The 2020 Show Us Your DIY Builds Thread!
DEEMARKAY
Re: The 2020 Show Us Your DIY Builds Thread!
Post by DEEMARKAY » Fri Apr 10, 2020 3:37 pm
MTM Spring Reverb. The RCA jacks will be added. I think the vactrols I bought on ebay a rip-offs. Not quite sure how this will affect the sound though Reverb sounds great non the less.
Very tight fit with the switch and the smallest one I had lying around.
Was running low on acrylic sheet as well and had to use the last part with a cut corner- oh well...
audioCTRL
Post by audioCTRL » Tue Apr 14, 2020 4:08 am
Navs
Post by Navs » Tue Apr 14, 2020 3:30 pm
roglok wrote:
Wed Apr 01, 2020 8:42 am
Navs wrote:
Wed Mar 25, 2020 3:42 pm
Little passive DIN Sync adapter/mult box. ...
that's cool. how is your typical DIN Sync input designed in terms of input protection? maybe an active solution clamping signals to 5V makes sense...
of course you can also use DIN Sync outputs to control your modular or sequencers / drum machines with trigger inputs. i built this, which works a treat: http://www.florian-anwander.de/a100/sync2clock/
Yes, active would be better. I'm relying on the inputs of the 808 and making sure I attenuate signals to @5V.
Thanks for the reminder - I had forgotten Florian's design.
GrantB
Post by GrantB » Sat Apr 18, 2020 10:30 pm
AML ez1073 kits. Little detour into 500 land.
tele_player
Post by tele_player » Sun Apr 19, 2020 10:22 am
Assembled Plaits yesterday, Vortex Generator a few weeks ago. These barely count as DIY, in my opinion. The VG was board/panel, so I had to source components, and compile the Arduino code, and assemble, of course. The Plaits was a full kit, and all the SMT was already done. Super easy build.
But, fun to build, fun to play.
Grumble
Post by Grumble » Sun Apr 19, 2020 8:56 pm
fitzgreyve
Post by fitzgreyve » Mon Apr 20, 2020 5:10 am
Woodwork rather than electronics - 126HP skiff/case:
Under developement:
- "Muse"
https://fitzgreyve2.blogspot.com/
audioCTRL
Post by audioCTRL » Tue Apr 21, 2020 1:03 pm
Awesome! Those Neve style knobs rock :sb:
GrantB
Post by GrantB » Tue Apr 21, 2020 4:20 pm
They are nice knobs but I think these CAPI knobs rock even harder. They would look great on a synth. A synth with discrete opamps and transformer balanced outputs ;)
dot matrix madness
Post by dot matrix madness » Wed Apr 22, 2020 7:49 am
Redesign of my Voltmeter (based on the discontinued Doepfer module).Added a toggle switch to
multiply the input voltage by 5 or 10 times (only for positive voltages). Comes in handy to
measure small voltages up to 2V.
Licenced to solder since 1993
sduck
experimental use of gravity
Post by sduck » Wed Apr 22, 2020 10:09 am
I haven't built any 5U stuff for about 5 years. I already have too much stuff in that format - my cabs are full, and I have a few unused modules in the closet. But couldn't resist this one!
ashleym
Post by ashleym » Wed Apr 22, 2020 12:13 pm
Truly madly deeply
I’ll have to look out for some of those. Knobs with a pointy end work for me. Lovely metal lumps like these especially so!!
DEEMARKAY
Post by DEEMARKAY » Thu Apr 23, 2020 4:14 pm
Love this color scheme! Reminds me of 80s zoids. If I ever would redo all the panels of my modules, It'd be something like that.
