dimensions are here: http://www.futuresoundsystems.co.uk
why on earth didn'they make it fit for eurorack ??? 5-6 mm less and It would have been OK...
I'm guessing it was deliberateautodafe wrote:just got my kit in the mail today, wil build it in a couple of days.
We've had a couple of other users report that changing R5 still doesn't get their envelope triggering. The fix for this, seemingly, is to strap a 100k resistor between pins 2 and 3 of the right-most TL082 IC (the TL082 beneath the power switch). Doing so should put the gate comparator into action for +5V gates, with R5 changed to 47k also.earlneath wrote:The thing l'm wondering is how to gate control the Brunswick using CV from an external controller? CV Pitch from a beatstep or keystep into 1V/Oct in on the Brunswick controls pitch no problem. But how to send gate (on/off) signals to the Brunswick using CV Gate from a controller? I have tried patching from CV Gate on an Arturia beatstep and keystep's to the Brunswick's Envelope Gate with the CV Pitch going into 1V/Oct In on the Brunswick. That isn't successful.
Thank you! That's handy!futuresoundsystems wrote:Also, we're working on a manual for release, hopefully, by the end of the year. However, in the meantime, for those out there who are a little confused by the signal routing on this thing, we've drawn up a signal flow diagram, which can be downloaded here.
The FSS post above yours includes a link to the schematic, a PDF version, and I'm attaching it here as a file attachment.csaban wrote:I saw you guys using the schematics in the thonk youtube video, is that available? Or will that be part of the manual?
I've also had problems with triggering, with both changes in place I can't get mine to 'go'. I'll take another look soon I hope (too many other things on the go!) — I'll try turning the control like you say (thanks!)autodafe wrote:maybe I'm an idiot...but th VCA ENV2 controll needs to be cranked all the way up for the Gate/Env to work at all...(thanks to FSS support)
BOM is here -hofmann25 wrote:Maybe I'm missing something. But, I can't find the BOM.
