I completed mine this morning except for the BAT54S, which arrives Saturday from Digi-Key. Meantime, I want to share a technique and a couple of questions.
First the technique:
I was concerned about marring the window with errant glue, so I taped it very carefully and used a product called "Formula 560 Canopy Glue" to cement the window to the panel. If you are not familiar with it, canopy glue is preferred by airplane modelers because it dries crystal clear. I loaded up the joint from the back of the panel, then wiped off the excess. Came out great.
Now the questions:
1. I think I successfully loaded the firmware on the Teensy. The loader didn't offer any error messages, but it sure loaded fast. Should I assume I'm good if I received the message "reboot successful"?
2. Such a cool module deserves cool knobs. Anyone have any experience with 3d printed knobs? This dealer on
Shapeways lists quite a few that should fit a .250 diameter shaft, though some are a little wide.
Here it is:
