holes that would line up with the corners of the Freak Shift PCBs That would probably be the way to go"
This sounds great I'm in. I wait with baited breath.
This world of abundance
Dcramer
Post by Dcramer » Sun Feb 21, 2021 11:06 am
Yup :tu: that sounds good to me!
soup
Post by soup » Sun Feb 21, 2021 11:17 am
First off wonderful work Doc. :tu: It got me dreaming of a building a frac version. Frac's a bit different than euro but I just don't see how 12hp would be possible. There's only a little more than 4" between the rails. Parallel to the panel I think you'd need at least 28hp.
KSS
Post by KSS » Sun Feb 21, 2021 2:09 pm
Frac has 4-1/4" between the rails and at least 6-1/2" deep. Use of the available depth is how it would work for all classic Blacet -and PAIA- Frac boxes.
soup
Post by soup » Sun Feb 21, 2021 3:03 pm
I know the frac dimensions, it's euro I'm not too sure about. I have a number of shallower cases so was daydreaming about pcb's parallel to the panel and figured it would have to be 4 fracs wide. It was the 12hp number I was confused about, I think that's only possible if the pcb's are perpendicular to the panel and the module is at least 6" deep?
Dr. Sketch-n-Etch
Post by Dr. Sketch-n-Etch » Mon Feb 22, 2021 2:15 pm
I messed up.
The boards are 5.6" long, so they cannot be oriented vertically behind a eurorack module. They would have to stick straight back, and would therefore require about 6.5" of clearance behind the panel (to also accommodate the panel PCB and the mounting hardware).
Gawd, I hate eurorack.
Bottom line: Unless you have a super-deep case, forget about this for eurorack. I may have to get proper SMD boards made, and then we'd be in business. Maybe I'll pursue that with a local manufacturer, but it won't be until the spring.
Also, if you want to make an order, please send me a PM. In the PM, please give me your email address (so I can send a Paypal invoice) and mailing address (so I can estimate shipping charges). Thanks!
McIntosh
Post by McIntosh » Mon Feb 22, 2021 3:10 pm
Bummer, I was so close!
yeah, Eurorack is a bit small but it's the format I choose, really wish Intellijel would jump on this, or whoever, I would be over the moon if you pursued a SMD version. I have no problem waiting, he who waits....
Appreciate your efforts on this!
Dcramer
Post by Dcramer » Wed Feb 24, 2021 9:51 am
It still works for me :guinness: I’ve got like a foot back there! :cloud:
Dr. Sketch-n-Etch
Post by Dr. Sketch-n-Etch » Wed Feb 24, 2021 4:59 pm
Hey Dcramer, drop me a PM with your email address and I'll set you up with a Paypal invoice.
Dr. Sketch-n-Etch
Post by Dr. Sketch-n-Etch » Wed Feb 24, 2021 5:09 pm
So, lastnight I had a dispiriting experience. I bought 100 of each value of capacitor I use in the Dome filters of Freak Shift and set about sorting them into the 41 bins (from 980 to 1020) for each value. I had reasonably expected to find, for 5% tolerance caps, a more or less Gaussian distribution of capacitance around a mean value of 1000. What I actually saw, at least for the 1nF and 10nF caps, were a ton of values less than 980 (from 950 to 980 -- they still fall within the 5% tolerance, but they are all clustered at the low end of capacitance). I don't have bin bags for any values less than 980, and my "<980" bags are now chock full of caps. That means that I'll have to create up to 30 more bags and sort those caps. This is becoming a little bit untenable. Probably what I'll do is combine caps into bags covering two adjacent values (say, 993+994), which will only give me 20 bin bags, and then I'll create 15 more bin bags for the low values down to 950.
It really doesn't matter too much. If I have a lot of caps at, say, 970, or 960, then as long as all the values are at that mantissa, I can still build very accurate Dome filters from these caps. I have an Excel model of the filters which allows me to put actual cap values in and look at the phase displacement error, and I find that even if the caps fall within a range of capacitance of up to +/-0.5%, I can still get very close to the minimum phase error. For example, if I have, say, four 10nF caps at 1002, 1004, 1005 and 1008, the model allows me to place those caps in specific locations within the filter circuit to minimize phase error (typically, that entails putting the 1002 and 1008 on one side, and the 1004 and 1005 on the other side). It just adds to the time required to stuff the filters.
