performer (or is it per|former?) sequencer build
RogerStrom
Re: performer (or is it per|former?) sequencer build
Post by RogerStrom » Mon Mar 15, 2021 6:25 pm
Hi everyone.
I built my Performer today. Hardwas is completed but I have massive problems getting the STM Cube Programmer running and so I couldn´t flash the STM32 yet. I´m running an iMac on 10.13.6 (High Sierra).
I have a ST Link V2 & JTAG adapter. Have installed Java JRE 8_821 & JDK 15.0.2 as well as STM Cube Programmer 2.5.0.
The app doesn´t start if I click the icon. Starting it in Terminal leads to an error message:
Error: Could not find or load main class com.st.app.Main
Caused by: java.lang.NoClassDefFoundError: javafx/application/Application
If I google this issue it leads always to nerdy Linux discussions in the ST forum but this doesn´t help me to be honest.
I´m not a programmer and don´t know how to modify any command lines in Terminal. So I need a good explanation if lots of steps need
to be done in Terminal (and I may ask some silly questions again, sorry).
Would be grateful if someone could point me in the right direction to get this damn tool working.
I don´t have access to a PC at the monent so the old Mac is my only option unfortunately. Thanks!
0110
Post by 0110 » Tue Mar 16, 2021 11:26 am
Hi everyone.
Not the most elegant solution but maybe easier solution: You could install virtualbox and run the programmer on Windows
https://www.virtualbox.org/
And windows for virtualbox:
https://developer.microsoft.com/en-us/w ... -machines/
0110
Post by 0110 » Tue Mar 16, 2021 1:24 pm
Another tip. On my mac (10.15) only STM32CubeProgrammer worked following the last step of this thread.
https://community.st.com/s/question/0D5 ... 0151-19b88
So you need move /jre folder from your download to STM32CubeProgrammer.app/ .
Finder friendly:
1. Copy "/jre" folder from your STM32 download.
2. Locate STM32CubeProgrammer app.
3. Second click "Show Package Contents"
4. Paste "/jre" inside. You you should see a "/content" folder and the new "/jre"
5. Try to open now.
RogerStrom
Post by RogerStrom » Tue Mar 16, 2021 6:13 pm
After installing OpenJFX and the latest Cube Programmer 2.6 it worked. No chance with V2.5 which I downloaded last week.
My Performer is alive and healthy. Thanks for the helpful comments! Cheers
matjinks
JTAG Flashing pinout
Post by matjinks » Wed Mar 17, 2021 3:54 pm
HI All, I'm trying to wrap my head around the flashing process, I'm a little confused by the JTAG pinout assignments. I'm using a STLINK V2 which has a 10 pin cable, I am using a breadboard to connect this to a mini JTAG board from Adafruit so I can drop the size to a mini JTAG I just need to work out the cables to get them to match I have a diagram on the St LINK case so I can see which ones are which to go to the Adafruit board but out from the board to the JTAG on the Performer is confusing, the RED stripe on the performer PCB gives me orientation but I do not know if the pins on the Performer are in the right config for the cable coming from the Adafruit? I'll add a couple of pics. If anyone has any knowledge about the Perfomer JTAG pinout, or can comment on my breadboard pins please shout.
Altitude909
Post by Altitude909 » Wed Mar 17, 2021 4:58 pm
well, to start, thats not a real STlink. If that will work with is anyone's guess. That being said, its just a question of connecting the right pins so just look at the schematic for the JTAG header and connect things accordingly
sduck
experimental use of gravity
Re: JTAG Flashing pinout
Post by sduck » Wed Mar 17, 2021 9:47 pm
As mentioned, get the right tools and it'll be easy.
https://www.mouser.com/ProductDetail/ST ... cy4w%3D%3D
https://www.mouser.com/ProductDetail/Ol ... dijQ%3D%3D
You might be able to get away with just using the adapter with your stlink thing - I'm not familiar with that one, but it might work.
matjinks
Post by matjinks » Wed Mar 17, 2021 10:16 pm
Got it, will order a real one, thought I could save some $$$
m.
Altitude909
Post by Altitude909 » Thu Mar 18, 2021 6:14 am
m.
Old Polish Proverb: Clever man pays twice. Dont forget a the 10 pin adapter for that, Olimex makes one
sduck
Post by sduck » Thu Mar 18, 2021 9:23 am
m.
