New buchla 208 card 12,demo sound diy or built pcb no MB mods
Available 40 eu the pcb
208X 200X modules serie ,Buchla 200 upgraded viewtopic.php?f=17&t=243688&p=3444875#p3444875
FS :custom buchla 203 style càbinet ,skiff new design,boat ,hardware for diy cabinet ,easel case ,new 1u to 10u to 56u and more. / New 208 buchla card 12 price down atm/
HQ small case buchla psu PCB
viewtopic.php?p=3118393#3118393
viewtopic.php?t=211862&highlight=
top/bottom layouts
first notes
first notes
a lot of important built infos added
- Virusinstaller
- Common Wiggler
Thanks Welcome
Last infos/motherboard mod added
a few pcbs available from the first batch
- captnapalm
- Veteran Wiggler
thanks,which film caps did you choose ?mkt mkp etccaptnapalm wrote:I have a Mouser BOM built; my PCBs should arrive in the next week so I'll test before I share the BOM.
and which 4 x Aop U1?
u2 /u3 available at mouser
TLC081 is not TLO81 !
tlc081
OPA134
- captnapalm
- Veteran Wiggler
I didn't include U2 because you hadn't posted about alternatives yet so I bought NOS LME49740 from eBay.
I used the same OPA134 as your link, for TLC081 I used this one which is same as your link but wider temp range.
Film caps I used PP, various ones depending on size etc. Will check before posting the BOM.
LME 49740
- captnapalm
- Veteran Wiggler
Ahah!captnapalm wrote:Boops recommends TL074 in the updated description.Karl71 wrote:OPA4277 looks like a likely replacement for the LME49740. Any other suggestions.?
I might do a comparison when I get around to the build. The OPA4277 is €9 from mouser. Im curious what the extra € 7 gets me in fidelity.
i ve written the cheap Tlo74 should work,i ve not recommended it,its not a really , high end aop .
- captnapalm
- Veteran Wiggler
Plenty of 4 x aop work ,just check the pinout
the lme 49740 i ve choosen is great ,the tlo74 is more standard ,and the pinout works .Im a diyer ,myself,and i alway try to be in a diy behaviour,some time not so easy
Sorry for the confusion
OPA4277PAKarl71 wrote:OPA4277 looks like a likely replacement for the LME49740. Any other suggestions.?
dip14
4277
let know ,how it sounds .
- captnapalm
- Veteran Wiggler
a few more infos
the motherboard mod is needed for a smooth control of the reverb imho
-the right jack socket is the direct audio out MO by default (or the CO if you choose it),it has a 100 % level no reverb
main outputs schematics added
- Attachments
- 547F8309-D506-4BCE-A6DD-2BFC7554C7A1.png (132.04 KiB) Viewed 155 times
- captnapalm
- Veteran Wiggler
Here is a Mouser BOM. This does not include a quad op amp U2, IC sockets, or the J2 & J3 headers/plugs for reverb cables. I built mine with this BOM and everything works great. I only changed C7/C8 after I built mine because the form factor was big. C13 is also big but there’s room for it, and Mouser didn’t have a smaller one for that value.
https://www.mouser.com/ProjectManager/P ... 46bb3779c5
