Macro Oscillator in 5U (THT based on "Plaits")
EOTS
Re: Macro Oscillator in 5U (THT based on "Plaits")
Post by EOTS » Fri Feb 28, 2020 9:57 am
Paradigm X wrote:
Mon Feb 24, 2020 2:03 pm
btw... small error in the MOTM builders guide/BOM
"Audio Output" connectors are detailed as MTA156 in column 3 but MTA100 in column 7. its clear anyway just thought id mention.
Thanks for reporting Ben, I'll include this in the next BOM update.
EOTS
Post by EOTS » Sun Apr 05, 2020 6:49 pm
FYI, due to a couple of questions: DIY kits in MU and MOTM are still available
hamildad
Re: Macro Oscillator in 5U (THT based on "Plaits")a
Post by hamildad » Mon Apr 13, 2020 9:33 am
Swapped the LED buttons to be correct, and reflowed the CPU and all seems to be working now...
:goo: :goo: :sb:
Looking forward to vastly under using this module because I have forgotten all the settings... like all MI stuff.
But it was a nice build with the only issues user error....
EOTS
Post by EOTS » Thu Apr 16, 2020 9:07 am
Awesome, good to hear!
hamildad
Post by hamildad » Mon May 04, 2020 6:08 am
all working and having fun this weekend with Chords setting through Oakley phaser.
noticed that the Corsynth C105 lo-fi next to it is bleeding into the Osc pitch.
Could this be my badly managed audio wiring or are there any other parts to check for insulation etc?
will do some tests to see if its just proximity but not worried as longer term the corsynth module will not sit next to it.
Synth Con Meo
Post by Synth Con Meo » Mon Jun 29, 2020 1:48 pm
Sent a PM Martin regarding the audio connection wiring.
Thank you
Synth Con Meo
<RIP> Kibou, I miss you.
EOTS
Post by EOTS » Mon Jun 29, 2020 3:58 pm
Hello Brian,
I just a question regarding the audio wiring connection.
First off you specify a COAX wire, is this to cut down on noise in the audio channel?
Yes.
With that though, it appears that maybe you have the core wire going to one pin and the shield going to an adjacent pin. Is this correct? And does it matter what pin the core connects to as opposed to the shield (obviously this is for the 2 sets of the 2 wires).
Maybe you could send me a better photo or a sketch.
Shields are on the inside, core wire on the outsides.
Hope that helps.
Best regards,
Martin
Synth Con Meo
Post by Synth Con Meo » Mon Jun 29, 2020 5:29 pm
Thank you Martin! :tu: :tu: :tu:
Synth Con Meo
