You use the open music labs clone http://www.openmusiclabs.com/projects/b ... index.htmlJackdamery wrote: ↑Mon Jan 25, 2021 9:23 amHi, do you have a circuit diagram for this? What did you use to substitute the BA662?
Oh dear, GAS alertCyrax wrote: ↑Tue Mar 09, 2021 3:43 amLook at this beauty
I have finished my 909 yesterday! The best, I have plug it in and it works! No bug fixing, I am so happy!
In my opinion, its great that it sound 100% like the TR-909 but the most parts are easy to order for repairI have check the sound with my TR-8S and my Sample-Library... It sounds perfect...
It was a pleasure to build this! I was so excited as the package arrive at my Studio. And that all parts in it makes it very simple.
I have checked all offers like RE-909 (No case at the moment and all parts must be ordered by myself) or Nava that's not like the 909 in my opinion. And I heard many problems with it. And, all Sets are more expensive as the SR-909! But this is awesome. It looks like the original, it sounds like the original, its more stable like the original
Happy happy happy![]()
I used NEUTRIK NRJ4HF
Even if you used the TRS versions, the signals wouldn't be balanced, correct? Would it be possible to have the outputs balanced?
Cool, thanks. That's what I thought they were but I wasn't sure because of the extra holes
Not at the Moment, at the Moment I try to Buil a Page: https://sr909.de with some Infos and Documentations.
Correct. Using TRS jacks would't change a thing. The ring holes are just not connected.deft_bonz wrote: ↑Wed Mar 10, 2021 3:01 amEven if you used the TRS versions, the signals wouldn't be balanced, correct? Would it be possible to have the outputs balanced?
Do you have any info about the DAC boards? what value resistors and do they deed to be .1% or something? Any pics of one assembled?Cyrax wrote: ↑Wed Mar 10, 2021 5:54 amNot at the Moment, at the Moment I try to Buil a Page: https://sr909.de with some Infos and Documentations.
Steda has Support me in some Questions directly. The TR-909 Service Manual helps also.
The most is logical and stupid. Only the Connection between the PCBs was a littlest tricky. But for this I try to write the Documentation asap to the Page.
