On the Boops card if you want behavior like the original you can bridge them the same with a small wire or resistor leg:
If you want the behavior like Boops describes, you can take the output from the wiper on channel B pot:
Other options are possible if you want to experiment. I tried sending the CO output directly in before the gates, but it gave a lot of bleed so I abandoned that approach.
