[AVAILABLE] TTSH V4 Build Thread
Re: [AVAILABLE] TTSH V4 Build Thread
@sduck
Nice!
I can't tell from the photo if yours does or doeesn't, but you can make these so they transition from round circle at the speaker face to an oval at the panel. Which looks little more like the originals and uses more of the panel holes for potentially better sound. Build with circle on 3DP base and there are no 'overhang' issues.
To be truly effective these need a seal between them and the speaker and moreso with the panel. Auto parts store gasket goops work well.
Nice!
- sduck
- experimental use of gravity
Yes, when I ramp up my cad skills that might happen.
The speakers i've used in the past have a pretty nice soft rubber seal around the inner edge, so at least there's that. The speakers that came with the current TTSH kit aren't quite so nice - while they have a "seal" sort of gasket, it'll require some assistance to actually work right. I'm not sure I'm going to use them.
And of course there's the bigger question of "how much difference does all this malarkey make? Not much, right?" I don't know, all the ones I've built have had them. There was the one time I visited a local friend who had one that i had built, and while it was on his kitchen counter he started messing with it, getting some great sounds, cranked all the way up through the speakers. After a while we noticed a new sort of buzzing sound that wouldn't go away - ah, the sound of a blown speaker! At least that's an easy fix.
I’m going to try something with the speakers used in this project:
viewtopic.php?f=17&t=236602
The built in radiator and speaker box are intriguing but they are 4 Ohm
There are some problems with running the on-board amps with 8 ohm loads (Peerless speakers), so 4 ohms may make things worse, but it also may not, depending on how much power these speakers need for drive, and whether their design is effective as a baffle or sealed (or ported) enclosure. What happens with the 8 ohm peerless speakers: when you crank the volume up high, and with low frequency content, the speakers bottom out. This is somewhat a factor of how much power is going in, but another factor in this is that there is no effective baffle or enclosure that would resist/suppress this behavior. When they go to maximum excursion, they rebound (get pulled back to center). When that happens, inductive spikes are generated in the speaker coils. These spikes make their way onto the power rails - affecting other parts of the synth. I have seen these spikes triggering pulses in the electronic clock, and creating sync-like effects for the VCOs.makers wrote: ↑Wed Sep 09, 2020 9:32 pmI’m going to try something with the speakers used in this project:
If you have a pair of these drivers to experiment with, and they otherwise fit, I'm curious how they might work.
Wired for weird
Going back to the original PWR AMP design and using even 8ohm speakers is a bad choice. 4 would not improve it. Unless you *also* go back to the very original design and use impedance matchng transformers. The circuit is designed for 45ohm speakers. In the originals this also means less piwer supply current draw,compared to TTSH's which use speakers of lower impedance.
Either way, what fuzzbass is saying about the spikes should be paid attention to!
Thanks for the tips. I read the similar posts in earlier build threads. I have really enjoyed working with this synth as a standalone instrument and using the internal speakers. I thought the low-fi quality of the 45 Ohm speakers that came with my kit would be appropriate for the context. But now I'd like to try something else.
I understand the power spikes and will certainly keep an eye out for that. But I was also worried about overheating the built in amplifiers. I planned to install the 4 Ohm speakers as is and gradually ease up the levels, checking the heat on the LM301's.
I have ordered 40 Ohm 20 Watt resistors to try in line with the speakers as well as the HW-711 amp used in the project I linked before. I spent too much time looking for matching transformers and gave up on that solution.
- Jim the Oldbie
- Super Deluxe Wiggler
My TTSH build has been on hold for awhile, so I haven't had a chance to actually try this yet, but here's my plan:
I also opted for better speakers, namely these Peerless speakers from Parts Express. (They're very similar to the optional ones described in the BOM except the surrounds are innies instead of outies.) To me, it seems kinda pointless to try driving "normal" speakers like these with the TTSH speaker amps for reasons already discussed, so I intend to mount this little Class D amp board (also from P.E.) in an aluminum box inside the synth case. I'll connect its inputs to the back side of the headphone jack NC switch contacts, using a stereo 1K pot in between for level trim, maybe screwdriver-adjustable from the rear panel. The amp runs on the same voltage as the TTSH, so I'll just need a bigger wall wart for the extra current draw.
