Compressor Fixed Ratio Calculations
cackland
Post by cackland » Tue Jan 14, 2020 12:56 pm
I'm thinking about implementing a compressor circuit into a design and wanted to set fixed ratio values.
Attached is the schematic. Here is the data sheet http://www.thatcorp.com/datashts/THAT_4 ... asheet.pdf
How would I define, say 3 fixed ratio values using a toggle switch.
1) 4:1
2) 10:1
3) 20:1
There is this formula in the data sheet: Page 7. Although not sure how to make sense of it, or if it will provide me the answer.
Anyone have any input?
EATyourGUITAR
has no life
Re: Compressor Fixed Ratio Calculations
Post by EATyourGUITAR » Tue Jan 14, 2020 1:08 pm
K is gain. Remember the last time we talked about gain? All you need to do is convert Vin to dBin. Vout to dBout. There are formulas for that. The rest is right there. You posted it . If you want to work backwards from the CR then that is just basic math. Substitute Vin for +/-5v. Solve for dBout. Then convert dBout to Vout. That gives you K. Then you can do the circuit.
EATyourGUITAR
has no life
Post by EATyourGUITAR » Tue Jan 14, 2020 1:15 pm
Remember K = Vout/Vin
guest
Post by guest » Tue Jan 14, 2020 3:41 pm
id get rid of the pot, and replace R9 with a series of resistors. then take your ON-OFF-ON (SPDT) toggle, and wire 3 resistors to it. all the resistors come from the RMS circuit, 2 go to the 'poles', and the 3rd goes to the 'throw', which also goes to the gain stage.
openmusiclabs.com
cackland
Post by cackland » Tue Jan 14, 2020 5:19 pm
Thanks EATyourGUITAR . The data sheet mentions the center position of the potentiometer (5k) equals a ratio of 4:1. So one resistor should be that. Need to figure out the other two values
Guest, is this how you mean?
guest
Post by guest » Tue Jan 14, 2020 5:43 pm
yes, so when the switch is one side you get R144//R145, in the middle you get R145, and on the other side you get R145//R146. so there will be a bit of calculating to do, but not too bad. you figure out R145 first, and then do the other 2.
openmusiclabs.com
cackland
Post by cackland » Tue Jan 14, 2020 11:24 pm
Thanks guest. To be honest, I've gone through the data sheet a couple of times to try and see if I can get a grasp for figuring out the values... it's definitely confusing me.
My original idea was the keep R9 and place a SPDT switch below with 3 resistor values in a similar fashion, however not relying on dividing them as you suggested and basing it off 5K as the reference point (which is 4:1). Figured as its exponential I'd have to work out another way to get exact for 10:1 and 20:1 (basic limiting).
EATyourGUITAR's explanation is confusing me too. Not terribly good with this kind of stuff.
Maybe there is something else you recommend I read up on
guest
Post by guest » Tue Jan 14, 2020 11:50 pm
one way i do things when the math is getting a bit hairy, is to just put a pot in, and then adjust it to what i want, and then pull the pot out and measure the resistance. so if you have the IC already, you can build the circuit up on protoboard first and see what works for you.
openmusiclabs.com
guest
Post by guest » Wed Jan 15, 2020 12:22 am
ok, i just had a quick read of the datasheet (havent used this IC personally). so, the K they are referring to in your initial equations is the gain of that inverting gain stage. so, since CR = 1/(1-K), you get CR=1 for the pot all the way down (K=0 since the input is shorted to ground and no signal gets through), and if you turn it all the way up, you get K=1 and CR = infinite. the gain is 1 because the opamp stage before the pot has a gain of 2 (5k source, 10k feedback) and the stage after the pot has a gain of 1/2 (10k source, 5k feedback). so in total that gives a gain of 1.
rearranging the CR equation, we get K=(CR-1)/CR. so if you want CR=10, you need K=0.9. since the first stage has a gain of 10/5.1, the second stage needs a gain of 0.9*5.1/10. if were only changing the source resistor, the gain is 5.1/R = 0.9*5.1/10, so R = 10/0.9 = 11k.
one problem with the switch configuration i gave, is that i dont think there is a way to have all the compressoin ratios go in sequence. the largest resistor value will be in the middle, with the two smaller ones on the ends. youll need a (ON-ON-ON) DPDT switch to implement a sequential arrangement.
openmusiclabs.com
cackland
Post by cackland » Wed Jan 15, 2020 1:23 pm
Thanks guest. Yes the things were getting a bit hairy. I had thought of adding a potentiometer, setting the position and measuring. Thanks for the math explanation.
I did come across the idea of wiring a DPDT as sp3t? Is this what you were referring to?
EATyourGUITAR
has no life
Post by EATyourGUITAR » Wed Jan 15, 2020 1:56 pm
I have like 10 books on the subject but I like this one because it has enough rigor to support you all the way to VCF design. I don't understand everything in the book but I will never stop trying. never stop learning.
this one however, is perfect for a beginner. it says transistor circuit design but in reality it is a very different book. the book spends a lot of time talking about V peak to peak to Vrms. lots of ohms law stuff. common formulas for mains electric stuff. there is one part that covers gain, dB, conversions to other formats such as Vrms etc.. there is a just enough about power supplies. it is much more than a book on transistors. to me it is more like a book for studio owners and product designers specifically audio related products.
cackland
Post by cackland » Wed Jan 15, 2020 2:02 pm
Great, thank you. I’ll definitely have a look at those books.
