[AVAILABLE] TTSH V4 Build Thread
Re: [AVAILABLE] TTSH V4 Build Thread
Can anyone direct me to how to wire up the Gate Booster currently available from Synthcube? I can't find any documentation on that board at all. Also it comes with 2 ferrite beads and 2 100n caps, but the board is marked for 4 100n caps.
Glad it you got it working!kristop wrote: ↑Thu Jan 28, 2021 12:04 amGlad this issue was on this page. Noticed while actually sitting down to start calibration that my noise just thumped and my sample & hold didn't work. Swapped the LM301 with one I had in my parts drawer and presto. Glad I have 9 more in case other issues arise.
The 2 pin header on the corner of the PCB are your Gate/Trigger outputs and from what I understand they are labeled incorrectly and should be swapped.
'Gate in' is pin #3 on the 3 pin header.
I don't think you need to use the ferrite beads.
You could reference the pics in the build guide to see what goes where. I hope this helps!
Thanks, I did come across this... the destinations aren't as much of a problem as where to hook up on that board. Seems like the supplied parts kit could use an update to this new board, which makes it all the more confusing.
This should do the trick. Remember to swap the gate and trigger outputs (2 pin connector).
- synthcube
- you will be assimilated
- Contact:
Question for the group regarding questions around the 2N5460 . We have stock from two makers here-- On Semi and Fairchild--- and they appear to test with different pinouts (!)
What are people's experiences with this please?
facebook: https://www.facebook.com/2SynthCube
synthcube webstore www.synthcube.com/cart
music from outer space: www.musicfromouterspace.com
blacet research: www.blacet.com
MOTM DIY Analog Synthesizers: www.motmsynthesizers.com
music from outer space euro smt: www.mfoseuro.com
^Not sure what you're asking?
Experience is yes, that kind of thing is normal.
Twist the body 45 degrees -off the axis 'line' of the legs- and the DS-SD leg swap -when necssary- is easier.
AKA no big deal. <-- When you read the datasheets.
Old school DIY build instructions often had visuals like you've done here to show the different parts which might be supplied with the kit so a proper build could be made with the parts one received.
My experience is when I'm heads-down building, I don't test new components, and if I built the order myself on DigiKey/Mouser, I only verify that the right value/part is in the right place. With 3rd-party/eBay suppliers, I'm more careful, but for my Synthcube parts, unless otherwise indicated, I trust they match the BOM specs - including pinouts.
I would have to know in advance that the pinouts were different or have a very clear note in the parts bag indicating the alternate configuration. For the 2N5460, yes, even ones that are marked with a manufacturer code can be fake; mine were clearly "Fairchild", but I only determined that they were fake after they were installed.
Oddly enough, I've since installed an SOT23 J177 on an SOT23 to DIP adapter board and it appears to be working quite well - not sure why more people aren't recommending the J177 as an alternate to the 2N5460.
Having trouble with my ADSR... Sort of the same as described a few days back. My A/D/S are all instantly 10v when manually fired and instantly back to 0. My R moves up to 10v wh3n I move the slider up and the stays there.
Could this be related to the 2N5460 and the pin out issue being talked about above?
If the parts were provided in a Synthcube kit, I would say it's very possible and even likely. If you have a transistor tester, I would desolder them and see if first they test as JFETs (and not BJTs), mine didn't. It sounds like a few of us had the same problem.kristop wrote: ↑Sat Jan 30, 2021 4:53 pmHaving trouble with my ADSR... Sort of the same as described a few days back. My A/D/S are all instantly 10v when manually fired and instantly back to 0. My R moves up to 10v wh3n I move the slider up and the stays there.
Completely agree, but my AR and ADSR weren't firing at all - just a drone. I checked here before I started debugging and saw a post to check the 5460s, and sure enough, mine were BJTs. I had a spare 5460 and the ADSR came to life, then I added a J177 and the AR started working as well.fallout wrote: ↑Sat Jan 30, 2021 5:45 pmIf the parts were provided in a Synthcube kit, I would say it's very possible and even likely. If you have a transistor tester, I would desolder them and see if first they test as JFETs (and not BJTs), mine didn't. It sounds like a few of us had the same problem.kristop wrote: ↑Sat Jan 30, 2021 4:53 pmHaving trouble with my ADSR... Sort of the same as described a few days back. My A/D/S are all instantly 10v when manually fired and instantly back to 0. My R moves up to 10v wh3n I move the slider up and the stays there.
I don't have a tester.... Is it a matter or rotating them, or do I need new 5460s?