With this done, I hope to optimize the original TTSH speaker amp circuits for use simply as a headphone driver; they seem fairly well suited for this actually. I'm hoping all I'll need is a simple voltage divider on each output; something like 33 ohms in series followed by 6.8 ohms to ground, with the output taken from the junction to feed the headphone jack. This should accomplish several things:
1. Provide a reasonable load resistance (39.8 ohms) to the TTSH speaker amp circuits
2. Reduce output voltage (& noise) by about 15 dB to a more suitable range for headphones
(remember that this gain will be restored downstream by the second power amp to drive the speakers)
3. Provide an output impedance to the headphone jack of <6.8 ohms (a bit high these days, but not too bad)
4. The 33 ohm series resistance will provide short-circuit protection for the TTSH speaker amps (for events such as a mono 1/4" plug in the headphone jack).
What do you think, sirs?
I installed the Tang Band speakers
http://tb-speaker.com/products/t2-2136sa
They fit well and sound good but the 4 Ohm impedance is almost certainly causing power problems. If I push them too hard I get some pitch tracking problems
Update: I installed this miniature Class D amp to power the speakers. I increased the AC to DC power supply to 3 amps. Now it's rockin!
https://www.parts-express.com/tpa3116d2 ... l--320-699
Hi all, Having trouble with the Internal Clock. It does not generate a pulse. The slider is only lit solid on power up if both trim pots are maxed, but eventually goes dark within several minutes if not touched. If raised more that 3/4 it always goes dark. Lit or dark it doesn't pulse. The S&H is working great when tested with an external clock. I've confirmed Cap/diode orientation, and looked at all the resister values in that section. Any idea where I should look next?
Hi folks, great thread!
I've reached main board stage 2 on ttsh V4 Rev8, and (hope you don't mind a stupid question) don't see any indications on the board (or in the instrucs) as to where the 2 pin amphenols go. There are a few likely spots, but they're umarked for the most part. Is there a diagram or image of the assembled board somewhere?
dp
dp
ah, think i found them, was thrown by a photo of an older model that used the red connectors in the e.g....anyway, assuming they are the amp L/R, eg gate/trig, and ext cv in?
Is this purchased kit or self sourced parts?
Which unijunction transistor did you use? 4870? 4871? Something else? And where did it come from? Are its legs matched to the PCB correctly?
Also want to confirm the pins of the transistor or transistors feeding the unijunction.<--ARP used two different designs with one or two transistors here and I don't know which version was used for the TTSHv4.
Kit parts I'd assume will not have these issues, but self-sourced may have different pinouts. The unijumction tranny is getting harder to find and even kit parts 'could' have a problem.
Well, I’m having a heck of a time troubleshooting my problems. Doesn’t help that I’m in the middle of a move and blah blah blah. Are there any wigglers in Canada (namely west coast), who could help me get this thing up and running? I’d gladly pay for your time at this point. Just want to play the darn thing so bad:(
- Ultra Wiggler
I'm still having trouble repairing the traces that were damaged when I had to remove and replace the switches. Can someone provide pictures of the main board that identify the component numbers so I can hardwire the switches according to the version 3 schematics that are available? I am having trouble tracing the connections.
- fluxmonkey
- Contact:
has the panel layout changed since v1? I have a v1 panel, can I use it with the V4 PCB?
- sduck
Yes, they'll work interchangeably. I have both here, and have put them on top of each other - except for some small differences in hole sizes there's no difference.
- fluxmonkey
- Contact:
excellent, thank you! this had languished in my backlog, partly because of the amount of rework required on the V1pcb...