It just sucks that the cap values are skewed low, as it just makes my job that much harder.
devinw1
Post by devinw1 » Wed Feb 24, 2021 5:35 pm
Ah, yes that is fun stuff. I have seen this sort of thing, sorting extremely tight tolerance ceramic sleeves for a fiber optic project and with wavelengths of sorted laser diodes.. You expect a Gaussian distribution within the stated bounds, but then it turns out that the manufacturer is dipping into to the distribution to either sell another company large amounts of a certain range or something similar, which skews the distribution. There are other factors that can skew the distribution, but that is certainly common. It may very well be that if you buy a huge bag of them from a different vendor (digikey vs mouser or something) that you get a way better distribution, but you're gambling of course. And you don't want to be buying thousands of caps you'll never use. Ayiyi!
Huba-Swift
Post by Huba-Swift » Thu Feb 25, 2021 9:28 pm
I recall when I was building Jurgens Freq shifter's dome filter, the capacitors were measured and two resistors were chosen for each one based on that value, eliminating the need for precision capacitors. Is this possible or is your use case different?
revtor
Dialing it in..
Post by revtor » Fri Feb 26, 2021 6:53 am
And why these things get expensive... (time!!). Bless the Docs heart!
Fellow North Jersey Synthaholic
Moog$FooL$
Broke Dick Dog
Post by Moog$FooL$ » Fri Feb 26, 2021 12:26 pm
i have to wonder if it's not time for "Doc" to take a page from Ken Stones' book & get someone else to make pcb's?? thusly cutting down on that.... (time!!)
i use to drink & smoke.
that fat cat had to go..... wasn't even mine.
KSS
Post by KSS » Fri Feb 26, 2021 3:41 pm
Nah. That flies in the face of what he wrote about how and why he does this. It changes everything. And not necessarily in a good way. For the Doc.
I'm glad he's doing it his way.
Dr. Sketch-n-Etch
Post by Dr. Sketch-n-Etch » Fri Feb 26, 2021 5:02 pm
The thing is, those resistors still need to be ordered, and since there is so much variation possible in the caps, I'd have to stock every single resistor value around the mean. Also, the absolute cap value is not really an issue. As long as the caps are "near" 1nF, 10nF, 100nF, and 1uF, they can really be anything within the +/-5% range. It's just that all filter stages need to use caps with the same mantissa. Hence it can be 1.024nF, 10.24nF, 102.4nF, and 1.024uF -- that works very well -- it just shifts the frequency range up by about 2.4% from design (so, instead of 0.1Hz to 10000Hz, it goes from 0.1024Hz to 10240Hz -- no big deal at all). It's just that I need to have enough caps within each mantissa for this scheme to work. I can mix values across about a +/-0.1% range without any fuss (so, from that example, I could use 1.023nF, 10.25nF, 102.4nF, and 1.023uF and I wouldn't be able to tell the difference, even in the simulation). It's just that this level of accuracy requires dividing up the caps into many bins, and most of those bins will be either empty or nearly empty. I end up with clusters of values around a mean, and I have to use those. So far, I've been lucky and have found combinations of values which give almost the optimum performance.
Dr. Sketch-n-Etch
Post by Dr. Sketch-n-Etch » Sat Feb 27, 2021 1:34 am
This is just an announcement to tell you that, if you ordered stuff from me a couple of weeks ago (I'm talking to you vtl5c3, kdjupdal, leverkusen, and deepblackjoe), then your orders are completely done and sitting on my bench. I was extremely busy with university work this week, and did not have time to pack things up and go to the post office. However, I'm planning to pack everything up this weekend and hit the PO on Monday.
Then I can get started on all the new orders I've received since then.
Dr. Sketch-n-Etch
Post by Dr. Sketch-n-Etch » Tue Mar 02, 2021 8:52 pm
UPDATE: vtl5c3, kdjupdal, leverkusen, and deepblackjoe: all of your orders have been shipped, with tracking. I'll email y'all the tracking numbers.
(Gawd, it was expensive. Next time I ship stuff, I'm expecting to have to give up a kidney. The postal service is a scam.)
regularjackson
Post by regularjackson » Tue Mar 02, 2021 10:48 pm
For sending stuff to the USA, I highly recommend using chitchats. You buy usps postage from them, they drive it over the border. I use it all the time, you’ll save a bundle and it’s quick and as reliable as usps is. Chitchats.com
Also avoids customs charging on the other end.
