Sweet! Would love to hear some sounds from it! What did you end up using for your MIDI/Cv interface? Or does that KB just have mult CVs?
The 2020 Show Us Your DIY Builds Thread!
- devinw1
- Super Deluxe Wiggler
- Contact:
Re: The 2020 Show Us Your DIY Builds Thread!
- Common Wiggler
I am using the Mutable Instruments Yarns module for midi-to-cv. I've been building so much I haven't really had time to play the thing much yet. I'll share something when I get the chance, it's pretty cool.
I've cloned the Befaco attenuvertor;
Vert, I like how it turned out, finger space between knobs and cables at the bottom was a starting point, same knob height was a happy accident.
- dot matrix madness
- Veteran Wiggler
Nice! Is that a two color pin header or are the two "red stripe" pins simply a separate part?
Licenced to solder since 1993
Yes, just a red 2 pin header, I actually forgot to add it in the silkscreen.
- fragletrollet
- Veteran Wiggler
- Contact:
Really like that befaco attenuator redesign. I always thought the jack placement on the original was what was holding it back from being my favourite attenuverter design.
I built a Mutable Shruthi XT with a Polivoks VCF, and liked the sound so much that I wanted to build a eurorack Polivoks VCF module.
I only spotted that Erica Synths released their gerber files a few days after submitting this for fab. Oops. Well, at least it matches most of my other VCF modules a bit more, this way!
- Learning to Wiggle
MFOS Quad Timbre Bank
not yet on a faceplate....
"We'll be living in all the oceans now."
(type of music I make.... drone atmospheres, deep late-night beats.)
- sduck
- experimental use of gravity
Ok, this one is weird and sort of ancient, but I finally finished it, so there.
This is version 1 of the very first run of these. I built most of this when I got it, maybe 6 years ago - it was right around the time the TTSH came out originally. But I didn't have a case for it. So it sat, mostly untouched, on a shelf since then. I moved since then, rebuilt my studio in the new house, put it on the same shelf it had been. A few years ago synthcube started a pre-order for the cases for these, so I bought into it, and finally got the case a few months ago. Some more sitting around ensued, with a few brief spurts of activity, but today everything seemed to fall into place to actually get everything together, and now it is! Still have to calibrate it - hopefully I won't wait another 4 months to do that.
Started my first DIY project during the beginning of the pandemic. I've been on a bit of a Buchla tear lately. Successfully built a 266, 281 and 292. I'm wrapping up a 227, and three 258s as well. Photos are a little disjointed, sorry.
Hi,
I continue my series of modules for less than 20 € and I've just finished a Quad Delay module for trigs & gates.
It's a "real" delay, i.e. it stores a serie of trigger events and restore them later.
Here's the panel :
And the video :
Here's the panel :
And the video :
- Veteran Wiggler
Those prices listed in the BOM are spectacularly cheap. I suppose you've got all the parts from CN.
yes... and by lotsdot matrix madness wrote: ↑Thu Nov 05, 2020 7:41 amThose prices listed in the BOM are spectacularly cheap. I suppose you've got all the parts from CN.
- Stoneyards
- Common Wiggler
I built a 12u case this summer..
I wanted something to match my desk..
Working backwards, here's the finished product with genus modu bus boards and acopian power supplies. There's a powder-coated mesh back that goes on after this.
Birch ply and pulplogic rails before stain and wipe on poly.
Cardboard prototype helped me get the angles right.
..And yesterday I replaced the linear supply with switch mode supplies. Lighter and eliminates a bit of mechanical noise.
Finished up a Barton Chordizer today...
Some of my pluses came out a little negative from the laser cutter but lots of positive vibes today to make up for it as the whole town was out celebrating the homegirl KH.
- Dr. Sketch-n-Etch
Wow, lots of beautiful new DIY on this page today. I gotta get busy.
A dewdrop can exalt us like the music of the sun.
- Peake
- I'm in ur DIY. Filling cases with Buchla
Finishing a modified Roman 212. I'll post documentation of the mods later. Panel by Beast UK, thank you!
- diode_destroyer
- Common Wiggler
Finally finished some Oakley euro modules: viewtopic.php?f=36&t=240130!
- autodafe
- Wiggling with Experience
- Contact:
Finally managed to find some time to solder Jasper MIDI interface and to host it into the mahogany case I started building last July.
Here's the result, not 100% perfect maybe but I am quite happy on how it turned out, those recessed MIDI connectors in particular ;-)
I've been trying to learn pcb layout. I've yet to make one without a mistake but so far have managed to get everything to work.
It's been fun. I've also been digging this laser cut aluminum from ponoko. Here's a couple of serge things in frac...
- NeolithicElectrophones
- Veteran Wiggler
^ Dayum. Looking really clean as usual. Your builds are always a highlight on here. How much did the panels come out to?