If I didn't have a tester, I'd replace them with good 2n5460's and save yourself the hassle of desoldering, soldering, desoldering.. etc
It's likely you got the same parts as the rest of us.
Also make a note that other 2n5460's might have a different pinout and you will have to swap pins. Check the datasheet of whichever ones you get.
But is not just a pin out problem with these ones then?fallout wrote: ↑Sat Jan 30, 2021 6:11 pm
It doesn't appear to be but I haven't tested personally. Check who manufactured the 2n5460's you received and then check their datasheets for their pinouts.kristop wrote: ↑Sat Jan 30, 2021 6:34 pmBut is not just a pin out problem with these ones then?fallout wrote: ↑Sat Jan 30, 2021 6:11 pm
The TTSH v4 PCB pads are orientated for pins 1(D) 2(S) 3(G) on the 2N5460's. For instance, I used Motorola 2n5460's whose pinouts are 1(S) 2(D) 3(G) and I had to swap pins 1 and 2.
Honestly, I'd save myself the trouble and just replace them with proper 2N5460's.
Fwiw—not saying your hypothesis is wrong or anything—don’t treat those cheap transistor testers as the end word on anything. I occasionally find that a JFET will test as a BJT for some inexplicable reason but invariably still work as expected in-circuit.fallout wrote: ↑Sat Jan 30, 2021 5:45 pmIf the parts were provided in a Synthcube kit, I would say it's very possible and even likely. If you have a transistor tester, I would desolder them and see if first they test as JFETs (and not BJTs), mine didn't. It sounds like a few of us had the same problem.kristop wrote: ↑Sat Jan 30, 2021 4:53 pmHaving trouble with my ADSR... Sort of the same as described a few days back. My A/D/S are all instantly 10v when manually fired and instantly back to 0. My R moves up to 10v wh3n I move the slider up and the stays there.
That could very well be the case, I don't think any of us have tried swapping pins on the transistors provided with the kit so I suppose it's worth a shot. I just hate having to desolder parts more than necessary!
I double-checked the Fairchild specs before desoldering just in case I had to swap legs, but the specs matched the BOM/board exactly. Both transistors tested as BJT in DCA Pro, while my one spare tested as P-Channel JFET, so I didn’t try swapping legs. I’d be weary of swapping legs on a transistor with clear markings and a matching datasheet. I did buy the Peak tester after some odd measurements with a $20 tester, so I’d be cautious with cheap testers as well.
Mine were tested with a DCA75 as well, for whatever that's worth. I haven't seen it mis-test anything in the time I've had it but it's not like I've tested hundreds of transistors.
It's a $1 part, swap it and be done with it.
Did I say I hate desoldering?
Unfortunately, I didn't hold on to the originals (from the full kit) after removing them from board. My replacements have the pinout on the right (S-D-G) so I had to swap the pins when installing. At this point I have no way of knowing if the originals were bad, or they had a different pinout that messed them up after the first power on.
Update: The LM301's my friend had were also from National Semi (though with a different date code) and behave exactly the same in my circuit. In addition, I tried the 100k to GND as suggested by KSS but that had no effect either.ebfx wrote: ↑Wed Jan 27, 2021 6:52 pmHadn't gotten there yet, so I just took a look and I'm seeing the same thing. I've got a friend who's supposed to bring over a couple of LM301's from his stock later this week (all of mine are from Synthcube, his are not). I'll let you know what I find.fallout wrote: ↑Wed Jan 27, 2021 3:56 pmNow that the noise problem is fixed, I've encountered another problem caused by the LM301AN.
When calibrating the internal clock, I was not able to adjust the period to slower than 1 second. The rate init trimmer would reach a point and the square wave would go flat. I swapped out A42 for one of my spare LM301AN's and the problem was resolved.
@ebfx I'm curious if you encounter this as well.
Looks like it's time to track down a LM301 from a different supplier. Anyone have any experience with the SMT-to-DIP adapters or am I better off just trying to track down some old stock in DIP packages?
Oh good.... Both Digikey & Mouser are sold out of 2N5460s.
Got mine from NTE Electronics via DigiKey. Why don't you try www.ntepartsdirect.com and see if you can get them directly? They weren't cheap, and they were packaged pretty poorly, but I got them quickly and they worked great.
Just checked, unfortunately, I'm in Canada and their only shipping option is $26USD. Digikey would be ideal as their shipping is $8CAD for 2 day service.ebfx wrote: ↑Mon Feb 01, 2021 4:13 pmGot mine from NTE Electronics via DigiKey. Why don't you try www.ntepartsdirect.com and see if you can get them directly? They weren't cheap, and they were packaged pretty poorly, but I got them quickly and they worked great.
