performer (or is it per|former?) sequencer build
- sduck
- experimental use of gravity
Re: performer (or is it per|former?) sequencer build
That's the error you get when your connector isn't connected right somehow. I hope you tried reversing the jtag connector?
- Learning to Wiggle
Did I need to power the module from the eurorack rail or the st-link will give the 3,3v? I know in other cases is need to extrenally power the unitcnicht wrote: ↑Mon Aug 10, 2020 7:36 amJust use the hex files on GitHub and ST-Link Utilty
https://www.st.com/en/development-tools ... nk004.html
Yes, I tryed both. I will duble check, but noresponse at the moment. Can you please confirm if it is necesary to externally provide power to the module? or the ST-Link is enough to program it?
Yes, you need to power the Performer, impossible to upload bootloader or firmware without power.
I've also had that message when I've had the jtag connector the wrong way round.
How are you connecting from the ST Link to jtag?
I paid for one of the olimex adapters having had problems trying to bodge my own st link - jtag cables.
Hi!.woodster wrote: ↑Mon Oct 19, 2020 4:21 amYes, you need to power the Performer, impossible to upload bootloader or firmware without power.
I tryed with power but no good news. I use the St-Link to Jtag conector, I will upload two fotos, one of the board and one of the adaptor.
I thing I have all the required components soldered to program the board.
You might want to check for shorts across the pins of the JTAG header. Do you have an illuminate loupe/magnifier? I'd definitely invest in one, if you haven't already. They're invaluable for situations like this.PabloSrNaranja wrote: ↑Mon Oct 19, 2020 5:30 amHi!.
Is the ST-Utility program recognising the ST-Link?
I've had a few glitches with mine and there is an option in the menu to connect/update.
Ye, all checked and good. I have a Loupe and I also use my smartphone macro as a viewer, it works nice.toneburst wrote: ↑Mon Oct 19, 2020 6:29 amYou might want to check for shorts across the pins of the JTAG header. Do you have an illuminate loupe/magnifier? I'd definitely invest in one, if you haven't already. They're invaluable for situations like this.PabloSrNaranja wrote: ↑Mon Oct 19, 2020 5:30 amHi!.
Thanks for the help.
I just got the launchpad mini MK2, everything is working fine but I have a slight artifact sound when holding the "1" button on launchpad.
Does anyone have the same experience? Is it possible to solve it?
Finally managed to program it after a big reflow.PabloSrNaranja wrote: ↑Mon Oct 19, 2020 9:16 amYes, it works nice with other modules and recognice the ST link.
Thanks for the help
hello fine people. i've been digging into some of the routing options and noticing when selecting one of the external CV ins I get unexpected behavior. on a static pattern with no routing applied to the track, i get expected results, but when routing one of the CV ins to transpose or octave shift, the pattern changes with no inputs to the CV in jacks. i checked the monitor and there does seem to be activity there, but not enough of a range fluctuation to get the changes i'm hearing. with routing enabled to transpose or octave, it'll get changes with +/- .03 CV (according to the Monitor page)
here's a screenshot of what i'm seeing, and they all flicker quickly, it's not just a static offset from 0.00v. does this sound like a hardware issue or a calibration issue? sadly i'm not handy with a soldering iron, so hopefully it's the latter. (perhaps someone will identify their own handiwork, it's a pretty unique encoder knob and arrangement of cap colors!)
i shot a video as well, and i'd happily upload it should it be useful, but as i only have mobile phone access to internet and it takes a while to complete the process, i'll wait for someone to confirm.
there is going to be some noise of the cv inputs are not grounded, did you try connecting them to some dc voltage for the same experiment
The CV Inputs are connected to ground if no cable is patched to them.
Are you able to measure the signal on the CV Inputs?
thanks for the suggestions - i took a 1.00v offset and plugged it into the CV ins and the flickering behavior persisted for each track, it only offset each value as shown above.
the more i explore my module, the less confidence i have the build is correct. i've spent days trying to get a midi signal in and out with no success, via the usb and midi jacks. one reason i suspect this - and not that my menu settings are incorrect - is the calibration on the System page (screenshot below): when i check each track, the voltage levels are quite different, even after ensuring there's no voltage (step) applied to the track. i would assume they would all would be figures near each other. this screenshot is track 2, 3 and 4, after verifying on the Monitor page there was no CV on the output (if that even matters.)
sorry for bombing questions on a build page - i'm nearly at the point where i'd pay to ship it to someone who has used the midi implementation to verify mine is functioning correctly. i don't see midi being received on the monitor page or hear it being sent to the correct track routing either. this is despite having a the Midi Input on the Project page set to All, ensuring the Layout page has the correct track set as Midi/CV, and having the correct Routing settings applied (Source set to MIDI Omni) to the track i'm monitoring pitch on.
thanks for reading, i guess determining whether the screenshot below appears correct is the first step before taking action to ensure the build functions correctly.
one easy way to check if midi is working is to flash the testing hex, connect midi in to midi out (with a stereo 3.5mm cable) and then press buttons to generate notes (in the midi testing page), you should see both sent and received matching notes
appreciate the tip! unfortunately i don't have much free time, and so i'd rather not spend what little i have troubleshooting. but your suggestion seems easy enough to figure out in an hour or two.
in the meantime i ordered another din connecter after confirming with the previous owner which brand worked for him. also, i came across sducks amazing video showing off all the variations this sequencer is capable of - and as i've been digging in deeper it was inspiring to learn this thing in and out.. one thing i really enjoy lately is playing with start points and clock division using internal cv tracks in the routing section.
one question for the pros here: has anyone found a way to use the arpeggiator on an internally generated signal? or even on one of the CV inputs? seems its only available on a midi channel, but thought i'd ask anyway. again, sorry for mucking up a build thread, not too many places to discuss this module.
Maybe is my unlucky searches but there seems to be a v1.1 pcb with thonky's. Is this on github? because I can't find it in the zip I downloaded
Hi to all!
I’m getting some troubles calibrating my Performer.
The outputs are really floating (4.7 initial state and after some time it gets to 5).
Do yours perform the same?
pretty sure my board has v2 written on it.. though i glanced briefly and wasn't looking for that info. i think it was earlier in one of the build threads i saw mr MSW proposing improvements, are there two PCB versions out there?
Michigan Synth Works did a limited run with thonkiconns. I think they're currently sold out.
- sduck
There's a slightly modified BOM for these, mainly to do with the button height if I recall correctly.
Where in the same country, but I would like it with a stencil so I can put it in my new oven.
A saw a post on the facebook
Performer Eurorack Sequencer
8 april 2019 ·
Pretty much done with the board revision 1.1. It includes:
So I thought it might be on github since it was posted in 2019.