Maybe if I finally decide to get that chinese laser and find a good deal on knobs.
nigel
Post by nigel » Thu Apr 23, 2020 9:38 pm
OK, so this is not my most technical build, but it does exactly what I need! I have a little suitcase system, powered by a wallwart. The trouble is, the lid is quite shallow, so I couldn't (a) leave it patched and closed, or (b) fit the wallwart in the case. The first problem I fixed by buying some Tendrils. They lie flat, which is good, although if you're short of finger room they can also be tricky to remove. For the second problem, I came up with this beauty:
There was actually an earlier attempt made from aluminium, but I took up too much space joining the sides (and also I made it the wrong size). Eventually I just grabbed some cardboard, folded it into a box, and attached some small strips of aluminium angle. So my briefcase now looks like this:
and all is fine! The wall wart fits in the little box in the bottom left, the spare cables (and audio recorder) are held in velcro loops hotglued to the lid.
GrantB
Post by GrantB » Fri Apr 24, 2020 1:41 am
more 500
AlanP
Post by AlanP » Fri Apr 24, 2020 4:13 pm
This one's been on the backburner for awhile. VCF from the MS-10, using the Korg35 circuit. The input has far too much gain on it at the moment -- it's very easy to swamp the filter entirely, so nothing gets filtered at all. But it does work nicely once the input level is set correctly!
808 Snare circuit. Again, backburner... this one had a really embarassing mistake that caused it to be benched for a few years (a few, he says.) But now it works nicely.
Er... while the panels might not say 2020, I did indeed finish 'em today. They've just taken a long time to sort :)
GrantB
Post by GrantB » Wed Apr 29, 2020 5:28 pm
and more 500
hox3d
Post by hox3d » Thu Apr 30, 2020 5:41 am
I made this case yesterday.
Not perfect, but I'm quite happy with the result.
I had so many built modules around, now they have a place.
Matte-fueled habits
forestcaver
Post by forestcaver » Fri May 01, 2020 11:30 am
I’ve uploaded my module designs (see photos earlier in thread) to GitHub:
https://github.com/forestcaver/Analog-Voice
https://github.com/forestcaver/Benjolin
https://github.com/forestcaver/Jinx
https://github.com/forestcaver/Minx_AJH
They are either cc-by-sa 4.0 or cc-by-nc-sa 4.0 as I havent decided fully what to do with them yet...
slaughterhousesam
Post by slaughterhousesam » Fri May 01, 2020 4:36 pm
total recycle job number 2
building stuff from bits of what i already have. only purchases made - a handful of extra 6.35 jacks, and some black card from sainsburys to cover the faceplate. desoldered pots and jacks, box and panel, psu, all from previous projects that have fallen out of favour. inside there are 12 cgs dc mixer pcbs converted into an 8x8 matrix mixer (along cgs design), switchable input mutes and dc filter, 2x gain on the input buffers, output attenuation, unipolar/bipolar on each send. spent some time jacking up the grounds and dropping pulldown resistors in (in retrospect doepfers matrix bi/unipolar switch is in a more sensible place than the cgs design) to try and cut the noise and crosstalk. quite happy now and v good fun :)
soup
Post by soup » Sat May 02, 2020 4:55 pm
My first quarantine build and my first metal panel. :banana: Stroh Ultrafade in frac...
tele_player
Post by tele_player » Sun May 03, 2020 12:00 am
I built these back in March, but only got them mounted in a crude wooden box today.
Fun noisemaker, but I need 20-30 more banana cables.
htor
Post by htor » Mon May 04, 2020 8:51 am
oh, my knobs that thing looks cool! good job :clap:
htor
Post by htor » Mon May 04, 2020 9:07 am
PHOBoSapiens wrote:
Tue Feb 18, 2020 9:50 am
gnsk wrote:
Tue Feb 11, 2020 5:08 am
so that's what insanity looks like,. well done!
:yay:
this makes me nervous!! why when whether how...
ashleym
Post by ashleym » Mon May 04, 2020 11:49 am
That’s got a :nana: :nana: from me. Nice mix of LW/CGS and Slightly Nasty. Do they all work well together? When will the mysterious module get finished?