That was my second link!
av500
Post by av500 » Thu Mar 18, 2021 9:32 am
to clarify, the "cheap chinese" STLINK clones are the same as the STLINKs that ST puts e.g. on their Nucleo or Discovery boards, they are set to a fixed 3.3V voltage on the target side. And they work jut fine, I have about a dozen of them and so far none has failed. The only drawback is that they don't bring out the NRST line, the pin labeled RST belongs to the SWIM interface for ST8 8-bit CPUs, not to the SWD interface (but you can easily solder a wire from the SWD NRST GPIO to that pin, as I did on a few of mine) - you need the NRST line to program an STM32 *IF* the design also uses the SWDIO or SWCLK lines as normal GPIOs. most designs don't so you can "soft"reset the target via SWD.
av500
Post by av500 » Thu Mar 18, 2021 9:34 am
why the 10-pin? the performer has only 4-pin SWD, simple jumper cables are enough...
Altitude909
Post by Altitude909 » Thu Mar 18, 2021 9:43 am
it does not have SWD. Only JTAG
av500
Post by av500 » Thu Mar 18, 2021 9:44 am
ah ok, well the version I have has SWD :)
vasculator
Post by vasculator » Sun Mar 21, 2021 11:25 am
Does anyone know how one of the multicolor step LEDs might end up being reversed color? Mine turns on and off correctly, but is red when it should be lit green and green when it should be red. Any idea where I might start troubleshooting? Thanks!
SysEx Dumpster podcast - modular, gear, and other garbage
groove
Post by groove » Sun Mar 21, 2021 11:59 am
If your colors are inverted, you installed the LEDs backwards. Rotate them 180 degrees.
av500
Post by av500 » Sun Mar 21, 2021 2:51 pm
or patch the SW :)
replace
_array[index] = { red, green };
with
_array[index] = { green, red };
tupinamba
Post by tupinamba » Sun Mar 21, 2021 6:36 pm
Hey guys!
So after a few months on other projects I'm getting back to my non-working PerFormer...
My 'only' issue is that I cannot calibrate correctly (cannot reach min and max values for -/+5v)
I"ve checked the DAC spec, and I can read 'DA8568C' on the DAC so I think I'm OK.
I've checked its soldering and everything seemed OK but I refluxed and tested with a multimeter (no cold solder joints, no bridges)
I've rechecked all solder joints on the board and everything looked fine (I refluxed the ones that did not look nice)
A few months back, both CV7 and CV8 were stuck to -11v (-5v to 0v calibration) or +11V (+1v to +5v calibration)
For CV1 to 6, I could not reach below -4.1v or above +4.1v
Now, after my reflux, CV1 to CV7 can go to -4.5v ('0' calibration value) and to +4.3v (max calibration value)
CV8 is still stuck at -11v (-5v to 0v, calibration value has no effect) and +11v (+1v to +5v, same thing)
It seems like I solved an issue on CV7 and that this allowed all other voltages (CV1 to 7) to get a little closer from where they are supposed to go. Does this make sense? And if so, where should I look for an issue on CV8?... (I'd say around U15D... right?...)
Thanks in advance for your help!
sduck
Post by sduck » Sun Mar 21, 2021 9:35 pm
or patch the SW :)
replace
with
It sounds like he has just one that's lighting up reversed, so changing the code won't help - he just has to rotate that one. Probably an easier fix anyway.
finnurbjarna
Post by finnurbjarna » Mon Mar 22, 2021 6:41 am
Well I've just finished my build and in a fit of brilliance managed to reverse ALL the LED's :bang: . I don't really mind, though, and don't suppose it matters much?
After reading this thread I was expecting all sorts of issues with the build - height of jacks and buttons etc - and was pleasantly surprised at how straightforward it all was. Other than having to lift the stereo jacks out slightly as well as the encoder (which I bolted to the panel anyway), it all fit together really well.
What an amazing project! :yay:
finnurbjarna
Post by finnurbjarna » Mon Mar 22, 2021 8:06 am
I also meant to ask, does anyone have a surplus window for the Performer?
dooj88
Post by dooj88 » Mon Mar 22, 2021 10:06 am
ooh, you mean like a perspex screen cover? i'd love to know if there's some of these around.
vasculator
Post by vasculator » Mon Mar 22, 2021 10:09 am
or patch the SW :)
replace
with
thanks everyone! yeah this wasn't my build, but i'm going to rotate that LED today. amazed i didn't notice it for months.
+1 on wanting a plexi window for the LCD!
tupinamba
Post by tupinamba » Mon Mar 22, 2021 1:41 pm
Solved!
Cold solder joint on CV8.
Everything seems to be calibrating nicely now... :-)
sneak-thief
Post by sneak-thief » Mon Mar 22, 2021 3:17 pm
FYI for anyone who wishes to invert their LED colours: hwconfig_invert-leds.hex
https://github.com/westlicht/performer/releases/
http://involucija.org - post-industrial euphoric deprogramming. LP coming soon on a+w.
