And still 12 steps!
It also has an inverter circuit. Having 2x 711's plus breakout for 2x frequency pots, plus switched inverter and 2x bypass switches is a lot of unnecessary HP. I'm sure this could be compacted into reasonable HP count in a single module, like the 720B...Modulart_JP wrote:Great on paper, not so great in real life...I was looking at the manual and reading through the various modules, the Frequency to Voltage feature on the 714 looks interesting. Is this something that's likely to be looked at?
Nothing you can't do with 2x 711's.Also there is a two-channel phaser (720B) with a lot of really nice features, is this likely to be cloned in the near future?
Because this is what the 720 basically is...
To be exact, the 720 is 2x 711's with the addition of a frequency shift pot for each phaser.
Have a look at the schematics and you'll see that's something you can easily add to the 711.
You could make a break-out 4HP module you put between 2x 711's.
I was wondering if Ori was ok after this announcement, followed by the radio silence, so I emailed him asking how he is. He replied saying that he is fine, just extremely busy. The good news is that he's ok, we just have to be patient.filterstein wrote:see post from 24 September:
- 715 Multimode Filters (available by the end of this week)
LektroiD wrote: The good news is that he's ok, we just have to be patient.
Good things come to those who wait...
That 715 is an instant buy the moment it goes up for sale.Modulart_JP wrote:Yes, I'm alive...
I had to rework the 715 Multimode Filters because although it was working I didn't like the layout.
I should have the new PCB's and panels next week.
I managed to get some, they are expensive, but can be sourced.Availability of obsolete chips is the reason I won't make a clone of the delay.
There is no reliable source for MN3004 chips and there is no reissue either.
Sounds good, I would love a copy of the Eagle files.I had plans for a clone of the Panning module from the 711.
I decided not to go through and didn't release it.
If some of you are interested, I can upload the Eagle files for the PCB and panel.
But keep in mind they were never tested therefore it would be at your own risk.
I don't know what passes for "quality" around here, but here is me jamming with mine.moog55 wrote:I'd like to hear some quality sound demos as well.LED-man wrote:Are there sound demos available?
Ok, I got my VCF 703F to calibrate / see changes by doing the following:LektroiD wrote:Calibrating the 703F VCF... I see no change on any of the poles when I test at the points indicated. I have my scope set to 50mV and all pots fully CCW. I am grounding the scope from the socket ground. Each pole is giving zero reading on the scope but rotating the trimmers from 0-100k has absolutely no effect on the scope reading.
The filter appears to work as expected with an audio input, but I would like to calibrate the individual poles properly.
diode_destroyer wrote:Ok, I got my VCF 703F to calibrate / see changes by doing the following ...
These Pharmasonic modules are what made me 'bite the bullet' and get into Eurorack and modular. That was 6 months ago and I'm now dealing with ~600hp of modules.