Hi Guys,
I had a very happy TTSH for a good while, but I've blown the 2 10ohm resistors a couple of times from using the wrong cable type in the headphone jack. I keep replacing, only now, my pitch is very unstable on all 3 oscillators. it will be solid, and then it will do a slight wiggle or a big wiggle, or maybe just jump like a 5th and then that is the new center... the power output seems stable at the 15v points on the power board..
Any Ideas? What other parts might have been damaged from having a TS cable in the headphone jack?
Im getting discouraged.
Grateful for any thoughts.
Thanks.
J
Thanks.
J
Not sure when you completed your TTSH, but did you see Fuzzbass' notes about some of the jacks shorting to ground? This was added to one of the later versions of the V4 build guide:Jfettig wrote: ↑Thu Nov 12, 2020 2:18 pmHi Guys,
Thanks.
J
"Signal traces transiting under some jacks can become shorted to the jack’s ground connection via the jack enclosure. This problem affects 19 of the jacks. A further explanation, the locations of these jacks, and suggested fixes are below in the section covering the jack installation."
Even though you weren't directly working on the jacks, if you had to remove the panel to service your synth, you could have disturbed them. It's worth looking into.
Good luck
- Ultra Wiggler
So I made a lot of progress with my TTSH. I had to wait a long time before I could get a organic vapor respirator due to shortages. I can't solder without one anymore... Fixed the switch issue and got most all the way through the calibration. I had to switch out a bad slider for one of the osc S/H inputs and a busted jack for the clock in... but managed it. Thought I was clear to case it up and do the final v/oct calibration and my 4012 filter module went out. :-( It had been a little flakey before, needed pressure/jiggling to get it working properly, but now it won't even jiggle into place. Adjusting the resonance slider reduces the volume, but neither fine nor course frequency has any effect. there is no filtering going on, but signal is passing through. I replaced the unmatched 3904 as it was something I could do, but I'm in the same situation. Anybody have any idea of where I should look for this situation -- passing audio but no filtration? Prior touchy peformance but working and then no filtering?
I reflowed everything and checked the connectivity it looks good. It was good. what happened
I never got the 4072 working at all.
Anybody got any tips of a filter module to sell me? My patience for the TTSH is running thin -- I think it may be the end of my DIY run once I get it working.
- LED-man
- Contact:
I have some spares.. pls send me a PM
- Ultra Wiggler
Also if anyone is just capable of diagnosising what went wrong -- the square wave output from the filter is half the amplitude of the input, frequency adjustment has no effect, and adding resonance does create a resonant waveform... would it likely be the dual transistor? The one part I don't have a spare of?
Ohah... something shorted accidently when I was probing signal flow. No output at all now. Filter is fully dead. Got to check recheck everything else now. Hope it just fried the filter.
For those that built from synthcube kits, is this what your IC headers looked like? Figured i was ordered machined headers, i would not consider these to fit that description.
- synthcube
- you will be assimilated
- Contact:
Here is the short version--we have made a change in our standards from the Mil-Max machine pin sockets to the TE Connectivity dual wiper type sockets. We were convinced by some research and smart people that the dual wiper type are superior to the machine pin type for the ICs we use in all of our kits. That is not to say we have ever had much of an issue with the machine pin types--- but we do not use machine pin-type ICs that the machine pin sockets were designed for. (Like most things, there are proponents on both sides of the question) In our current opinion, for this application --the (genuine manufacturer) dual wiper types are superior. Its simply about slotting a rectangular pin into a rectangular slot, rather than a rectangular pin into a circular slot.
facebook: https://www.facebook.com/2SynthCube
synthcube webstore www.synthcube.com/cart
music from outer space: www.musicfromouterspace.com
blacet research: www.blacet.com
MOTM DIY Analog Synthesizers: www.motmsynthesizers.com
music from outer space euro smt: www.mfoseuro.com
Ok, I'll follow up in an email, but surely you can see how the description of the product misrepresents what was sold? It's not really about opinion on what is best.
