Neutron sound Dust of Time.
consumer
Re: Neutron sound Dust of Time.
Post by consumer » Sun Mar 15, 2020 10:03 pm
Altitude909 wrote:
Mon Mar 09, 2020 5:44 pm
... but its EITHER regular pots and the tacts OR the Switch pots
Aren't there eight tact switches even if one gets the Switch pot version? ...That's how it appears in the renderings...
Asking because the BOM's note is "Not used with the click pots", but that's misleading, right?
Altitude909
Post by Altitude909 » Mon Mar 16, 2020 8:28 am
yeah, it is. Fixing
Altitude909
Post by Altitude909 » Mon Mar 16, 2020 8:35 am
consumer wrote:
Sun Mar 15, 2020 9:27 pm
Neutron7 wrote:
Sat Mar 14, 2020 6:15 pm
I re exported with zero paste swell can you try that?
That seemed to make a difference. I'm going to go ahead and order the stencil and will report back once received.
Thank you for this: You're the best!
tbh, i've been using the smaller paste footprint with my stencil and its fine. The only part in question is the DAC and that is a TSSOP part that really needs very small cutouts (like ridiculously small)
defalut
Post by defalut » Mon Mar 16, 2020 2:42 pm
Altitude909 wrote:
Sat Mar 14, 2020 6:36 pm
defalut wrote:
Sat Mar 14, 2020 6:05 pm
Damn, been waiting like crazy for this to be released and now when it´s gettable i can only get one? Altitude, when will you get more panels? I have a bunch of ppl im trying to order with to get down shipping and customs cost..
There's 25 more of the tact ones and new panels will be here next week
Wonderful. thank you!
With new panels, are they new-new, i mean without the small bug that you mention on the site - is that it?
Cheers! :hail:
Altitude909
Post by Altitude909 » Mon Mar 16, 2020 4:56 pm
Cheers! :hail:
yes
consumer
Post by consumer » Tue Mar 17, 2020 4:58 pm
anyone have a suggestion on good knobs?
I think the knobs in the photo Neutron7 posted look pretty good, but I'm open to other suggestions.
sduck
experimental use of gravity
Post by sduck » Wed Mar 18, 2020 10:59 am
Knobs are a matter of taste. I suggest looking around on small bear electronics - they have a great selection of different knobs - and figure out what you like.
djthopa
Post by djthopa » Fri Mar 20, 2020 11:27 am
Maybe i need more coffee, the bom is missing c6 & c17 ? 0,1 uf?
Can someone confirma please, i does show up on the ibom.
djthopa
Post by djthopa » Fri Mar 20, 2020 12:07 pm
I assume led cathode square pad on pcb?
Altitude909
Post by Altitude909 » Fri Mar 20, 2020 1:06 pm
yes
djthopa
Post by djthopa » Fri Mar 20, 2020 1:18 pm
yes
Thanks Altitude,
One last thing, VR1, VR2, VR3, VR4, VR5, VR6 are 10kb pots as in the BOM 858-P0915N-FC20BR10K
Also, lcd needs spacers right?
djthopa
Post by djthopa » Fri Mar 20, 2020 4:07 pm
last one.
so buttons 7/8/910/11/12 are not used.
Panel does not have those holes.
Altitude909
Post by Altitude909 » Fri Mar 20, 2020 4:30 pm
last one.
Depends, as noted above, I screwed up the first batch of panel orders and shipped the click pot ones. The corrected ones will be here tuesday so I'll continue sending replacements then. Alternatively, the click pots are scheduled to ship on the 24th (also tuesday) and I'll make those available for the DIY people so if you want to go that route, simply wait till next week and order the pots then
OLED spacers should be 6mm, i've never found ones I like at mouser (I used nylon ones) but I'll make a note on the BOM for those
djthopa
Post by djthopa » Fri Mar 20, 2020 5:38 pm
Thanks Altitude909 for your help.
Enjoyed this built!
Congrats to Neutron for a great sound module :sb: :sb:
Now to learn all the functions ;)
sduck
Post by sduck » Fri Mar 20, 2020 9:16 pm
Looks great! Just started mine tonight.
Did you figure this out?
And what did you use for the switched pots?
whyfarer
Post by whyfarer » Sat Mar 21, 2020 12:19 am
are there any important specs on the sd card? the one listed in the BOM is out of stock at mouser.
edit: similarly the bat54s is also out. can anyone point me towards suitable substitutions?
much thanks
Altitude909
Post by Altitude909 » Sat Mar 21, 2020 6:18 am
class 10 is recommended.
any BAT54S will work fine provided its SOT-23
https://www.mouser.com/Semiconductors/D ... 4s&FS=True
fixed. qty was right but designators were missing. Just a side note on this for anyone that goes by the diptrace files. The bypass caps dont have a value on them so if you search for 0.1u, they wont show up (C6 and C17 will)
whyfarer
Post by whyfarer » Sat Mar 21, 2020 9:26 am
excellent - thanks
KittenVillage
Post by KittenVillage » Sat Mar 21, 2020 10:10 pm
excellent - thanks
I went with BAT54SLT1G for mine.
Half done. Looking forward to it.
Eurorack is an exercise in delayed desire.
Neutron7
Oldschool bleeper
Post by Neutron7 » Sun Mar 22, 2020 11:35 am
About BAT54S you may be tempted to use non “S” ones, but that S is not simply a grade bin like a transistor or op-amp
, the different suffix letters mean the 2 diodes are wired differently, and can cause bad things, including shorting power to ground!
Neutron7
Oldschool bleeper
Post by Neutron7 » Sun Mar 22, 2020 3:30 pm
If you finish your module, can you post what your calibration value ends up? mine is +6 with +42 cents 0 semis for A=440
by the way i just uploaded a new 0.8.1 with a better config screen. you can see the pitch frequency while you adjust the calibration. play octaves and get it as close to doubling frequency each octave, then once you are happy with it, you can adjust cents and semitones to A=440. then press the right screen button to save.
sduck
Post by sduck » Mon Mar 23, 2020 12:08 pm
Can I get some clarification about what resistor this is?
I could probably figure it out eventually by the process of elimination, but an official clarification would ease my mind. Somewhat. For a little while at least.
Altitude909
Post by Altitude909 » Mon Mar 23, 2020 6:19 pm
Here's a PDF of the layout
DOT DIY.pdf
Neutron7
Oldschool bleeper
Post by Neutron7 » Mon Mar 23, 2020 6:49 pm
sduck
Post by sduck » Mon Mar 23, 2020 11:05 pm
