Well, there's a lot of circuitry in there! Two complete Dome filters (one 12-stage, the other 18-stage), two four-quadrant multipliers and two output amplifiers. And those PCBs are stuffed (although there is a tiny bit of wiggle room on the top PCB). To get the Dome filters to fit onto these euro-sized PCBs, I had to break my own rule and install ICs without any space in between. The 9 TL072s in the 18-stage Dome filter are all smashed together, so that they take up 3.6" of length. This can be done with 8-pin ICs, but not with 14-pin ICs like TL074s. Those must have a 0.1" space between because they are actually the same length as 16-pin packages, so if you try to install them without a space in between, you have to grind a bit of the package down on the edges. I learned that the hard way. But, with 8-pin ICs (and, presumably, 16-pin ones as well) you can put them right together. The challenge then is to fit all of the associated circuitry, and to arrange the necessary traces, into the 0.4" space of each IC. The 18-stage Dome filter is my favorite layout ever.
Something New from Doc Sketchy
- Dr. Sketch-n-Etch
- Super Deluxe Wiggler
Re: Something New from Doc Sketchy
Power spent passion bespoils our soul receiver
Surely we know.
Surely we know.
Doc, how well would 1% caps work with no binning for further accuracy by the builder?
- devinw1
- Contact:
Yes, of course, and I hope you didn't take that as a knock! I always love seeing your creations and have much respect for your artisanal builds!
The dome filter layout is indeed nice. It always feels great to have such a nice symmetry to these things.
Wow, impressive!!
I think the now discontinued RS-240 is 122 mm deep.
//M
//M
- Dr. Sketch-n-Etch
1% caps would probably be OK. On top of the 1% accuracy of the resistors, this would give a maximum 2% error. I just ran this through my simulation (adding and subtracting random numbers bounded to 2% of the target from the RC factors in the filter) and the predicted phase displacement can be quite far off, as much as a 2 degrees off of 90, but is typically within 1 degree.
Surely we know.
Surely we know.
- Dr. Sketch-n-Etch
You can buy an RS-240 from Big City Music today for $2,199. You could get seven Freak Shifts for that. However, the RS-240 does have a VERY BIG KNOB.
Surely we know.
Surely we know.
- Dr. Sketch-n-Etch
Actually, I came by the thread today to tell you all that I tested the "new and improved" euro Freak Shift this morning with my trusty electric guitar, and it worked perfectly. It's now just waiting for a nicer panel, and it will be shipped to McIntosh.
I actually put a new panel on it as well. The graphics are still a little messed up, but it turns out that I drilled the holes for the jacks slightly too low on that first panel, and it was stressed and slightly curvy. I had another panel which I hadn't drilled yet, so I drilled the holes about half a millimetre further up, and that panel slid onto the panel components with ease. It turns out that the centre of the jack on those damned Thonkiconn jacks is not quite aligned with the 0.1" grid (although the solder tabs are), which makes it a pain to put in my layouts. However, I copied a mechanical drawing of the jack into Excel, resized the drawing until the solder tabs fell on my grid, then put another dot where the centre of the jack actually is, and found it to be about 0.5 mm away from where I had it. I moved the jacks in my FPD panel file, then made a PDF of that and copied it into my Excel layout file, and was able to see that the new jack hole locations on the panel are more or less perfect.
Surely we know.
Surely we know.
The RS-240 sound very good. Your two variants also sound very good.Dr. Sketch-n-Etch wrote: ↑Fri Apr 02, 2021 5:28 pmYou can buy an RS-240 from Big City Music today for $2,199. You could get seven Freak Shifts for that. However, the RS-240 does have a VERY BIG KNOB.
I’m still saving up for your 5U FS inc VCO but now with the Freak Shift “light” I’m not sure which one to get...
//M
Yup, I hope to have something up this weekendDr. Sketch-n-Etch wrote: ↑Fri Mar 26, 2021 9:04 pmWell, I wouldn't mind just something "quick and dirty" with some of your experiments, not necessarily your usual masterpiece. I'm just really curious to see how a "real" modular musician uses this thing. (If you've seen any of my videos, then you'll know just exactly how low my standards really are.)Dcramer wrote: ↑Fri Mar 26, 2021 7:11 pmHey Doc, yup it fits, of course when you look along the back of my rack it’s the only one sticking out!
Yes, I’ll get a video done, I’m actually several videos behind, so it may take awhile.
I’ve done all kinds of experiments with it, being able to put anything into it makes it so creative![]()
Of course I goofed around with the thing all night and ended up with over an hour’s worth of footage
The new boards look great Doc
Be the modulation you wish to see in the world
https://www.patreon.com/join/jdanielcramer
http://queertunes.bandcamp.com
http://m.youtube.com/user/jdanielcramer
http://soundcloud.com/dcramer
- Dr. Sketch-n-Etch
I'm really looking forward to seeing (and hearing) some of your footage, Dcramer!
Surely we know.
Surely we know.
and the obligatory Euro thread in the hopes that it'll be the next Beads
viewtopic.php?f=16&t=246966
Brilliant work, its the little details that make the difference. I am so inspired, I decided to build myself a new deeper case so the Freak Shift has plenty of room to freak out, and room for more Future Doc Skectchy lab modules!
Lovely tones, woody and squelchy, brilliant.
This world of abundance
- Dr. Sketch-n-Etch
Dcramer, that was FREAKIN' AMAZING!!!!!! I think you are now my grandfather!
Surely we know.
Surely we know.
- Moog$FooL$
- Broke Dick Dog
so great!! nicely done Dcramer.... you do a good job of showing some things i definitely wouldn't know of. u seem to know your synthesis quite well.
i use to drink & smoke.
that fat cat had to go..... wasn't even mine.
That was truly awesome Dcramer, thank you!
//M
//M
- zengomi
- Wiggling with Experience
- Contact:
Thank you, Dcramer. Well done!
Ready to freak, Doc.
USTA primitivo
- Dr. Sketch-n-Etch
Just remember, if you PM me about wanting a module, please tell me:
a) your email address (so I can send a Paypal invoice)
b) your location (so I can calculate the proper shipping cost)
Thanks in advance, bitches!
Surely we know.
Surely we know.
- Dr. Sketch-n-Etch
I don't expect to be making any more of the big ones. If you want to buy my existing 5U unit, I'd be happy to sell that to you. However, I think that the Freak Shift is actually quite a bit more versatile than the big unit, because of the ability to use external modulation sources. If I'd have known how good that was going to be, I never would have bothered with the bigger unit, because the quadrature oscillator is about 70% of the circuitry in that unit.
Surely we know.
Surely we know.
- Dr. Sketch-n-Etch
I just wanted to let people know that, if you have ordered or are in the process of ordering a Freak Shift, I probably won't be processing the Paypal invoices for a week or two. I don't like collecting money for stuff long before I can deliver it, and I won't be able to deliver any new Freak Shifts for at least three weeks (shooting for the last week of April) because it is going to take me that long to get the new panels.
At last count, I have 9 people who want Freak Shifts, and that's just from today. I'm writing y'all down in my little black book, and I'll send y'all Paypal invoices later this month. In the meantime, I'm going to start etching and drilling and stuffing and soldering PCB sets, to try to build up a bit of an inventory for when the panels come available.
Surely we know.
Surely we know.
- Moog$FooL$
- Broke Dick Dog
i think he may just have some help from a friend..... at least with the stuffing & soldering.
- Huba-Swift
- Ultra Wiggler
I read through the whole thread again today and have a question about your Polaris filter (which looks absolutely mind-blowing btw). You have modes labeled 1-4 and 1-8 on the two scanners, but what are the actual modes it' scanning in-between on each slider? I don't understand how that lines up with the 6 modes and 5 types on the production module.
- Dr. Sketch-n-Etch
It doesn't. My version has more modes than the production module. There are four banks of 8 modes on mine. This is because I am using a 4-channel scanner and an 8-channel scanner, so I have 32 possible modes. There is, in fact, an almost infinite number of modes possible, but most of them are useless. I identified what I consider the essential modes. I think I put a table in somewhere.Huba-Swift wrote: ↑Sun Apr 04, 2021 10:06 pmI read through the whole thread again today and have a question about your Polaris filter (which looks absolutely mind-blowing btw). You have modes labeled 1-4 and 1-8 on the two scanners, but what are the actual modes it' scanning in-between on each slider? I don't understand how that lines up with the 6 modes and 5 types on the production module.
Incidentally, I got rid of that module (I basically gave it to a buddy). If I did that again, I would not use an interpolating scanner, but would instead just switch between modes with analog switches, or even panel switches (or, most likely, the latter sending 5V logic to the former). This would make the module far less complex, and I'm not convinced that the interpolation is useful anyway.
Surely we know.
Surely we know.
- Huba-Swift
- Ultra Wiggler
Ahh, I see. I was really curious as to how scanning through various filter modes could be used, and how it would sound, especially when being modulated by CV. Too bad to hear it might not have been worth all the added complication.
- Dr. Sketch-n-Etch
Just a reminder: If you send me a PM requesting a module (such as the Freak Shift), please PLEASE give me your email address and TELL ME WHERE YOU LIVE so I can figure out the shipping cost. (I'm looking at you, alanalan, thisoldhouse, and Fayette...)
Incidentally, I'm sitting on 13 Freak Shift orders right now (including 2 orders from one customer). I'm a little nervous about that.... Tonight I finished two sets of boards (all except the Dome filter caps because I'm waiting for a shipment). I'll keep plugging away, making two boards every two or three days, so that I'll have them all built and ready to go by the time I get some panels.
Surely we know.
Surely we know.
- Dr. Sketch-n-Etch
I've now got 18 orders as of 6 March. I've sent all interested parties a PM informing them that they will soon be receiving Paypal invoices. If you have expressed interest but have not received a PM reply, please let me know. I've got a list with 17 names (somebody wants two units, so he has two positions in the queue), so I know who you are and I think I have all of your email addresses and locations (except maybe one). So yeah, I've started making boards. I've got two sets all made and stuffed (except for some missing film caps for the 180-stage Dome filters and some mounting hardware, all of which is en route from Bangkok as I type this).
Two down, 16 to go.......
Surely we know.
Surely we know.
