BUILD THREAD: 18-channel vocoder
glubsch
Post by glubsch » Wed Apr 03, 2019 3:42 am
Here are the links to the three important documents: The spreadsheet is helpful for procurement purposes as it uses corresponding color coding in the left-most column on sheet "Consolidated BOM". Note that this spreadsheet was composed with Excel. I don't know if it is properly handled by spreadsheet alternatives such as OfficeCalc.
Note: the bundle I am offering is not the whole kit. You will still have to order parts from your trusted distributor. There are three Mouser projects available:
derpinguin
Post by derpinguin » Sat Apr 06, 2019 2:21 am
The parts arrived yesterday. So far I can say glubsch did a terific job. Now I have to get all the needed electronic parts and start building. :nana:
synthcube
you will be assimilated
Post by synthcube » Sun Apr 07, 2019 4:39 pm
anxiously awaiting :)
julian
i like synthesisers...
Post by julian » Thu Apr 11, 2019 5:11 am
Can I advise people, early on, to use the LEDs specified in the build docs, and not just what you may have in your draw.
The reason for this is that the front panels have been cut to accommodate the specified LEDs, with minimal clearence.
Each and every front panel has been test fitted with the specified LEDs, for confirmation, but, if you use larger diameter units, they may not fit.
2nd -
The assembly template supplied with the kit does not have a recess in the rear for the LEDs.
If you want to be perfect with the build, I would suggest packing out the pots with a couple of washers when using the assembly template, so as the LEDs are offset against their final position on the actual front panel.
What this will do is create a bit of tension when the final job is assembled, so as to press the LEDs fully home into the final front panel.
We are only talking 0.5mm so it's no big deal, but just for the perfectionists! : )
If the above sounds confusing, read it again when you're using the template and it will make more sense then!
_________
For stocked euro / buchla / midibox see - http://thebeast.co.uk/?post_type=product
For custom cnc engraved panels see - http://thebeast.co.uk/?page_id=21
pinewave
Post by pinewave » Tue Apr 16, 2019 4:22 am
julian wrote:Can I advise people, early on, to use the LEDs specified in the build docs, and not just what you may have in your draw.
2nd -
Thanks for the warning Julian! :)
Any sufficiently advanced technology is indistinguishable from magic. -Arthur C Clark
derpinguin
Post by derpinguin » Thu Apr 18, 2019 4:38 pm
Thank you. When are the panels to be expected?
derpinguin
Post by derpinguin » Sat May 11, 2019 1:29 am
Any update on the front panels?
julian
Post by julian » Sun May 12, 2019 3:57 am
I'm sorry, the panels are my delay, not Stephen's.
There's no issue. I've just been ill, and now have to be away a couple of days. The metal work is all cut and ready for print - I've just not actually printed it yet.
_________
derpinguin
Post by derpinguin » Sun May 12, 2019 8:00 pm
Great news. Thank you Julian
tkatona
Post by tkatona » Fri Jun 07, 2019 12:16 pm
What about the front panel?
derpinguin
Post by derpinguin » Sun Jun 09, 2019 9:27 am
Yep, still waiting on those.
derpinguin
Post by derpinguin » Sat Jun 22, 2019 2:34 am
Wigoz
Post by Wigoz » Tue Jun 25, 2019 12:13 am
Any new updates on this? By the way, awesome work
magman
Post by magman » Wed Jun 26, 2019 8:24 am
A quick BOM question.
C41 on the channel cards is not listed in the parts list for these cards. I noticed it is also not populated in a few of the build photo’s from the build manual. Is this cap needed and if so, what value should it be.
I’m doing quite well with my build, with the final 6 channel cards hopefully being completed today, then it is on to some testing and case assembly.
Regard
Magman
Next Liverpool Synth Meet - it’s 11th April 2020
glubsch
Post by glubsch » Tue Jul 02, 2019 3:09 pm
Yes, keep C41 unpopulated. The photo that shows the channels from the backside of the vocoder is not a good reference as this version of the vocoder is populated with different versions of the channel boards that underwent a number of refinements.
KaZpeR
Re: BUILD THREAD: 18-channel vocoder
Post by KaZpeR » Sat May 02, 2020 2:53 pm
I'm starting to source parts for this and had a couple questions for fellow builders.
Q1- Is there a copy of the silkscreen layers available for the PCB available, I find that it helps when you have questions on what goes where.
Q2- Parts, can you physically substitute 1/4W resistors in place of the 1/6W resistors or is there a space concern. Some of them are out of stock at the moment.
glubsch
Post by glubsch » Sat May 02, 2020 3:26 pm
Re Q1: good suggestion. Let me see how I can integrate that in the documentation.
Re Q2: yes, you can use 1/4 W resistors. For more details on size constraints, see here on Page 2, "Resistors".
jfloftin
Post by jfloftin » Fri Jul 24, 2020 12:44 pm
The Panasonic inductor is obsolete. This needs to be fixed on the BOM at Mouser.
Flounderguts
Post by Flounderguts » Fri Jul 24, 2020 4:20 pm
just go to the product page and click on the alternate parts button. You can easily find a part with the right specs.
Flounderguts
glubsch
Post by glubsch » Sat Jul 25, 2020 2:23 am
I sent out an email on June 6. In short, use RFS1317-104KL instead.
nobody
Post by nobody » Sat Jul 25, 2020 6:36 pm
I couldnt find one at mouser that was in stock until aug /sep. Farnell has some.
Other question: What is the orientation of IC1 on the DC to DC power supply? I see the stripe on the silkscreen, is that supposed to mean something? I am used to a dot.
collinspr
Post by collinspr » Sat Jul 25, 2020 7:10 pm
Yes. If you look at the MOSFET package (IC1) you’ll see that it has a chamfer on one side. It should be fitted with this corresponding to the ‘stripe’ on the silkscreen.
glubsch
Post by glubsch » Mon Sep 07, 2020 11:49 am
The documentation was missing information about how to connect the anodes and cathodes of the front panel LEDs. I've corrected this omission. See Chapter 4.5 in the Assembly and Tuning Guide.
